POV-Ray : Newsgroups : povray.general : Tessellating a union of spheres Server Time
30 Sep 2024 05:23:05 EDT (-0400)
  Tessellating a union of spheres (Message 1 to 5 of 5)
Subject: Tessellating a union of spheres
Date: 14 Oct 2006 03:53:11
Message: <k1d204-roa.ln1@badulaque.unex.es>
Hi all,
I have a problem which is not really related to POV-Ray but I guess someone
here can help me.
I have to tesselate a union of spheres. I can create a polyhedron (pentakis
icosahedron, for instance) and then recursively subdivide each triangular
face, and that for each sphere. This is good enough for my needs. My
problem now is how to deal with with the intersections between the spheres.
I can just remove the points (vertices) that are inside some other sphere,
and that is also good enough. But I don't know how to deal with the seams,
since I would also like to have triangular faces there (of which I'd like
to calculate the area and normal as well). It's not important that the
triangles in the seam actually follow the spherical surface, they can just
"bridge" the "valley" between the spheres, so I don't need additional
vertices, all I need is to create the triangles joining the different
spheres.
Does anyone have a pointer to some algorithm or description on how to do
this? Or maybe some other suggestion?
Thanks in advance.
light_source{9+9*x,1}camera{orthographic look_at(1-y)/4angle 30location
9/4-z*4}light_source{-9*z,1}union{box{.9-z.1+x clipped_by{plane{2+y-4*x
0}}}box{z-y-.1.1+z}box{-.1.1+x}box{.1z-.1}pigment{rgb<.8.2,1>}}//Jellby
Subject: Re: Tessellating a union of spheres
Date: 14 Oct 2006 10:48:33
Message: <4530f8c1$1@news.povray.org>
Jellby nous apporta ses lumieres en ce 12/10/2006 14:10:
> Hi all,
> here can help me.
> spheres.
> Thanks in advance.
Are your objects opaque? If so, you don't have to remove anything, the
intersecting parts will get hiden inside the other object.
If they are transparent, you can use a merge of the different shapes. That way,
if your meshes have a clearly deffined inside(inside vector), it's possible to
remove the parts that are inside the other object.
At the feast of ego everyone leaves hungry.
	Bentley's House of Coffee and Tea, Tucson, AZ
Date: 14 Oct 2006 13:39:50
Message: <lij704-blt.ln1@badulaque.unex.es>
Among other things, Alain saw fit to write:
> way, if your meshes have a clearly deffined inside(inside vector), it's
> possible to remove the parts that are inside the other object.
Thanks for the reply. But as I said, this is not directly related to
POV-Ray, it's not a problem of rendering the object, but of getting a
definition for the surface, and I cannot have intersecting triangles, all
of them have to be in the surface.
I'm considering another method: projecting a tesselated sphere and then
subdividing the mesh when needed... This would the "advantage" of only
giving the outer surface (which is what I ultimately need, I believe).
Date: 14 Oct 2006 16:08:18
Message: <453143b2$1@news.povray.org>
Hash: SHA1
	Maybe the GNU triangulated surface library can help, have you looked?
http://gts.sourceforge.net/
		Jerome
+------------------------- Jerome M. BERGER ---------------------+
|    mailto:jeb### [at] freefr      | ICQ:    238062172            |
|    http://jeberger.free.fr/     | Jabber: jeb### [at] jabberfr   |
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.2.2 (GNU/Linux)
iD8DBQFFMUOxd0kWM4JG3k8RAkgxAJ0bjGoEXvo/tqdwn+26Rmmysiko8ACeJnFi
XjZ0w7ymXdybMAB2rI+zXzg=
=8MpO
-----END PGP SIGNATURE-----
Date: 15 Oct 2006 08:47:14
Message: <9qh904-k8e.ln1@badulaque.unex.es>
Good, I didn't know that... may be worth a deeper study. Thanks!
