POV-Ray : Newsgroups : povray.general : from quad to triangle ...? Server Time
29 Dec 2025 09:39:56 EST (-0500)
  from quad to triangle ...? (Message 1 to 7 of 7)
Subject: from quad to triangle ...?
Date: 25 May 2004 19:18:57
Message: <Xns94F5D63150A8seed7@news.povray.org>
While working on a mesh2 to *obj converter I ran into a problem. It
seems that is important to the obj file and applications that use it how
a quad is dividen in triangles. Or better, in what order the vertices
should be specified, counteclockwise.
D     C
A     B
It wants <A,B,C>, <D,A,C>. Otherwise the normals get messed up, even if
no normals are specified in the obj file. I only have to Poseray to test
this and assume it works the right way.
Is there a consensus on how to specify quads>triangles in the CG world?
Is there a way to figure out from a list of face_indices and vertices in
what way the faces are written?
For POV-Ray it doesn't seem to matter how the faces are arranged, as I
noticed when writing the mesh macros. I there for no specific reason
chose for <A,B,D><A,C,D>. This becomes a mess when converting to *obj :(
Ingo
Subject: Re: from quad to triangle ...?
Date: 25 May 2004 20:01:44
Message: <opr8kydfmfcs6ysw@news.povray.org>
Usually, triangles/quads are specified with their vertices in
counter-clockwise order.
In general, no.
If it's a closed mesh, I suppose you could examine one of the faces to see
which order makes the normal point outward. You could do the same for an
open mesh if you know which way at least one of the normals is supposed to
point.
It matters if you specify an interior texture.
FE
Date: 26 May 2004 07:24:28
Message: <40B47E73.2030007@hotmail.com>
> D     C
> A     B
In fact it does not matter if the vertices are clockwise or
counterclockwise. You should keep the same order as in the quad.
So either <A,B,C> and <A,C,D> or <A,B,D> and <B,C,D> (or any
rotated form of these).
No, unless you assume that the objects have finite volume and you are
willing to reconstruct the whole object and do some inside/outside
tests. Luckily there is no need to know, just keep the same orientation.
It does matter. Normally you do not notice it except if you use
interior_texture. I would not be surprised if there are also problems
if you use interior media in self intersecting objects.
I assume a typo here, these two triangles do not fill the quad.
> Ingo
Date: 26 May 2004 10:37:27
Message: <40b4aba7@news.povray.org>
Note that converting a quad into two triangles may be the most efficient
way if the amount of triangles is concerned, but it's not the best way
if you are texturing the polygon with uv-mapping.
  This image explains why:
http://www.cs.tut.fi/~warp/images/uvproblem.gif
  (And no, that image has no perspective. I bet all my money someone would
comment something about perspective correction (which has nothing to do
with this since there's no perspective projection anywhere).)
  I don't know if there exists any solution to this problem.
Date: 26 May 2004 19:04:32
Message: <40B52279.1BA96716@hotmail.com>
> D     C
> A     B
My New Surface Subdivision Suite contains code that does this.  It was
posted to p.b.scene-files a few days ago.
Basically you look at each edge, and see the way the vertices of that edge
are specified in the faces bordering on that edge.  If they are named in
opposite order, you're cool.
So if one triangle has the vertices A, B, and C, then the other triangle can
have vertices B,A,D, D,B,A, or A,D,B (assuming that A and B are the shared
vertices).
John
John
Date: 26 May 2004 23:09:00
Message: <cjameshuff-22FC6B.22092426052004@news.povray.org>
In article <40B### [at] hotmailcom>,
There are no problems with this. Since media uses intersections to
decide which volume a ray is in, the only requirement is a "well
behaved" object with no holes or stray internal surfaces.
http://tag.povray.org/
Date: 27 May 2004 08:30:58
Message: <40B5DF8A.7000806@hotmail.com>
Am I correct that the 3D equivalent of the even/odd rule is used.
If I have a self intersecting object and I enter the object
again somewhere on the inside, I am supposed to be outside
again? Can I also create hollow objects by simply adding two
meshes? No need to invert the orientation of the inner surface?
That would be much faster then using differences, I guess.
I know I can simply try this myself, only with meshes you always
have a lot of boundary cases with rays exactly hitting a vertex
or a face 'horizontally', and in this case you could hit
two vertices and/or faces at the same time. So I guess asking
you is a more authoritative answer then any testing I can do myself.
