POV-Ray : Newsgroups : povray.general : Sweep Spline Along Spline Server Time
30 Mar 2026 17:46:47 EDT (-0400)
  Sweep Spline Along Spline (Message 1 to 6 of 6)
Subject: Sweep Spline Along Spline
Date: 22 Apr 2004 16:50:01
Message: <web.40882e93ffb86f20eba257cf0@news.povray.org>
One of the commands I use the most when I'm working in 3D CAD applications
such as Solid Edge, AutoCAD, or MicroStation is the one that generates a
solid object by sweeping a closed shape along a path.  Very often when I'm
thinking of modelling something in POV I wish for such a command.  I have
read and re-read the POV documentation and can't find an analogous
constuction.  The closest thing seems to be the sphere sweep, but unless
you want a circular crossection this doesn't seem to be much use.  Am I
missing something?
I realize that if I want to follow a path of straight line tangent segments
and arcs I can assemble a series of prism and partial lathe objects, but
unless there's an existing macro for that it seems fairly laborious.  Does
anyone know of such a macro?  Also, it seems to me that if there are any
'kinks' in the path, assembling pieces like this won't work well either.
Comments and suggestions welcomed.
Thanks,
Sun.
Subject: Re: Sweep Spline Along Spline
Date: 23 Apr 2004 05:19:32
Message: <4088dfa4$1@news.povray.org>
Hi SunTzu,
I had the same problem as well, when trying to make the ears of some mugs.
The cross-section was an union of two (half-)elipses.
segments
thats how I solved it, the results are pretty good, as long as you don't
make the object transparant.
this is another problem indeed.
So, I can't help you with a nice solution, but I can send you the code used
for the ears of the mugs if you like?
Greetings,
JWV
"SunTzu2" <sun### [at] hotmailcom> wrote in message
news:web.40882e93ffb86f20eba257cf0@news.povray.org...
> missing something?
segments
> Thanks,
> Sun.
Date: 23 Apr 2004 05:28:01
Message: <edoh8011cd86fs07larhntqlc11j6b12h5@4ax.com>
See bottom of http://www.econym.demon.co.uk/isotut/more.htm
HTH, ABX
Date: 23 Apr 2004 09:30:01
Message: <web.408919be525e5dceba257cf0@news.povray.org>
Thank you.  My first impression (after about 2 minutes looking at the code)
is that I don't understand what the 'waist' parameter is for in the
'sweepspline' macro.  If you know I'd appreciate it if you could tell me,
otherwise I'll just play with it when I get home from work and try and
figure it out.
Sun.
Date: 23 Apr 2004 09:43:32
Message: <j17i80ta69m2cs0ubbllllvlv2erl1i58m@4ax.com>
> figure it out.
I never used this macro but as far as I understand description:
Waist  A spline with x coordinates that specify the radius of the spheresweep
       The secion of the spline between control points 0 and 1 will be used
it is characteristic how radius changes along base spline. So Basically
writing it this way:
My_Waist = spline { linear_spline 0 , 0 , 1 , 2 }
means for me that at the begioning sweeped shape is as minimal as possible :-)
(nothing/point/vertex) and at the end of sweeping it is twice large as
designed. But as I said I never used that macro.
ABX
Date: 23 Apr 2004 11:19:12
Message: <Xns94D4B02FC96CAseed7@news.povray.org>
> applications such as Solid Edge, AutoCAD, or MicroStation is the one
> that generates a solid object by sweeping a closed shape along a
> path.
I posted an extruder/lofter by Daniele Varrazzo in:
Newsgroups: povray.binaries.utilities
Subject: Striscia, extruder/lofter
Message-ID: <Xns94D4AF6BE46A0seed7@news.povray.org>
Date: 23 Apr 2004 11:15:11 -0400
Xref: news.povray.org povray.binaries.utilities:3720
It is completely SDL based and doesn't use the since 3.5 built in splines.
Ingo
