POV-Ray : Newsgroups : povray.general : height_field smooth Server Time
13 Nov 2025 05:14:55 EST (-0500)
  height_field smooth (Message 1 to 7 of 7)
Subject: height_field smooth
Date: 11 Dec 2004 00:09:53
Message: <Xns95BC3EEAD2C01raf256com@203.29.75.35>
I have problem with sommthi height fields - they have random black
spots/parts. Problem is connected with smooth (without it it works ok),
with light/shading (because using diffuse 0 ambient 1 helps).
Example:
#if (1)
  height_field {
    png "../media/bmp/hf/gory2.png"
    smooth
    translate <-.5, -40/256 ,-.5>
    scale <70000,10000,70000>
    texture { texLand1Far3 }
#if (1)
  height_field {
    tga "../media/bmp/hf/gory3b.tga"
    smooth
    scale <70000*5,1,70000*5>
    texture { texLand1Far4 }
    scale <1,80000,1>
I think that such problem was disscused here before, wasn't the path
applyed to MegaPov 1.1 nor PovRay 3.6.1 (tested in both, on Win32)?
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: height_field smooth
Date: 11 Dec 2004 02:14:39
Message: <41ba9e5f$1@news.povray.org>
This is a known problem. The "smooth" keyword, especially when resizing the
height_field, may result in unexpected shadow artifacts. One possibility is
to use double_illuminate and/or no_shadow, another is to use an isosurface
or just write a script to calculate the mesh yourself.
IIRC correctly, the problem is due to the calculated normal's and how they
are moved about and scaled when resizing the heightfield, but someone with
more expertise might know the actual, 'correct' bug. ;-)
Tim
"Tim Nikias v2.0"
Date: 11 Dec 2004 04:10:01
Message: <cpedev$1vp$1@chho.imagico.de>
No, such a bug existed but has been fixed in 3.6 IIRC.  AFAIK there are
no known bugs related to heightfields that are not fixed.  Of course
smooth heightfields suffer from the same problems as smooth meshes.
Last updated 23 Sep. 2004 _____./\/^>_*_<^\/\.______
Date: 11 Dec 2004 10:33:04
Message: <41bb1330@news.povray.org>
Christoph Hormann <chr### [at] gmxde> wrote:
> Of course
  And as for those, see sections 2.4.8 and 2.4.9 of the documentation.
Date: 11 Dec 2004 11:47:59
Message: <41bb24bf$1@news.povray.org>
news:41bb1330@news.povray.org...
> > Of course
don't you mean 9.9.1 to 9.9.3?
Marc
Date: 11 Dec 2004 17:28:57
Message: <41bb74a9@news.povray.org>
  There are only three chapters in the current POV-Ray documentation.
Date: 12 Dec 2004 07:56:52
Message: <41bc4014$1@news.povray.org>
news:41bb74a9@news.povray.org...
Sorry, I was talking about POV-Ray 3.5 doc :/
Marc
