POV-Ray : Newsgroups : povray.general : Unhandled exception rendering guassianblob.pov in 3.6 Server Time
15 Jan 2026 05:47:23 EST (-0500)
  Unhandled exception rendering guassianblob.pov in 3.6 (Message 1 to 8 of 8)
Subject: Unhandled exception rendering guassianblob.pov in 3.6
Date: 5 Nov 2004 11:55:01
Message: <web.418baf5b1de09dac8b9853a0@news.povray.org>
I didn't see any message about this previously. I am running Win98
512 Mb on an Athelon XP 2500+. I retrieved this program from the
net. It is credited to Greg M. Johnson 2001. It runs fine on 3.5,
however I get an unhandled exception in PoV 3.6.1.
The code is short, and uses an array of 7500 objects.
Subject: Re: Unhandled exception rendering guassianblob.pov in 3.6
Date: 5 Nov 2004 12:30:00
Message: <web.418bb816330fe60dc8b9853a0@news.povray.org>
Here is the code:
// Demo scene for povray 3.5
// Features Gaussian distribution and use of trace function
// Composed by Greg M. Johnson 2001
// Uses a macro by Rico Reusser.
#declare UseRadiosity = no;
#declare S = seed(20173);
#declare CompRadius=0.05;//radius of blob components;
#declare CompNum=7500;//number of blob components
#if(UseRadiosity)
 global_settings {
  radiosity {
   pretrace_start 0.04
   pretrace_end 2/300
   count 400
   recursion_limit 2
   nearest_count 1
   error_bound 0.2
 #default {finish { ambient 0}}
#else
 light_source {<0, 200, -100> colour rgb 1.5}
//This macro created by Rico Reusser <reu### [at] chorusnet>
#declare e = 2.718281828459;
#macro Gauss(RSR)
 sqrt(-2*log(rand(RSR))/log(e))*cos(2*pi*rand(RSR))
plane {y,-0.9105  pigment {White}}
#declare Norm=<0,0,0>;//This variable is used to hold the normal vector
obtained
//using trace(). This vector is then used to determine whether an
intersection was found.
#declare Posy=array[CompNum]
#declare Posy[0]=<Gauss(S),0,Gauss(S)>;
#declare Ally=sphere {Posy[0], CompRadius}//This variable will hold a
collection of spheres,
//one for each blob component. The algorithm checks against this object to
decide
//if a component is "on top of" another.
#declare N=1;
#while(N<CompNum)
 #declare Test=<Gauss(S),0,Gauss(S)>;
 #declare Tracey=trace(Ally,Test+100*y,-y,Norm);
 #if (Norm.x = 0 & Norm.y = 0 & Norm.z = 0)
  #declare Posy[N]=Test;
  //put the new component at y=0
 #else
  #declare Posy[N]=Tracey+Norm*CompRadius;
  //put the new component at a point "above" the one it hit
  //The algorithm actually uses the normal to compute the position
 //Add new sphere to union
 #declare Ally=
 union {object {Ally}
  sphere {Posy[N], CompRadius}
// #debug concat(str(N,4,0), "n")
 #declare N=N+1;
blob {
 threshold 0.5
 #declare N=0;
 #while(N<CompNum)
  sphere {Posy[N], CompRadius*2.85, 1}
  #declare N=N+1;
 pigment {rgb <0.2,1,0.1>}
background {White}
sphere {<0.5,0,0>, 0.5
 inverse
  gradient x
  pigment_map {
   [0.0   rgb 0]
   [0.995   rgb 0.04]
   [1.0   rgb 2]
 finish {ambient 20}
 translate <-0.5,0,0>
 scale 500
 location <0,3,-15>
 look_at <0,0,0>
 angle 20
Date: 5 Nov 2004 13:43:35
Message: <418bc9d7@news.povray.org>
In article <web.418baf5b1de09dac8b9853a0@news.povray.org> , "Dan"
The scene design was and is defective.  We just forgot to remove it from the
distribution.
    Thorsten
Thorsten Froehlich
e-mail: mac### [at] povrayorg
I am a member of the POV-Ray Team.
Date: 15 Nov 2004 09:30:01
Message: <web.4198bceb330fe60dc8b9853a0@news.povray.org>
> distribution.
>     Thorsten
> Thorsten Froehlich
Thank you for your official response. Though I don't understand
what is wrong in the scene design, I think that this should
be listed as a bug. Any sequence of code that causes the program
to crash is bad. The fact that it works without problems in 3.5
just makes it more likely that the bug will be encountered.
Date: 15 Nov 2004 10:10:17
Message: <4198c6d9@news.povray.org>
In article <web.4198bceb330fe60dc8b9853a0@news.povray.org> , "Dan"
No, it is not a bug in POV-Ray and that is does not occur on some platforms
when using POV-Ray 3.5 is pure luck.
    Thorsten
e-mail: tho### [at] trfde
Date: 15 Nov 2004 10:35:02
Message: <cnai6h$fgf$1@chho.imagico.de>
> to crash is bad.
That is right but it is quite illusive to assume it would be possible to
prevent POV-Ray from crashing with *any* piece of code.  So obviously
this kind of problem has low priority in comparison to problems that
cause something failing that should work.
BTW it is well possible to modify this scene to work as intended but
there is no really efficient way to do this kind of thing in current SDL.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 15 Nov 2004 10:39:15
Message: <4198cda3@news.povray.org>
Luck has nothing to do with the execution of computer code.  There must
be another reason why it does not happen on some platforms in version 3.5.
Tim Cook
Version: 3.12
Date: 15 Nov 2004 10:43:47
Message: <4198ceb3@news.povray.org>
In article <4198cda3@news.povray.org> , Tim Cook <z99### [at] bellsouthnet>
No, but this is not povray.programming .
    Thorsten
