POV-Ray : Newsgroups : povray.general : Applying finish to mesh2 Server Time
31 Mar 2026 01:07:35 EDT (-0400)
  Applying finish to mesh2 (Message 1 to 6 of 6)
Subject: Applying finish to mesh2
Date: 20 Feb 2004 15:03:28
Message: <slrnc3cq0g.d0o.ecaddiga@cardiff.ks.uiuc.edu>
Hi all,
I'm pretty new to POV, so please forgive me if it's an easy question.
I'm asking this only after searching both this news group and the web.
I have a mesh2 object and I'm already using different textures
(pigments, mostly) at the verticies. Now I'd like to apply a new texture
(a finish) to the entire mesh object, but can't figure out how to do it.
I'd rather not include the same finish in the texture block for each
vertex, as this file is already pretty large (>200 MB).
Thanks,
Eamon
Subject: Re: Applying finish to mesh2
Date: 20 Feb 2004 15:10:46
Message: <rcqc30heeinthvp6nc4mtvpta20rj2so6l@4ax.com>
I think chapter "6.2.4 The #default Directive" is what you are looking for.
ABX
Date: 20 Feb 2004 15:23:35
Message: <slrnc3cr66.d0o.ecaddiga@cardiff.ks.uiuc.edu>
Thanks! This does the trick, but I need to restore the original default
after each mesh2 object if the texture is to affect that object only.
-Eamon
Date: 20 Feb 2004 15:52:02
Message: <40367372$1@news.povray.org>
news:slr### [at] cardiffksuiucedu...
There's something I'm not sure I understand... It seems that you have one
texture for each vertex, which seems to defeat the idea of having a compact
format like mesh2 in the first place.
Usually, the textures in a mesh2 object are neatly packed in the
texture_list{} part and all you have to do is to declare them externally
before the mesh is loaded.
#declare T1=..
#declare T2=..
and then mesh2{... texture_list{4, texture{T1}texure{T2}...} ...}
G.
http://www.oyonale.com
- Graphic experiments
- Posters
Date: 20 Feb 2004 19:06:14
Message: <slrnc3d87m.d0o.ecaddiga@cardiff.ks.uiuc.edu>
> #declare T1=..
> #declare T2=..
I should confess that I'm writing code to export POV scenes from another
program. I plan to specify /only/ the uniqe textures used for the object
in the texture list soon, but for now I'm just trying to get things to
work.
On a related note, is it possible to create vertex-shaded triangles
outside of mesh objects? smooth_triangle only accepts a single color for
the entire triangle.
-Eamon
Date: 20 Feb 2004 22:06:50
Message: <4036CBDC.DECC302B@pacbell.net>
See - http://www.geocities.com/SiliconValley/Lakes/1434/otherincludes.html
Ken Tyler
