POV-Ray : Newsgroups : povray.general : Bending isosurface functions Server Time
4 Oct 2024 00:21:49 EDT (-0400)
  Bending isosurface functions (Message 1 to 8 of 8)
Subject: Bending isosurface functions
Date: 26 May 2004 09:45:00
Message: <web.40b49ec5ed899368e1a5e5d0@news.povray.org>
I tried many ways to bend a GSG object. The only possibility was Chris
Colefax's object bender. But the you have to set the quality that high,
that rendering takes too much time for an animation.
Now I'm looking for a mathematical way to bend an isosurface function. As
example you can made a torus with a cylinder. That would be stupid, but it
is an example.
When you want to translate an function 7 units along the x-axis, you have to
write function(x-7,y,z), not function(x+7,y,z). Thats the point: I have a
transformation to bend an object, but it is the wrong way:
xnew = cos(x/radius)*(radius+z)
znew = sin(x/radius)*(radius+z)
Solving to x and z gives a stupid result, becaus sin and cos have infinite
solutions.
Do you now any other ways to bend an Isosurface object?
Subject: Re: Bending isosurface functions
Date: 26 May 2004 09:56:32
Message: <sa89b0htch01l4rt5m39av8sd3vcc56p6o@4ax.com>
This animation bends isosurface.
http://news.povray.org/povray.binaries.animations/attachment/%3C4d9jevcec7l8meqapa1f939dllrf23mk88%404ax.com%3E/isotorspline.mpg
Basically it uses combination of IC_Shaped_Arc with IC_Torus_Spline
http://www.tu-bs.de/~y0013390/pov/ic/docu02.html#Shaped_Arc
http://www.tu-bs.de/~y0013390/pov/ic/docu02.html#Torus_Spline
ABX
Date: 26 May 2004 11:15:36
Message: <40b4b498$1@news.povray.org>
> is an example.
> solutions.
I have successfully "bent" and deformed isosurfaces with NURBS.
(With one trivariate function for each of the x, y, and z axis.)
- But it was *really* painful to wait for the results. Maybe we
will have powerful enough processors in some years...
Tor Olav
Date: 26 May 2004 15:00:01
Message: <web.40b4e8801e85861e77fcd8f50@news.povray.org>
Thanks for the link and the idea.
Bending a cross section (defined by a spline) along a spline is exactly what
I need , but the render is too slow. I can't use it for my animation becaus
it takes too much of my time, not the computer's.
I see, looking for such a thing, fast AND good, is nearly impossible.
But I decided for the fast rendering, so I'm going to use the object bender.
Date: 26 May 2004 17:00:00
Message: <web.40b5045a1e85861e77fcd8f50@news.povray.org>
With a little bit more thinking, I could find the right operation for
bending an object (along the x-axis), so that a cylinder is bent to a
torus:
xnew = atan(z/x)*radius
ynew = y
znew = sqrt(x^2+z^2)-radius
--> function(atan(z/x)*radius, y, sqrt(x^2+z^2)-radius)
The rendering speed is ok, so I can use it.
Date: 27 May 2004 02:10:40
Message: <WfWW4AAQXYtAFwx4@econym.demon.co.uk>
>I need
Have you looked at these pages?
http://www.econym.demon.co.uk/isotut/more.htm
http://www.econym.demon.co.uk/isotut/splines.htm
Mike Williams
Gentleman of Leisure
Date: 27 May 2004 02:14:31
Message: <ZfsVYKA4aYtAFwRO@econym.demon.co.uk>
>torus:
>ynew = y
I don't think you need the atan(z/x)*radius, you can just use
function { F(sqrt(x*x+z*z)-r1, y, z) }
See <http://www.econym.demon.co.uk/isotut/substitute.htm#sor>
Mike Williams
Date: 27 May 2004 11:40:00
Message: <web.40b60b381e85861efb0f997b0@news.povray.org>
> Mike Williams
I tried it without replacing x (in my case) and it worked. --> less render
time. Thanks very much
I also rendered the bended (with splines) 2D-star, but it was very slow.
Do you know anything about a bug when you are using macros with more than 7
parameters? I have big trouble with this.
