POV-Ray : Newsgroups : povray.general : fu*ing photons and memory managment Server Time
24 Sep 2025 06:51:26 EDT (-0400)
  fu*ing photons and memory managment (Message 1 to 10 of 10)
Subject: fu*ing photons and memory managment
Date: 23 Feb 2004 16:59:34
Message: <Xns9498E9DB12C0Braf256com@203.29.75.35>
It realy is irritating in PovRay 3.6 how it can hang entire system (in 3.5
also, but in 3.6 this effect is stronger).
Just create a simpel scene complicated enought that it will want to use say
1.5 GB memory in shooting photons pahse.
Even on render priority low, it will cause most machines to hang, i.e.
my Athlon 2200 512 RAM WinXP was hanign for about 15 minutes before
responding to alt+f4 and other keys to finaly kill povray application.
In this time no other process could get CPU time, so all internets
connections broke (because server/clients programs was also hanging) and
even after each move of mouse pointer user has to wait 15-20 seconds for
reaction on (GeForce 4 Fx 128 ram card).
Now for some constructive critics / sugestions,
- pov 3.5 did better job with priority settings and was more nice with
sharing thime with other processes
- I suggest adding an ini options:
  +meml 128  memory limit in MB, render will stop with an error if it will
    try to alocate more memory
  +old CPU cycle (80%, 90%) - I suggest it should also be an ini option
  +old priority - it should be also an ini option
- new duty cycle / priority settings - for memory, i.e. that PovRay will
delay for i.e. 1 second every second of memory swapping.
Explanation - if povray will detect that each memory operations took to
much time, say simply allocation of 4 mb buffer tooks almost 1 second, it
will assume that it is causing heavy swapping in system, and will sleep for
several seconds if told to do so, to give user a change to kill povray
- I think that photons related code does not check if STOP button was
pressed (or it does it rearly)
Subject: Re: fu*ing photons and memory managment
Date: 23 Feb 2004 17:07:05
Message: <403a7989$1@news.povray.org>
In article <Xns9498E9DB12C0Braf256com@203.29.75.35>, "Rafal 'Raf256' Maj"
The effect you describe is not something POV-Ray is causing  If your OS is
too stupid to correctly give priority to other processes while one
application requires a lot of swap space, change your OS.  You cannot blame
POV-Ray is your hardware and OS are not up for the scenes you want to
render.  In fact, there is absolutely nothing POV-Ray could do about it
other than refusing to render the scene at all.  Sorry!
    Thorsten
e-mail: tho### [at] trfde
Date: 23 Feb 2004 17:16:39
Message: <403a7bc7$1@news.povray.org>
Try one of the systems below.  They will not exhibt any of the problems you
are describing, even if your scene takes 20 GB of memory:
<http://www-1.ibm.com/servers/eserver/pseries/hardware/workstations/>
I am serious, this is no joke.  If you seriously have scenes the size you
are talking about on a regular basis, these systems will be a good solution.
    Thorsten
Date: 23 Feb 2004 17:29:35
Message: <Xns9498EEF24B5D0raf256com@203.29.75.35>
tho### [at] trfde news:403a7989$1@news.povray.org
>> (in 3.5 also, but in 3.6 this effect is stronger).
> OS is too stupid to correctly give priority to other processes while
> one application requires a lot of swap space, change your OS.  You
> cannot blame POV-Ray is your hardware and OS are not up for the scenes
> you want to render.  In fact, there is absolutely nothing POV-Ray
> could do about it other than refusing to render the scene at all.
> Sorry!
Yes, I agree that OS should handle this situation better.
But - PovRay could take this into accound and allow an option to correct
stupid OS behavior.
Setting hard memory limit could be step one, and I guess it's realy easy to
implement. It will just refuse to render, but it will save stress frome
users who set to high quality/photons (by mistate) or mis-calculated needed
memory limit.
Second thing - detecting to stron swapping and forcing sleeping then also
is something that can be done probably?
I'll try to implement hard memory limit, can I download code of pov 3.6 for
VC++? If I'll implement this in next 2 weeks (much real-life) will it has
chance of beeing in final 3.6?
Btw my friend with start to play with Pov, find simillar problem very
iritating,
#local I=1; While (I<1000)
  box { ... }
#local I=I-1;  #end
this infine loop (made by mistake -1 instead of +1) wil cause simmilar
problems, and adding memory limit, and more often check if STOP button was
pressed in POV_ALLOC (afair) parsing, and photons code will help
Date: 23 Feb 2004 22:24:14
Message: <403AC47D.AFD50154@tag.povray.org>
The code for v3.6 is not available to the public.
