POV-Ray : Newsgroups : povray.general : Only rendering part of a frame Server Time
22 Mar 2026 16:47:05 EDT (-0400)
  Only rendering part of a frame (Message 1 to 3 of 3)
Subject: Only rendering part of a frame
Date: 27 Dec 2002 20:20:02
Message: <web.3e0cfbb41992fd35ddfe293c0@news.povray.org>
Hey all,
I have a curious graphic whose render will result in a frame which is
symetrical left and right. The complicated lighting and reflections I
employed make a 7 hour render not unacceptable, but surely unwanted. If I
could just render half and then duplicate it and flip it, I could save 4.5
hours. But I seem to devise a method of doing so. My rotating the camera to
only view half, I change the focal point and the perspectives all shift. I
am failing to summon the technical terms to describe this phenomena, but
for those of you who understand what I am speaking of and perhaps how to
leave my camera in place, while only rendering part of the frame, I would
appreciate any advice you could offer.
Sincerely,
Jared Chung
Subject: Re: Only rendering part of a frame
Date: 27 Dec 2002 20:40:02
Message: <web.3e0d0075d2a34a27d655a8f0@news.povray.org>
Jared wrote:
>Hey all,
I am not sure if it solves your problem,
but if you use POV-Ray for Windows, you
can start a rendering and then stop it.
Then you can just select a region in the
rendering window with the mouse. POV-Ray
will then render this region only.
IIRC you can also give POV-Ray command
line options to achieve the same, but I
have not done this. (So you may want to
read about it in the manual.)
Tor Olav
Date: 27 Dec 2002 21:18:17
Message: <3e0d09e9@news.povray.org>
In article <web.3e0d0075d2a34a27d655a8f0@news.povray.org> , "Tor Olav
He could just read the manual sections about the partial render options
(probably you should do the same) to find out how to specify only a part of
an image can be rendered.
Documentation section "5.2.2.1.2 Partial Output Options", online at
<http://www.povray.org/documentation/view/128/>.
    Thorsten
e-mail: tho### [at] trfde
