POV-Ray : Newsgroups : povray.general : Cannot layer a patterned texture over another Server Time
27 Jul 2025 07:22:36 EDT (-0400)
  Cannot layer a patterned texture over another (Message 1 to 4 of 4)
Subject: Cannot layer a patterned texture over another
Date: 28 Oct 2004 15:46:20
Message: <Xns9590DDE145B7Eraf256com@203.29.75.35>
Is there a way to have texture with texture_map as a layer over another
texture?
Like:
sphere {
  1 10
  texture { pigment { rgb .8 } finish { reflection .4 } }
    slope y
    texture_map { [0 texStain1] [1 texStain1] }
gives:
File Context (5 lines):
Parse Error: Cannot layer a patterned texture over another.
http://www.raf256.com/3d/
Computer Graphics
Subject: Re: Cannot layer a patterned texture over another
Date: 28 Oct 2004 20:38:04
Message: <Xns95911B310EE12raf256com@203.29.75.35>
spa### [at] raf256com news:Xns9590DDE145B7Eraf256com@203.29.75.35
After a bit of reading manual, actually there is a sollution,
2.3.4.12  Limitations Of Special Textures
For example, say we have a layered texture called Speckled_Metal, which
produces a silver metallic surface, and then puts tiny specks of rust all
over it. Then we decide, for a really rusty look, we want to create patches
of concentrated rust, randomly over the surface. The obvious approach is to
create a special texture pattern, with transparency to use as the top
layer. But of course, as we have seen, we would not be able to use that
texture pattern as a layer. We would just generate an error message. The
solution is to turn the problem inside out, and make our layered texture
part of the texture pattern instead, like this
  // This part declares a pigment for use
  // in the rust patch texture pattern
  #declare Rusty = pigment {
    granite
    color_map {
      [ 0 rgb <0.2, 0, 0> ]
      [ 1 Brown ]
    frequency 20
  // And this part applies it
  // Notice that our original layered texture
  // "Speckled_Metal" is now part of the map
  #declare Rust_Patches = texture {
    bozo
    texture_map {
      [ 0.0  pigment {Rusty} ]
      [ 0.75 Speckled_Metal ]
      [ 1.0  Speckled_Metal ]
And the ultimate effect is the same as if we had layered the rust patches
on to the speckled metal anyway.
...sorry for easy question then. And bless manual :)
Computer Graphics
Date: 29 Oct 2004 15:23:23
Message: <418298ab@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
news:Xns95911B310EE12raf256com@203.29.75.35...
Yep - I nearly posted an example (I forgot that this was covered in the
manual). The trouble was that the your example didn't make it entirely clear
what you were *really* trying to do...
Date: 11 Nov 2004 23:24:16
Message: <Xns959F37586C125raf256com@203.29.75.35>
pov### [at] tomandlucouk news:418298ab@news.povray.org
> the manual).
Btw, more complicated example:
#declare GRASS =
    bozo
    texture_map {
      [0.0 textGrass1 ]
      [0.7 textMud1 ]
where textGrass1 and Mud1 already are layered textures.
Now we wont to make it more advanced:
#declare EARTH =
  granite y
  [0 GRASS]
  [1 MOUNTAINS]
How can I achive this result? Because if I understand correctly, then now I
would need to add this granite y to every one component of GRASS and of
MOUNTAINS, with gives several textures that need to be modyfied.
Imho this is quite not-comfortable... perhaps it would be a good idea to
allow "normal" definitions?
Computer Graphics
