POV-Ray : Newsgroups : povray.general : scaling problem using uv_mapping image_pattern Server Time
19 Apr 2026 23:14:16 EDT (-0400)
  scaling problem using uv_mapping image_pattern (Message 1 to 10 of 13)
Subject: scaling problem using uv_mapping image_pattern
Date: 19 Mar 2004 15:16:57
Message: <eric.medlin-7A9A0A.15165719032004@news.povray.org>
I have the following texture attached to a model:
texture{
  normal{ uv_mapping image_pattern{ jpeg "mask.jpg" interpolate 2}
    normal_map{
      [0.5 bump_map{ jpeg "bump.jpg" interpolate 2} scale 0.02]
      [0.5 bozo scale 0.02 bump_size 0.5]
Now the normals maps are scaled to 0.02, if I change the uv_mapping
image_pattern... to just image_pattern the normals maps are no longer
the same scale.  I have to change the normal maps scales to 0.2 to make
it match the uv mapped image pattern.  How is uv_mapping effecting the
scale?
Subject: Re: scaling problem using uv_mapping image_pattern
Date: 22 Mar 2004 12:01:36
Message: <eric.medlin-2340FC.12013022032004@news.povray.org>
In article <eric.medlin-7A9A0A.15165719032004@news.povray.org>,
> texture{
>     normal_map{
> scale?
OK, I think I figured out what it is doing.  You cannot apply uv_mapping
to image_pattern, so it is applying it to the normals causing it to
scale.  If this is correct, then how can I use a uv_mapped mask to
decided where each normal map should be applied?
Date: 22 Mar 2004 15:54:15
Message: <eric.medlin-86B40A.15541422032004@news.povray.org>
In article <eric.medlin-2340FC.12013022032004@news.povray.org>,
> > texture{
> >     normal_map{
> > scale?
This just seems like a bug to me.  It is actually uv mapping the mask to
the object, but it is scaling the normal maps also.  I changed it to a
texture map as a test and it still does the uv mapping for the mask and
scales the pattern.  Why would the pattern be a different scale if the
image pattern is uv mapped or not?  The image pattern should just give a
value for the map not scale whats in the map.  I plan to move this to
povray.bugreports if I or someone else don't find figure this out.
Date: 23 Mar 2004 03:29:28
Message: <405ff568$1@news.povray.org>
In article <eric.medlin-7A9A0A.15165719032004@news.povray.org> , Eric Medlin
> texture{
>     normal_map{
> scale?
I think you are confused about what uv-mapping does and what not.  Please
read section "6.7.7 UV Mapping" of the manual.  As you do not provide a full
scene, nobody cannot help you better because the uv-mapping depends on the
object type as described in the manual.  The image-pattern is always one by
one (by one) unit in space, while your uv-vectors may very well be
different.  Without a small but complete scene or at least knowing the
object type, one cannot help you!
Another thing I don't really understand is why you are using a JPEG
image-pattern ... it does not make much sense to use a JPEG for this at all.
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Mar 2004 09:33:19
Message: <eric.medlin-8CEC8E.09331923032004@news.povray.org>
>     Thorsten
My understanding is uv mapping allows you to map vertex coord. to points
on a texture.  I have used them before in opengl, povray, and different
modeling programs.  A full sample scene is provide below.  By removing
the uv_mapping you will see the scale changes.  I don't think it should
though because the patterns used for the normal maps are a function of
the 3d space they are in and that does not change.  The only think that
changes is the mapping for the image_pattern that tells which normal map
to apply where.  You will need to make a simple mask.tga file for the
image pattern.  I didn't have any reason to use a jpeg.  I just used it.
Why is it a bad choice?  Compress artifacts?  Anyway here is a sample
scene that shows my problem.
light_source {
   <5, 5, -5>, rgb <1, 1, 1>
global_settings {
   assumed_gamma 1.5
   perspective
   location <0, 0, -1>
   sky <0, 1, 0>
   direction <0, 0, 1>
   right <1.3333, 0, 0>
   up <0, 1, 0>
   look_at <0, 0, 0>
box {
   <-0.5, -0.5, -0.5>, <0.5, 0.5, 0.5>
      normal {
         uv_mapping image_pattern{tga "mask.tga"}
         //image_pattern{tga "mask.tga"}
         turbulence <0, 0, 0>
         normal_map {
            [ 0.5 bozo
            scale 0.02
            [ 0.5 quilted
            scale 0.02
         color rgb <1, 1, 1>
   scale 1
   rotate <0, 0, 0>
   translate <0, 0.5, 0.5>
box {
      normal {
         bozo
         scale 0.02
         color rgb <1, 1, 1>
   scale 1
   rotate <0, 0, 0>
   translate <0, -0.5, 0.5>
Date: 23 Mar 2004 10:38:26
Message: <406059f2@news.povray.org>
In article <eric.medlin-8CEC8E.09331923032004@news.povray.org> , Eric Medlin
It does, and for a box it is explained in the manual using a nice image.
