POV-Ray : Newsgroups : povray.general : Re: normal_transparency! Server Time
26 Feb 2026 03:47:08 EST (-0500)
  Re: normal_transparency! (Message 1 to 6 of 6)
Subject: Re: normal_transparency!
Date: 5 Jan 2001 11:47:34
Message: <slrn95bul8.cq4.ron.parker@fwi.com>
On Fri, 05 Jan 2001 11:36:08 -0500, Florentine Audet wrote:
>I am using POV to do some artistic works for my own
>pleasure.  Does someone could help me to get
>some shadows from a filtered texture with
>a normal modifier ?!  My problem is that the
>light rays come through my normal modifiers without
>doing shadows on to the others objects it affects.
It sounds like you're looking for caustics.  You might give MegaPOV a look
for its photon mapping feature.  (http://nathan.kopp.com/patched.htm)
Ron Parker   http://www2.fwi.com/~parkerr/traces.html
My opinions.  Mine.  Not anyone else's.
Date: 5 Jan 2001 14:48:42
Message: <3A562547.2F14E207@peak.edu.ee>
Although in this case the fake caustics in regular POV shoud give an acceptable
result (see subsection "Faked Caustics" in the "Interior" section)
Margus Ramst
Home page http://www.hot.ee/margusrt
Subject: caustic effect
Date: 6 Jan 2001 00:21:52
Message: <3A56AA9C.F6B3EFDA@sympatico.ca>
 look
ceptable
> Margus Ramst
> Personal e-mail: mar### [at] peakeduee
> TAG (Team Assistance Group) e-mail: mar### [at] tagpovrayorg
( what I am trying to do is imaging about under_water
simulation,  and stuff like that... Say,  a clear water,
with some visible ground in the bottom...
I am using an interior and a media statement
into a finite box of a given size, with the hollow keyword.)
I am not quiet sure if the caustic effect is what is doing the
spot of "moving" lights and shadows on a under-water ground.
Is it caustic ? Anyway I will try it;  It would be nice,  if it worked;
I have found something special in term of water-texture,  with
some "normal { agate scale }",  but it doesn't give any spots
of shadows at all...
Thanx a lot for the responses
                                                   Alex
Subject: Re: caustic effect
Date: 6 Jan 2001 00:49:45
Message: <3A56B223.4E35470F@pacbell.net>
Caustics are most certainly the effect you are looking for.
This is the effect you see at the bottom of a swimming pool
or the light shining through a glass of water.
Date: 6 Jan 2001 07:06:02
Message: <3A570AC6.CA9CE64D@inapg.inra.fr>
You can use normal and photons to do this but you can also fake it with a color_map.
G.
// using a color_map
camera {location  <2,3,-4>    direction z up y     right x*4/3 look_at <0,0,0>}
light_source {<-200,100,100>  color rgb 2}
box{<-2,0,-1>,<2,0.01,2> pigment{bozo poly_wave 0.5 color_map{[0 rgb<0.3,1,1>][1
rgbf<0.3,1,1,1>]} scale 0.5} translate y}
plane{y,0 pigment{rgb 1}}
// using photons
#version unofficial Megapov 0.6;
global_settings{photons  {count 20000}}
box{<-2,0,-1>,<2,0.01,2> pigment{rgbf<0.3,1,1,1>} interior{ior 1.33} normal{crackle 2
scale 0.3}  photons {target 1 refraction on }translate y}
http://www.oyonale.com
Graphic experiments
Pov-ray gallery
Graphic experiments
Pov-ray gallery
Subject: Alex
Date: 6 Jan 2001 18:25:04
Message: <3A57A87B.DEDF2675@sympatico.ca>
Thank You all very much.
I think I will use "caustics",  I tried it a little bit today,
and it seems to work very well.  It should appear to
you as a very basic optional keyword,  but for
myself I didn't use this function before...
... The color_map "fake" seems to be
a very good idea too ! ( probably better if
you want to see rays of light go through the water
volume,  with the scattering function ??! Or does
the particules will interact with the caustics effect
as small objects -surely - and show us
the rays of ligth through the water...
... I will try to take a guess with all that stuff
this week-end .
It is my first use of a forum;  It seems to me  to be
pretty rich and interesting... So,  thanks a lot
for these quick answers !!
        Alex
