![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
I am creating a vaulted aisle (like in a gothic cathedral). The shape of the
vault is not a sphere or a cylinder, it is a complex mathematic surface
function. I need to make it look like made of bricks using the 'brick'
pigment but I can not find the way to make the bricks to appear correctly.
I build the surface with a mesh made of triangles calculated on the fly
using the 3D function (much faster than the corresponding isosurface).
To apply the bricks, I am using uv_mapping and uv_vectors but always the
bricks appear well on the upper side (almost horizontal) but highly
distorted in the almost or completely vertical surfaces in the lower part.
If I try to calculate the uv_vectors to take the appropriate portion of the
brick pigment, then the pigments on each triangle doesn't match with their
neighbours.
I feel that I'm walking in the wrong direction. Any lights?
Thanks,
Zoly
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Maybe some code and/or a sample image might help...
Kyle
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
"Zoly" <nomail@nomail> wrote in message
news:web.4554e04ace7089d1f6a4e110@news.povray.org...
> the
> neighbours.
If your uv's don't match up between faces then you're going to see
discontinuities, but for what you want it might be easier to switch off
uv_mapping and just line the pattern up as best you can using scale &
rotate.
Tek
http://evilsuperbrain.com
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
> Kyle
I'm posting a small scene that reproduces the problem. It is not very
easibly readable but you can cut and paste and have a look at the image.
Thanks,
Zoly
//--- VAULT CONSTRUCTION
#macro Vault(P01,r1,a1,n1,P02,r2,a2,n2,h)
#local dd=0.00001;
#local dl=0.1;
#local h1=r1*sqrt(2*n1-1);
#local h2=r2*sqrt(2*n2-1);
#local x01=P01.x;
#local x02=P02.x;
#local z01=P01.z;
#local z02=P02.z;
#local fr1=function(y) {
(y>h-h1)*(-r1*(n1-1)+sqrt(pow(r1*n1,2)-(y>h-h1)*pow(y-(h-h1),2)))+(y<=h-h1)*r1
#local fr2=function(y) {
(y>=h-h2)*(-r2*(n2-1)+sqrt(pow(r2*n2,2)-pow(y-(h-h2),2)))+(y<=h-h2)*r2
#local x1=function(y) {x01+fr1(y)*cos(radians(a1))}
#local x2=function(y) {x02+fr2(y)*cos(radians(a2))}
#local z1=function(y) {z01-fr1(y)*sin(radians(a1))}
#local z2=function(y) {z02-fr2(y)*sin(radians(a2))}
mesh {
#local i=h;
#while (i>0)
#local a_i=i;
#local i=i-dl/sqrt(1+pow((fr1(i)-fr1(i-dd))/dd,2));
triangle {
<x1(a_i),a_i,z1(a_i)> <x2(a_i),a_i,z2(a_i)> <x1(i),i,z1(i)>
uv_vectors <x1(a_i),z1(a_i)> <x2(a_i),z2(a_i)> <x1(i),z1(a_i)>
triangle {
<x2(a_i),a_i,z2(a_i)> <x1(i),i,z1(i)> <x2(i),i,z2(i)>
uv_vectors <x2(a_i),z2(a_i)> <x1(i),z1(i)> <x2(i),z2(i)>
uv_mapping
brick rgb 0.15 rgb 0.2
scale 0.08
rotate 90*z
//--- MAIN OBJECT
object {Vault(<0,5,-3.59>,3.555,0,1.2,<0,5,0>,5,40,1,5)}
object {Vault(<0,5,-3.59>,3.555,0,1.2,<0,5,0>,5,40,1,5) scale <-1,1,1>}
//--- SECONDARY STAFF
light_source {<0,0,0> 2}
light_source {<50,50,-50> 5}
camera {location <4,2,-10> look_at <0,2,1> rotate <0,-10,0>}
plane {y, 0 pigment {rgb <0.08,0.02,0>}}
sky_sphere {pigment {rgb <0.04,0.04,0.2>}}
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
Zoly,
Here's my suggestion:
>>> snip >>>
#local U = 0;
mesh {
#local i=h;
#while (i>0)
#local a_i=i;
#local Uinc = abs(vlength(<x2(a_i),a_i,z2(a_i)>-<x2(i),i,z2(i)>));
triangle {
uv_vectors <U,z1(a_i)> <U,z2(a_i)> <U+Uinc,z1(i)>
#debug concat("T1: ",vstr(3,<x1(a_i),a_i,z1(a_i)>,",",0,5))
#debug concat(" - ",vstr(3,<x2(a_i),a_i,z2(a_i)>,",",0,5))
#debug concat(" - ",vstr(3,<x1(i),i,z1(i)>,",",0,5),"\r")
triangle {
uv_vectors <U,z2(a_i)> <U+Uinc,z1(i)> <U+Uinc,z2(i)>
#debug concat("T2: ",vstr(3,<x2(a_i),a_i,z2(a_i)>,",",0,5))
#debug concat(" - ",vstr(3,<x1(i),i,z1(i)>,",",0,5))
#debug concat(" - ",vstr(3,<x2(i),i,z2(i)>,",",0,5),"\r\r")
#local U = U + Uinc;
uv_mapping
scale 0.04
rotate 90*z
>>> snip >>>
I hope this helps, or at least gets you going in the right direction.
Kyle
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
My hat is absolutely off to you, Kyle. Thank you for your help and your
understanding of my code.
I have posted in povray.binaries.images how looks your solution in my (still
beta) Chartres Cathedral 'stone by stone' reproduction. There are still
pending the textures, ornaments ambient and lighting.
Rgds,
Zoly
> Zoly,
> >>> snip >>>
> #local U = 0;
> mesh {
> #local i=h;
> #while (i>0)
> #local a_i=i;
> triangle {
> #debug concat(" - ",vstr(3,<x1(i),i,z1(i)>,",",0,5),"r")
> triangle {
> #debug concat(" - ",vstr(3,<x2(i),i,z2(i)>,",",0,5),"rr")
> #end
> texture {
> uv_mapping
> pigment {
> scale 0.04
> rotate 90*z
> >>> snip >>>
> Kyle
![](/i/fill.gif) |
| ![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
![](/i/fill.gif) |
| ![](/i/fill.gif) |
![](/i/fill.gif) |
