POV-Ray : Newsgroups : povray.general : Parser in C/C++ for PovRay Server Time
20 Apr 2026 05:50:17 EDT (-0400)
  Parser in C/C++ for PovRay (Message 1 to 5 of 5)
Subject: Parser in C/C++ for PovRay
Date: 8 Dec 2003 02:20:01
Message: <web.3fd425569bd6da3dd11b8e040@news.povray.org>
Hello
I am a newbee in gamedevelopment. I want to use PovRAY to model my 3d
gameobjekts, and I need a parser to load and parse the PovRAY file. Is
there any free parser in C/C++? Any nonfree?
Best regards
Henrik Teinelund
Subject: Re: Parser in C/C++ for PovRay
Date: 8 Dec 2003 10:20:11
Message: <cjameshuff-B671F4.10195708122003@netplex.aussie.org>
In article <web.3fd425569bd6da3dd11b8e040@news.povray.org>,
First hit on Google:
http://www.cournia.com/classwork/cpsc805/proj2/
POV2MDL has one:
http://www.tb-software.com/pov2mdl.txt
There are a few others...but nothing that comes anywhere close to a full
implementation. To do that, one would have to rewrite most of POV-Ray
itself.
http://tag.povray.org/
Date: 8 Dec 2003 13:26:28
Message: <3fd4c254$1@news.povray.org>
> Hello
model my 3d
PovRAY file. Is
> Best regards
> Henrik Teinelund
http://tag.povray.org/povQandT/filesQandT.html#povtootherformatsdifficulty
(especially the penultimate paragraph)
I would suggest a re-think if you're after triangle meshes
as the end result.  Blender is an example of an open-source
program which would probably suit your requirements.  And
there's probably many more - that's just the first one that
sprang to mind.
Date: 8 Dec 2003 18:06:07
Message: <3fd503df@news.povray.org>
> POV2MDL has one:
> itself.
Probably it would be a lot faster to patch POV in order to allow it to
export some sort of binary description of the scene (at least at a
geometrical level) or of a single object (you can always use an union
block to wrap all the geometry of your scene into a single instance).
Given a fixed data format it would be pretty easy for 3rd part
developers to write some sort of conversion utilities. Tessellation
would not be mandatory since a lot of modern 3d program nowadays can
handle "compound objects" such as CSG.
Jonathan.
Date: 8 Dec 2003 20:50:06
Message: <3fd52a4e@news.povray.org>
gmax.
Andrew wrote:
>>Hello
> model my 3d
> PovRAY file. Is
>>Best regards
>>Henrik Teinelund
> sprang to mind.