Taking a look at it <http://www.povray.org/documentation/images/boxmap.png>
clearly shows how a one by one unit is mapped onto the box, and if you
render your scene with a checker pattern and a 0.1 scale (see scene below),
you will notice that POV-Ray functions exactly as expected.
Yes, if you want a map with precise borders (it appears you want that
because you only have two different types of patterns), then artifacts at
those borders could get into your way.  I would use a grayscale PNG for
this.
    Thorsten
light_source
camera
   perspective
   location <1, 0, -1>
   sky <0, 1, 0>
   direction <0, 0, 1>
   up <0, 1, 0>
   look_at <0, 0, 0>
box
   texture
      normal
         normal_map { [ 0.5 checker ] }
         scale 0.1
      pigment
         color rgb <1, 1, 1>
   scale 1
   rotate <0, 0, 0>
box
   texture
      normal
         checker
         scale 0.1
      pigment
         color rgb <1, 1, 1>
   scale 1
   rotate <0, 0, 0>
Date: 23 Mar 2004 11:48:29
Message: <eric.medlin-E8CB45.11482823032004@news.povray.org>
In article <406059f2@news.povray.org>,
The manual and that image show how uv mapping for a box is done.  I
understand that it should scale the image pattern.  Bu where does it say
it will scale the normal map that uses that image pattern.  Your example
seems to prove my point also.  Without uv mapping you get 10x10 squares
on each side of the box.  That makes perfect since.  Unit box normal
mapped with checker which is 1 unit scaled by 0.1 to give 10 squares on
each side of the 1 unit box.  Now uv map the image pattern.  The image
pattern will be scaled and wrapped around the box like the manual says
and can be seen in the link you provided.  Now I would think that when a
ray intersects the cube it would convert the intersection point on the
cup to uv coords on the image pattern. Then get the value from the image
pattern and look in the normal_map and find the correct normal to apply.
It would then get that normal which in this case by sampling the checker
pattern using the point of intersection on the box.  This point of
intersection would not change if the image pattern is uv mapped or not.
Also note if you don't uv map but change the map type to say sphere or
torus this does not change the normals at all.
Date: 23 Mar 2004 12:00:44
Message: <40606d3c$1@news.povray.org>
In article <eric.medlin-E8CB45.11482823032004@news.povray.org> , Eric Medlin
UV-mapping is a modifier that applies to the normal statement, as explained
in the manual.  The fact that it is set directly in front of the
image-pattern implies nothing.  It still applies to the normal statement,
not the image-pattern statement!  This is exactly like all modifiers in
POV-Ray work.
    Thorsten
Date: 23 Mar 2004 12:28:32
Message: <eric.medlin-37D475.12283223032004@news.povray.org>
In article <40606d3c$1@news.povray.org>,
> POV-Ray work.
I also thought it was applying it to the normal statement only, but it
is applying it to the image pattern statement also.  In my example I
used two normals statments one for below 0.5 and one for above 0.5.
When uv mapping is applied you can clearly see that the image pattern is
being uv mapped.  It is probly applying it to the normals to though
causing the scaling.  Either way I don't see where it says it will apply
it to both.
Date: 23 Mar 2004 12:52:35
Message: <40607963$1@news.povray.org>
In article <eric.medlin-37D475.12283223032004@news.povray.org> , Eric Medlin
>> POV-Ray work.
> it to both.
You are not understanding at all what an image-pattern does!  It does only
define a pattern of the image in the unit cube.  The pattern (the checker
pattern makes this easy to see) together with the normal map is part of the
the surface normal function, and that is then mapped onto the surface (this
is what the uv-mapping modifier specifies) using uv-mapping, which is a
2d-function, rather than specifying 3d-function.  This is exactly like it
works for every pattern and every other statement using patterns in POV-Ray.
In fact, it would not make any sense to just pick arbitrary parts of the
normal statement and use only them for uv-mapping.
Just imagine what would happen if what you seem to be expecting was the case
when using pigments.  The image-map would be uv-mapped and a pigment-map
would not? - This could never work in a predictable manner at all!
    Thorsten
