POV-Ray : Newsgroups : povray.general : Rendering The Scene Description Server Time
1 Mar 2026 22:33:17 EST (-0500)
  Rendering The Scene Description (Message 1 to 2 of 2)
Subject: Rendering The Scene Description
Date: 28 Jul 2004 17:10:00
Message: <web.4108157ae40b467e681299870@news.povray.org>
I find it tricky to think in 3D as I code SDL.  All too often I confuse
myself regarding the relative positioning of the camera, lights, and
objects.  I realize there are several 3D modelling programs but I'm curious
if it's possible for PovRay to render it's own scene description?
The idea is to have a special command for Povray to render the classical
front, side, top and camera perspectives as images but including special
objects to represent the lights and camera as well as the usual SDL
objects.  The output would be 4 bitmap images (or maybe 1 bitmap with the 4
views in it).
With such an output I could then get a visual indication of the relative
positioning of my camera, lights, and objects.  This might be thought of as
a meta-rendering where Povray internally constructs a meta-scene to show
the SDL scene-under-construction's layout.
Would this be a difficult extension to PovRay?
Cheers,
Bill
Subject: Re: Rendering The Scene Description
Date: 28 Jul 2004 23:56:25
Message: <41087569@news.povray.org>
<snip>
<snip>
Its not difficult to do in SDL, no need for an extension to the program.
Once I have the basics of what I want in my scene I usually do something
like that as a routine way of fine tuning my scene.
I first have my camera position & primary light positions defined;
#declare Cam_Pos = <position>
#declare Lights = <positions...>
Then I create a switch - case set of cameras for the usual top, side &
director views;
#declare VIEW = 0;
#switch(VIEW)
  #case (1)
    camera <some_y_spot>
  #break
  #case(2}
    camera <some_x_spot>
  #break
  #case (3)
    camera <some_z_spot>
  #break
  #case(4}
    camera <rear_perspective>
  #break
  #else
    camera Cam_Pos
Then I make a red cone for the fake camera and some bright yellow
spheres for the fake lights, using the reorient_trans macro to aim the
camera to the look_at, and enclosed in
#if (VIEW)
   object { fake_camera )
Then set VIEW to 0 to render my scene normally, or to 1,2,3 or 4 to get
whatever view I need.
I actually find this far more flexible than the views in Bryce or
Truespace since I'm constantly moving those around through wireframes to
try and get a view of something specific, while with Pov SDL, its easy
to set the camera to look_at specific objects or directions using
variables that I usually already have defined in the scene.
If I know there's a particular spot in the scene that I'm going to be
spending time on I define my working camera locations right into the
scene as I'm building it, then I can instantly switch to them any time.
RG