Ken Tyler - POV-Ray Technical Assistance Group
Date: 24 Feb 2004 04:31:03
Message: <pq3m30ldlcikqc9kfo4mm1tljdiqefkqji@4ax.com>
On 23 Feb 2004 16:59:34 -0500, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> also
In the next thread you said you are able to fix it. Sources of 3.5 are
available, you claimed you are programmer. What do you need more ?
There is povray.beta-test group. Rules for reporting problems are clear. There
is a warning about risk using beta versions. Please, read second part of
second sentence of POV-Ray 3.6 beta announcement at http://www.povray.org/
Thanks, constructive critics are welcome.
Minimal sample + statistics comparison 3.5 vs 3.6 from the same machine ?
My personal opinion is that POV-Ray is not for dummies: if you type +W8000
+H6000 then you know it will be large image, when you type
media{}/isosurface{}/parametrics{} then you know it will slow down, when you
turn on photons you should be ready for memory/CPU usage. Moreover "6.10.2
Using Photon Mapping in Your Scene" describes techinics about limiting number
of photons aka memory usage in photons{}.
where is explanation what it does ?
How do you want to fix memory swapping in POV-Ray for Windows if you do not
understand that it is not a task of POV-Ray ?
IIRC current beta expires in middle of March. Until then can you write
universal function based on 3.5 sources which recognizes than next line of
code takes 4 mb ?
That's the only sensible sentence if real. Please provide (povray.beta-test)
script so others could confirm it.
ABX
Date: 24 Feb 2004 06:25:54
Message: <403b34c2$1@news.povray.org>
try using alt+g instead of pressing the button in the user interface. i
had the experience that the response was much faster, sometimes the
button didn't respond until the render was finished. i guess the reason
is that the interface has a lower priority.
bye,
	Marc
and god said: let there be a light_source { location SUN look_at EARTH,
rgb SUNLIGHT }
Date: 24 Feb 2004 11:07:24
Message: <Xns9499AE242E970raf256com@203.29.75.35>
abx### [at] abxartpl news:pq3m30ldlcikqc9kfo4mm1tljdiqefkqji@4ax.com
Time :) *If* no new jobs / personal life probles will apear I can start in
about week from now.
> +W8000 +H6000 then you know it will be large image, when you type
But if You have just  photons { spacing 0.001 } it is not quite easy to
calculate memory usage. OFcourse You can use i.e.  1.0  0.5 0.25 assuming
it will tke (AFAIR) x2 more memory (x3 for modeia), but...
> techinics about limiting number of photons aka memory usage in
> photons{}.
Well, right... but memory limit imho can be still usefull.
I ment "old" (current in 3.5 and 3.6) options.
>> will delay for i.e. 1 second every second of memory swapping.
> do not understand that it is not a task of POV-Ray ?
Ofcourse I do understand it is not responsibility of Pov, but users will be
heapy if it will do something extra.
> line of code takes 4 mb ?
There was function linke afir POV_ALLOC that allocated memory and btw.
calculates peek usage ustatistics. Changing it should help, like
void* pov_alloc_function( size_t size) {
  if ( statistics_memory_allocated += size  > max_mem_size )
    povray_error(...)
  else malloc( ... )
Date: 24 Feb 2004 11:45:54
Message: <403b7fc2$1@news.povray.org>
One day......   I'll spend 20.000 euro's for something like that or better
:P
Date: 24 Feb 2004 11:47:44
Message: <h0um309hcvs0a8dk76lgeo8fnpqtgo5b1e@4ax.com>
On 24 Feb 2004 11:07:24 -0500, "Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote:
> > photons{}.
How, if you just said "it is not quite easy to calculate memory"?
If you can't calculate memory usage yourself, how can you choose value for
memory limit for option ??????
3.6 threading is almost completly rewritten. It's simply impossible.
Sure, just give us a reference to msdn where possibilities of installing
callback function for memory managers of all versions of Windowses are
designed. Or better, give it to yourself and provide ready solution.
How does it affects storing local variables ?
Really, if you do not want memory to swap, just turn swap file off. Otherwise
such limit is useless since that's not management of POV-Ray but OS. In other
words if you have 512 MB RAM, render which uses 300 MB, 10MB of PDF in Acrobat
Reader, Open Office large document and a few other things, your memory still
will be swaped. You are free to install memory usage monitor (and usually one
is already within Windowses) to verify amount of memory POV-Ray used and you
can kill POV-Ray then.
Again, the only valid point (which does not excuse "fu*ing" word in the world
of volunteers) is that perhaps photons stuff does not leave thread with
photons calculation often enough. If you think it is the case please provide
(follow-up set) script so somebody could confirm your observation. Not every
photon usage can be affected by such issue.
Before next "bug report" please read:
  Date: Wed, 28 Jan 2004 06:39:19 -0800
  Newsgroups: povray.beta-test
  Subject: Beta-test Bug Report Requirements
ABX
