POV-Ray : Newsgroups : povray.general : while-loop in macro Server Time
11 Jan 2026 19:39:42 EST (-0500)
  while-loop in macro (Message 1 to 10 of 11)
Subject: while-loop in macro
Date: 23 Feb 2003 16:45:18
Message: <web.3e5940689d42b660de2a6cfb0@news.povray.org>
now i'm pulling out my hear on this problem
i just started with this macro to create a fence:
#macro Fence(Flength, Fheight, Fspace, Fdiam)
   #local i=0;
   #while(i< Flength/Fspace+1 )
      cylinder{ <0,0,0> <0,Fheight,0> Fdiam/2 }
      translate <i*Fspace, 0, 0>
     #local i=i+1;
the macro itself is ok when rendered, but of course you only get a black
screen.
When i try to call the macro in an object as following, i get an error "no
matching '}' in object, cylinder found instead".
I allready found out the problem has to do with the #while loop. but i can't
find how to fix. Please can someone guide me throug this?
object{
   Fence(400, 150, 20, 1.5)
   pigment{ rgb .1 }
Subject: Re: while-loop in macro
Date: 23 Feb 2003 16:52:00
Message: <3e59427f@news.povray.org>
>    #local i=0;
>      #local i=i+1;
>    #end
> #end
> screen.
So you finally have:
object {
  cylinder { }
  translate
  cylinder { }
  translate
This makes no sense, as far as I know. Try calling it as an union (instead
of object) and moving the translate block inside the cylinder braces. So
you have:
union {
  cylinder {
    translate
  cylinder {
    translate
Linux User #289967 (counter.li.org)
PGP Pub Key ID: 0x01A95F99 (pgp.escomplinux.org)
Date: 23 Feb 2003 17:10:07
Message: <web.3e594598d27a3e2ede2a6cfb0@news.povray.org>
>object {
>  cylinder { }
>  translate
>  cylinder { }
>  translate
i don't understand how you come to that :-s
>you have:
>union {
>  cylinder {
>    translate
>  cylinder {
>    translate
calling it as a union doesn't work. but the problem is something with the
while-loop and not with the cylinder. when i remove the #while and #end,
everything works fine.
when i add that while, i get the error.
it's very strange...
thx for the reply!
lenx
Date: 23 Feb 2003 17:27:52
Message: <3e594ae8@news.povray.org>
It's called loop unrolling... He (Jellby) is right, your code is not
supposed to work; I'm surprised you say it compiles.
Enclosing this in a 'union' is not that necessary -- as long as you, at
least, put your 'translate' statements inside 'cylinder' blocks.
Date: 23 Feb 2003 17:33:07
Message: <cjameshuff-A5EFF5.17294623022003@netplex.aussie.org>
In article <web.3e594598d27a3e2ede2a6cfb0@news.povray.org>,
> >object {
> >  cylinder { }
> >  translate
> >  cylinder { }
> >  translate
Your macro:
   #local i=0;
     #local i=i+1;
It loops over a cylinder and translate statement. You then call it in an
object block...and get the expected result.
Since your translate statement is apparently intended to translate the
cylinder, it should go in the cylinder block. And an object block can
only contain one object, you need to put either the macro call or the
loop itself in a union.
BTW, your "i" variable is poorly named. It is a good idea to always use
at least one upper-case letter in a variable name, which will prevent
conflicts with future keywords.
http://tag.povray.org/
Date: 23 Feb 2003 17:45:22
Message: <cjameshuff-6FB941.17420123022003@netplex.aussie.org>
In article <3e594ae8@news.povray.org>,
Huh? He didn't. Nobody mentioned anything compiling, which is good,
because POV doesn't compile anything. He did say it didn't work.
Putting it in a union has the advantage that the entire group of
cylinders can be transformed and textured as a single object. Not
strictly necessary, but more flexable.
Date: 23 Feb 2003 18:27:30
Message: <3e5958e2@news.povray.org>
I was referring to his words that "the macro itself is ok when rendered, but
of course you only get a black screen.". That is, it seemed like he was
complaining about the macro not working in some particular case. Maybe I
just misundertood him.
Date: 23 Feb 2003 18:48:10
Message: <cjameshuff-0B0D6F.18444923022003@netplex.aussie.org>
In article <3e5958e2@news.povray.org>,
Ah, I see...I understood this as "when I don't call the macro". His
macro will parse fine, as long as it isn't actually called. It won't
parse if it is called outside an object block, which might be what you
meant. (I don't think it will parse anywhere)
Date: 24 Feb 2003 12:55:02
Message: <web.3e5a5c25d27a3e2e293f3c960@news.povray.org>
thanks Christopher, you made it clear to me.
i was complaining about the macro, working on itsself, but not working when
called in an object.
so the macro renders without errors, but called in an object it gives error.
thanks to you all!
//code is now:
   union{
   #local I=0;
   #while(I< Flength/Fspace+1 )
         cylinder{
            translate <I*Fspace, 0, 0>
      #local I=I+1;
Date: 24 Feb 2003 16:30:16
Message: <cjameshuff-FB8598.16263324022003@netplex.aussie.org>
In article <web.3e5a5c25d27a3e2e293f3c960@news.povray.org>,
When a macro is just defined, very little parsing is done. The contents
of the macro only really exist to the parser when the macro is called
