POV-Ray : Newsgroups : povray.general : Light source performance impact problems Server Time
31 Mar 2026 02:57:57 EDT (-0400)
  Light source performance impact problems (Message 1 to 6 of 6)
Subject: Light source performance impact problems
Date: 3 Jan 2004 17:10:38
Message: <Xns9465AF0B848F7cybermans.pov.posts.@204.213.191.226>
I have a scene I have been working on and there are a large number of light
sources in it, This appears to be a real problem.  Is there a way to
'eliminate' extra sources that won't be visiable using the fade_distance
and fade_power from the light source? (sort of like fog only for  light
source 'consideration')
I just don't want to wait 4 hours for a 320x240 test shot on a 2.2Ghz
machine. Upgrading is obviously a silly solution because all things
considered it won't do anything useful (such as dramatically reduce
rendering times).
Should I make a 'IF' statement for creating the light sources based on the
camera location? (they have a quick fall off so they look real.)
Another question is, this scene is ment to be in a dark place with lots of
'torches' 'braziers' giving illumination throughout the scene.  Is it
possible to use 'black' fog to fade parts of the scene 'unseen' etc?
The scene is basically a large flat plaza with many columns the columns
have light sources about there bases.
Suggestions?
Commentaries?
Questions regarding how it's coded?
I automatically generate the light sources with the columns. The braziers
are seperate objects from the light sources. For objects greater than a
certain distance I assume these details are not visable including the light
source (see fade settings above). So is this the right way to handle this?
Do a 'distance' calculation, from the camera to the light source/object. If
it's greater than XXX don't create them. I'm thinking of doing the same
with the columns (I have 15000 of those in the scene I'm still tweaking
that to be honest.) Only with the columns I plan on switching to a cylinder
or a prism to simplify the look. Columns are made up of 10 sections that
are CSG made. Thus they are quite complex and the result object IMHO is a
waste of data space and likely tracing time.
My problem at the moment is I have some 'glowing' crystals of which there
are 40 some, no light sources on the columns and a parallel area light. It
seems that puting the light sources in the crystals slows things down
immensly. Thoughts?
Subject: Re: Light source performance impact problems
Date: 3 Jan 2004 18:13:35
Message: <Xns9466207D2E17raf256com@204.213.191.226>
cyb### [at] socketnet
news:Xns9465AF0B848F7cybermans.pov.posts.@204.213.191.226
> the camera location? (they have a quick fall off so they look real.)
Yes, it's quite good work-around
> Is it possible to use 'black' fog to fade parts of the scene 'unseen'
> etc?
I use fog sometimes in simmilar ocasions.
> Suggestions?
> Commentaries?
I had simmilar problem (scene wih 100-200 small fast-fading lights).
It would be a good ida IMHO to add
light_source {
  cut_off [distance n.n | lightness n.n]
and when distance between a point and light is > n.n then this light source
will not be taken into account when calculating color in this point (or in
shadow calculations). In lightness n.n version the distance D is calculated
bade on minimal brightes.
Date: 3 Jan 2004 18:23:02
Message: <cjameshuff-2FF7DF.18230003012004@netplex.aussie.org>
In article <Xns9465AF0B848F7cybermans.pov.posts.@204.213.191.226>,
No, though this probably should be added...
Why don't you try it?
Yes, it's possible. The fog won't be illuminated by the lights
though...for that, you need media.
> that to be honest.)
So you have N*15000 light sources, with N lights per column? You aren't
very clear about this. If so, you are likely getting hammered by the
light buffers. The light buffers are actually an optimization feature,
but can really slow things down on scenes with many light sources. This
many light sources are going to be slow whatever you do, though.
If the columns are complex and identical, you might want to consider
using meshes.
> immensly. Thoughts?
For a glowing crystal, you might have better luck with emitting media
and radiosity. The same may go for the column lights...radiosity can
handle huge numbers of lights with no trouble. A room lit with 10000
ambient spheres using radiosity will render a lot faster than a room
with 10000 point light sources. It doesn't do well with small light
sources though.
http://tag.povray.org/
Date: 3 Jan 2004 18:45:08
Message: <3ff75404@news.povray.org>
"Rafal 'Raf256' Maj" <spa### [at] raf256com> wrote in message
> It would be a good idea IMHO to add
> light_source {
Prior to version 3.5 a light's color value had to be above a certain amount
before it could appear, otherwise it didn't emit any light rays IIRC.
Considering how light_source has so much impact on the rendering times this
idea of constraining its realm might be a great thing. Especially, as
Chistopher pointed out, if shadow creation were limited to a certain
distance; as measured from camera or the light, or both.
Bob H.
http://www.3digitaleyes.com
Date: 3 Jan 2004 19:50:29
Message: <cjameshuff-03DCF5.19502803012004@netplex.aussie.org>
In article <3ff75404@news.povray.org>,
To be precise, what I was talking about was ignoring the light if the
attenuated illumination from it dropped below the ADC bailout or some
new threshold value. Shadow testing would not be done in this case,
which should speed up things quite nicely.
Date: 4 Jan 2004 17:20:32
Message: <3ff891b0@news.povray.org>
news:Xns9465AF0B848F7cybermans.pov.posts.@204.213.191.226...
> Suggestions?
> Commentaries?
Well, 15000 lights is a lot of lights. I remember doing similar scenes and
running into problems with a few hundreds of them... At least if you have
light buffer issues (very long parsing time) you can turn them off with -UL
but it won't help with the render time itself.
Still, the obvious question is, are all these lights really necessary ?
Wouldn't it be possible to fake the majority of them with (fast) emitting
media or even with clever texturing on the columns, leaving the actual
lighting to a few ones? With many lighting sources, the contribution of each
one is really minimal and unless you plan a very large render most won't be
seen at all. In any case, if you really need many lights, try using
spotlights instead of point lights, it should be faster.
> immensly.
Putting lights into transparent objects certainly requires further
calculations so it's not unexpected. Again the question is whether this
could be faked.
G.
http://www.oyonale.com
- Graphic experiments
- Posters
