POV-Ray : Newsgroups : povray.general : "scale" usagage observation Server Time
22 Feb 2026 05:56:28 EST (-0500)
  "scale" usagage observation (Message 1 to 10 of 10)
Subject: "scale" usagage observation
Date: 10 Sep 2003 22:26:30
Message: <Xns93F2E3DCD64E5POVMIKA@204.213.191.226>
Hi folks!
I've seen this kind of syntax here and there:
    	scale x + z + y*0.03
I don't like it as it is not clear what it does without having to analyse
it for a moment
From what I gathered and from normal operator precedence this is the same
as:
    	scale x*1 + z*1 + y*0.03
    	    	or
    	scale <1,0.03,1>
I figured the syntax not so clear syntax is to avoid the "cannot scale by
0 warning" when one uses this syntax:
    	scale y*0.03
I'm not saying it's good or bad, I just don't like when I have to ponder
on such a simple statement in order to figure out what it's doing.
Would it not be wise for the scale statement to assume 1 instead of 0 for
those vectors that are not specified.
I may not realise what other impact this may have on the system as a
whole.
Just thought I would mention it.
Thanks
Marc Champagne
marcch.AT.videotron.DOT.ca
Montreal, CANADA
Subject: Re: "scale" usagage observation
Date: 10 Sep 2003 23:45:30
Message: <3f5fefda$1@news.povray.org>
Not without giving a warning, as it does, IMO. Scaling by zero is illegal
and the program should not fail to let the user know that they've done
something wrong.
 - Slime
 [ http://www.slimeland.com/ ]
Date: 11 Sep 2003 05:09:34
Message: <3f603bce$1@news.povray.org>
"Marc Champagne" <marcch.AT.videotron.DOT.ca> wrote in message
A common request. I *think* the problem is that If the default for an
unspecified vector was changed to 1, this would have an impact on translate and
rotate vectors (where defaulting to 0 is desired).
In the end, you are only getting a warning, which you may ignore.
Date: 11 Sep 2003 08:15:07
Message: <3f60674b@news.povray.org>
  Certainly not. That would seriously break things like translate x*5
or box { 0,1 }
  It could be thinkable that the 'scale' command would be a special
case, where an element value of 0 is converted to 1. However, this is
what it already does. The only question is whether the warning is
relevant or not.
Date: 11 Sep 2003 08:16:53
Message: <Xns93F353F8A9442newsATctldirectDORco@204.213.191.226>
"Tom Melly" <tom### [at] tomandlucouk> wrote in
news:3f603bce$1@news.povray.org:
> news:Xns### [at] 204213191226...
>> for those vectors that are not specified.
> translate and rotate vectors (where defaulting to 0 is desired).
Defaulting to 1 would only be for scale of course as it ends up being 1
in the end anyways...
Date: 11 Sep 2003 08:18:30
Message: <Xns93F3543EF2033newsATctldirectDORco@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3f60674b@news.povray.org:
> or box { 0,1 }
I don't mention translate or box do I!
> relevant or not.
Bingo
Date: 11 Sep 2003 08:59:29
Message: <3f6071b1$1@news.povray.org>
Well, relying on default values for just
specific functions (in this case, defaulting
to 1 just for scale) is quiet unpleasing
IMHO. This way, I can always expect
that 2 = <2,2,2>, and x*2 is <2,0,0>.
If you begin with scale to do
x*2 = <2,1,1>, then where do you want
to stop for "special default cases"?
Its just a useful warning after all! There
are simple rules for floats and vectors
and they simply apply everywhere, which
makes them easy to handle and interpret,
even in obfuscated code.
So, IMHO, let the warning be.
Tim Nikias v2.0
Email: no_lights (@) digitaltwilight.de
> > or box { 0,1 }
> > relevant or not.
> Bingo
Version: 6.0.515 / Virus Database: 313 - Release Date: 01.09.2003
Date: 11 Sep 2003 12:32:47
Message: <3f60a3af@news.povray.org>
> to assume 1 instead of 0 for those vectors
The following may sound like nitpicking, but I think it's worth
mentioning.
When you scale by x*2 then you are not just specifying the x-scaling,
you are also specifying the y-scaling and z-scaling. These you have set
to 0.
This is not because 0 is any kind of default. It is simply because the
meaning of the build-in variable "x" is exactly <1,0,0>. That is, "x" is
a full vector in itself, not some kind of float that only applies to the
x value. So when you are specifying scale x*2 then it is exactly the
same as specifying scale <1,0,0>*2 and this is a full vector definition,
without any defaults being assumed.
I still think it's a good idea that POV-Ray corrects the incorrect
scaling specifications, but the warning definitely should be there.
My main point I guess, is to make clear that no default are being
assumed, since there are no vectors that are "not being specified", and
thus it doesn't make sense to request that the defaults should be
different.
Rune
rune|vision:  http://runevision.com **updated Jul 25**
POV-Ray Ring: http://webring.povray.co.uk
Date: 11 Sep 2003 18:02:48
Message: <Xns93F3B728E788CPOVMIKA@204.213.191.226>
"Rune" <run### [at] runevisioncom> wrote in news:3f60a3af@news.povray.org:
> mentioning.
> to 0.
> different.
Well your nitpicking :) makes a whole lot of sense, I better understand
now!
What frustrates me the most are sequences that are not so obvious without
mentaly breaking it down, such as
    	scale x * 2 + y + 15 * z
I still believe for this case that
    	scale (x * 2) + (y * 1) + (15 * z)
or even better
    	scale <2,1,15>
would be faster to digest by humans (more readable)
Thanks
Marc Champagne
Montreal, CANADA
Date: 11 Sep 2003 20:32:49
Message: <3f611431$1@news.povray.org>
Program ended abnormally on 11/09/2003 18:02, Due to a catastrophic Marc
Champagne error:
> or even better
>     	scale <2,1,15>
Absolutely.  I do not think there are lots of people who will write:
      scale x*2 + y + 15*z
as it does nothing more that waste characters and slow down the parser for a few
cycles.  Statements like this will only show up (in my pov scenes, at least) in
the development phase when I'm usually not thinking straight, or inside my .sig.
I have had to use complex statements to generate scale, translate or rotate
vectors, but I usually try to make it easier to read and understand 6 months
down the road.
