POV-Ray : Newsgroups : povray.general : Camera angles problem Server Time
20 Dec 2025 06:17:32 EST (-0500)
  Camera angles problem (Message 1 to 10 of 31)
Subject: Camera angles problem
Date: 14 Aug 2013 15:08:42
Message: <op.w1tl4rt1ufxv4h@xena>
I am trying to duplicate the camera angle in a scene with a box mapped
with the image, but when I use certain camera positions and look
combinations, it rotates the image along the z axis. It seems to happen
when the Camera position and look position don't have the same y value.
How can i fix this?
here is a stripped down version. If the "doesn't work' part is commented
out it works fine.
I must admit, I don't always know when to use Reorient_Trans() vs
vrotate() vs VAngleD() and even less how to use them. It gets confusing.
// begin code
#version 3.7;
global_settings {  max_trace_level 5 assumed_gamma 1}
#include "Transforms.inc"
//works:
#declare CamPos= <0.5, 1.5,4.5 >;
#declare CamLook= <1.3,1.5,0>;
// doesn't work:
#declare CamPos= <0.5, 1.5,4 >;
#declare CamLook= <1.3,1.2,0>;
#declare CamDirect=<0,0,1>;
#declare CamWidth=image_width;
#declare CamHeight=image_height;
#declare ColMapPig=pigment {image_map { png "test.png" }
                             translate -0.5*(x+y)
                             scale <CamWidth/CamHeight,1,1>*2
box{<-CamWidth/CamHeight,-1,CamDirect.z>,<CamWidth/CamHeight,1,CamDirect.z+0.001>//}
                                 pigment {ColMapPig}
                                 finish { ambient 1 diffuse 1}
                            translate CamDirect
                            Reorient_Trans(z, (CamLook-CamPos))
                            translate CamPos
#declare ColMap="test.png"
         location  CamPos
         direction CamDirect
         right   x*image_width/image_height
         look_at CamLook
// End code
-Nekar Xenos-
Subject: Re: Camera angles problem
Date: 15 Aug 2013 10:47:51
Message: <520cea17@news.povray.org>
Nekar Xenos wrote:
> How can i fix this?
Have you tried specifying an explicit "up" vector?
Date: 15 Aug 2013 12:20:01
Message: <web.520cfebd572d40e6328783aa0@news.povray.org>
> How can i fix this?
> out it works fine.
Reorient_Trans() rotates an object so that a given axis is aligned with another
axis by rotating the object around an axis perpendicular to both.
e.g. reorienting the object to align its x axis with it's z axis would rotate it
around y.  This is, of course, an extremely trivial example, but you could also
use it to align an axis with a given vector (not sure if it needs to be a
unit-vector or not)
vrotate() simply rotates an object around a vector.
VAngle() and VAngleD() compute the angle between two vectors, the former
returning an angle in radians, the latter returning an angle in degrees.
> // begin code
> #version 3.7;
> //works:
> // doesn't work:
>                          texture {
>                                  pigment {ColMapPig}
>                             translate CamDirect
>                             translate CamPos
> camera {
>          location  CamPos
>          direction CamDirect
>          look_at CamLook
> // End code
> -Nekar Xenos-
I agree with Christian that you need to specify the up vector in your camera
definition.  My default camera is usually something like this: (actually a lot
like yours)
    perspective
    location locVect
    up y
    right x*(image_width/image_height)
    look_at lookVect
regards,
A.D.B.
Date: 15 Aug 2013 14:00:36
Message: <op.w1vdnapkufxv4h@xena>
On Thu, 15 Aug 2013 16:47:48 +0200, Christian Froeschlin <chr### [at] chrfrde>
wrote:
> Nekar Xenos wrote:
>> How can i fix this?
According to the docs up y is the default camera value.
But that is not the problem. If you add a horizontal plane to this scene,
you will see that it is the box that needs an up y option - not the
camera. I am not quite sure how to simulate that.
-Nekar Xenos-
Date: 15 Aug 2013 14:05:59
Message: <op.w1vdv5auufxv4h@xena>
On Thu, 15 Aug 2013 18:16:51 +0200, Anthony D. Baye
>> How can i fix this?
>> out it works fine.
> another
> rotate it
> could also
> unit-vector or not)
So this is the correct one to use.
Thanks Anthony. The docs don't specify that it is an abject that gets
rotated.
>> // begin code
>> #version 3.7;
>> //works:
>> // doesn't work:
>>                          texture {
>>                                  pigment {ColMapPig}
>>                             translate CamDirect
>>                             translate CamPos
>> camera {
>>          location  CamPos
>>          direction CamDirect
>>          look_at CamLook
>> // End code
>> -Nekar Xenos-
> camera
> a lot
> like yours)
> camera {
>     perspective
>     location locVect
>     up y
>     look_at lookVect
> regards,
> A.D.B.
This makes no difference. In this case my object needs an "up y" option :S
-Nekar Xenos-
Date: 16 Aug 2013 00:25:01
Message: <web.520da8bc572d40e6328783aa0@news.povray.org>
> >> How can i fix this?
> >> out it works fine.
> > another
> > rotate it
> > could also
> > unit-vector or not)
> rotated.
well... What it actually does, is rotate a point A around the origin by a given
amount B. -- Sorry, I misread, and was thinking of vaxis_rotate(...).
so you could use it like this:
object {
    translate vrotate(A, B)
vaxis_rotate(A,B,F) does what I said.  Where A is, again, a point in space, B is
a vector around which A is rotated by an amount F.
you would use it in the same way as vrotate.
A.D.B.
regards
Date: 16 Aug 2013 00:30:01
Message: <web.520daa2b572d40e6328783aa0@news.povray.org>
I should also be clear that with vrotate(A,B), B is also a vector.  So:
object {
is the same as:
object {
    translate A
    rotate B
A.D.B.
Date: 16 Aug 2013 05:11:11
Message: <520decaf@news.povray.org>
Am 16.08.2013 06:27, schrieb Anthony D. Baye:
> object {
> is the same as:
> object {
>      translate A
>      rotate B
Nope. It's rather like
     rotate <0,0,-B.z>
     rotate <0,-B.y,0>
     rotate <-B.x,0,0>
     translate A
     rotate B
Date: 16 Aug 2013 14:10:01
Message: <web.520e6a4f572d40e6328783aa0@news.povray.org>
> > object {
> > is the same as:
> > object {
> >      translate A
> >      rotate B
>      rotate <0,0,-B.z>
>      rotate <0,-B.y,0>
>      rotate <-B.x,0,0>
>      translate A
>      rotate B
Then the documentation needs serious clarification.  That is not mentioned at
all.
http://www.povray.org/documentation/view/3.7.0/229/
From: Pov-Ray documentation 2.2.1.4 Vector Expressions --
"vrotate(A,B) Rotate A about origin by B. Given the x,y,z coordinates of a point
in space designated by the vector A, rotate that point about the origin by an
amount specified by the vector B. Rotate it about the x-axis by an angle
specified in degrees by the float value B.x. Similarly B.y and B.z specify the
amount to rotate in degrees about the y-axis and z-axis. The result is a vector
containing the new x,y,z coordinates of the point."
A.D.B.
Date: 16 Aug 2013 14:25:01
Message: <web.520e6d62572d40e6328783aa0@news.povray.org>
> > > object {
> > > is the same as:
> > > object {
> > >      translate A
> > >      rotate B
> >      rotate <0,0,-B.z>
> >      rotate <0,-B.y,0>
> >      rotate <-B.x,0,0>
> >      translate A
> >      rotate B
> all.
> Regards,
> A.D.B.
see example in p.b.i
A.D.B
