POV-Ray : Newsgroups : povray.general : Re: shadows produced by area light extremely grainy.. Server Time
31 Dec 2025 23:47:52 EST (-0500)
  Re: shadows produced by area light extremely grainy.. (Message 1 to 8 of 8)
Subject: Re: shadows produced by area light extremely grainy..
Date: 10 Sep 2002 07:17:52
Message: <b3lrnu8coleenehnnedb3anr2jhots4iip@4ax.com>
On Tue, 10 Sep 2002 16:41:07 +0530, "Rahul Pilani" <rah### [at] yahoocom>
wrote:
>is something wrong
try to understand area_light parameters, they are nicely described in
documentation
btw: this group is not for binary posting and there is a special group for
newbie kind questions
ABX
Date: 10 Sep 2002 08:11:42
Message: <3D7DE2A0.5EEE5560@comcast.net>
Well, you were correct about it being due to the area_light parameters, but
he didn't post a binary, he posted a .POV file...
> wrote:
> >is something wrong
> documentation
> ABX
Date: 10 Sep 2002 08:27:20
Message: <3d7de528@news.povray.org>
  But he posted it uuencoded, not in plain text. That is, he posted it in
binary format, not text format.
Date: 10 Sep 2002 08:32:09
Message: <3D7DE76B.6EB01A67@comcast.net>
Sorry, my reader just gave it to me in text - I didn't notice the UUENCODE...
Emory
Date: 10 Sep 2002 15:46:11
Message: <3D7E4D29.170072F@comcast.net>
Rahul,
   Try the following lighting:
light_source
    <-12,12,-3>
    color White
    area_light <3, 0, 0>, <0, 0, 3>, 20,20
    adaptive 3
    //jitter
Note: I've got 400 lightsources, you had 9.  I also don't usually like
the jitter, I'd rather wait for the 'real thing'.  I ran this at
800x600 A0.3 on my AMD Thunderbird 750Mhz - took about 3 hrs 45 min.
Slowest lines ran about 4PPS!  There's just a little bit of banding
around coordinates 265x445, but it's pretty smooth...
I posted it at:
  http://www.untiedmusic.com/dice1.jpg
I generally find lighting is one of the places I always can criticize
about other peoples work (OK, mine too sometimes!).  Render it rough
while you're working on it, but for the finals, very dense area lights
will make a HUGE difference when trying to do these kinds of soft
shadows and edges...even the Sun is not a point source, it's a disc.
You can simulate it with area lights and get MUCH more realistic daylight.
Emory
> wrote:
> >is something wrong
> documentation
> ABX
Date: 11 Sep 2002 05:27:15
Message: <3d7f0c72@news.povray.org>
  When you have enough density in the area light, jittering can get rid
of the banding in the shadows without introducing visible graininess, thus
needing less density and thus rendering faster. (I speak from experience.)
Date: 11 Sep 2002 06:52:28
Message: <3d7f206c@news.povray.org>
Me too, I've tried setting up a grid of point lights, to simulate an
automated grid of area_lights. In cases where you want a very large area of
light, a real grid is best while it illuminates the objects accurately, not
just softening the shadows... But in cases where you need the sun, there is
absolutely no visble gain from setting up a real grid of lights.
In other words, a real grid is good for the blue sky, or a reflecting wall,
or so... Warps idea of a mix between area_lights and a real grid sounds like
a good idea... And speaking of the blue sky, sometimes radiosity provides
this kind of area-light more efficiently than a grid of light_sources.
Good luck,
Hugo
Date: 11 Sep 2002 07:55:06
Message: <3d7f2f1a@news.povray.org>
> a good idea...
  Uh? There must be some confusion here.
  I was speaking merely of one single area_light (when I use the word
"density" I'm talking about how many "point lights" it contains, ie. the
'Size_1' and 'Size_2' parameters used in the documentation).
