POV-Ray : Newsgroups : povray.general : POVRay Fractal Raytracing Competition Server Time
21 Feb 2026 15:12:38 EST (-0500)
  POVRay Fractal Raytracing Competition (Message 1 to 10 of 34)
Subject: POVRay Fractal Raytracing Competition
Date: 2 Apr 2004 06:21:30
Message: <pdb_NOSPAM-B97870.21213002042004@news.povray.org>
The first POVRay Fractal Raytracing Contest is now open, see
   http://astronomy.swin.edu.au/povfrac/
If you have a favourite 3D fractal and ideas on an elegant way
to render it then maybe this contest if for you.
Paul Bourke
pdb_NOSPAMswin.edu.au
Subject: Re: POVRay Fractal Raytracing Competition
Date: 2 Apr 2004 06:42:42
Message: <406d51b2@news.povray.org>
Cool! There goes my weekend :)
10KB SDL. There really goes my weekend...
Florian
Date: 2 Apr 2004 07:05:21
Message: <406d5701@news.povray.org>
Doesn't this replicate too much IRTC with a topic of "fractals"?
This is mainly because there are practically no limits on what the
user can do (except using external files, which isn't very limiting,
and a maximum of 10000 bytes, which isn't very limiting either).
  The problem I see with this is that there's really no challenge
in this competition other than making a beautiful image. Which is
exactly what IRTC is for.
  (And of course how to define a "fractal" is another question...)
Date: 2 Apr 2004 07:10:02
Message: <c4jl08$4t8$1@chho.imagico.de>
Nice topic but the competition frequency is quite high, most people will
not be able to invest a serious amount of time that frequently.
The links of the sample images lead to a 404 BTW.
Last updated 21 Mar. 2004 _____./\/^>_*_<^\/\.______
Date: 2 Apr 2004 07:10:58
Message: <406d5852$1@news.povray.org>
"Warp" <war### [at] tagpovrayorg> wrote in message news:406d5701@news.povray.org...
I'm unclear as to why this is a problem/objection.
napolitana replicates margharita with a topping of 'anchovies' - I still like
both ;)
Date: 2 Apr 2004 07:14:26
Message: <406d5922@news.povray.org>
  Because there's no challenge. It's boring.
Date: 2 Apr 2004 07:30:02
Message: <c4jm69$524$1@chho.imagico.de>
Apart from what you already mentioned i think there are the following
important differences to the IRTC:
- the source code has to be provided
- manipulations in a paint program are not possible
- the images used for voting are guaranteed to be of comparable
technical quality
- the competition is restricted to POV-Ray
While the last point is surely a questionable advantage the other ones
make it quite different from the IRTC and could make it a great
demonstration of the capabilities of POV-Ray.
Date: 2 Apr 2004 07:37:22
Message: <pdb_NOSPAM-EF949E.22371902042004@news.povray.org>
Granted, this is very different in terms of a challenge from SSC3.
And it is similar to IRTC, on the other hand it is a short time
contest with significant public appeal and plenty of scope for
stimulating images.
Paul Bourke
Date: 2 Apr 2004 08:42:45
Message: <406d6dd5@news.povray.org>
  Since when this has been allowed in the IRTC?
Date: 2 Apr 2004 09:40:02
Message: <c4jtvr$7k0$1@chho.imagico.de>
I have not said anything about this being allowed - i was just talking
about the possibility.  In fact this rule has been interpreted quite
loosely recently in the IRTC - all kind of convolution filters are
considered not breaking the rules as well as resizing from a larger
render.  If you remove artefacts or do other tweaks in a larger render
and then scale it this is next to impossible to spot in the resulting image.
