POV-Ray : Newsgroups : povray.general : Exporting to Povray from Wings3D Server Time
5 Oct 2024 02:16:13 EDT (-0400)
  Exporting to Povray from Wings3D (Message 1 to 5 of 5)
Subject: Exporting to Povray from Wings3D
Date: 11 Jul 2003 11:08:53
Message: <Xns93B57167CCF08None@204.213.191.226>
Hello, I've downloaded the Wings3D modeller along with the Povray export
plug-in.  When I run Wings3D, I don't see an export option for Povray,
although there are some for .mdl and .vrml.  The is also a plugin
preference menu for Povray.  But I can't figure how to export and object
from Wings3D to a Povray .pov (or .inc) file?  What am I doing wrong?
BTW I've downloaded the latest Wings3D (wings-0.98.11b) and the latest
WingsPov plugin (wingspov-0.98.11a_b).
Thanks.
Subject: Re: Exporting to Povray from Wings3D
Date: 11 Jul 2003 11:28:58
Message: <3f0ed7ba@news.povray.org>
You mean, there is a menu with preferences for POV-Ray export? You can
export from there.
I'm a few versions behind you, but if Wings3D still works like my version
does, you can click on the menu-text "POV-Ray 3.5" to export directly  OR
you can click on the button right next to the text, for adjusting the
preferences - as you say, you have tried.. It should be rather simple.
If somehow these options not showing up, make sure you've put the
export-plugin in the right directory, and that the version corresponds with
the Wings3D version. Even a slight difference in version is currently enough
to mess it up.
Hugo
Date: 11 Jul 2003 18:26:35
Message: <3f0f399b$1@news.povray.org>
I find it's easier to export to a wavefront .obj file then use PoseRay to
convert that to a pov file. It's a bit of hassle but PoseRay has better options.
Tek
http://www.evilsuperbrain.com
"None" <Non### [at] onca> wrote in message
> Thanks.
Date: 11 Jul 2003 19:00:03
Message: <Xns93B5C149DD98DNone@204.213.191.226>
"Hugo Asm" <hua### [at] post3teledk> wrote in news:3f0ed7ba@news.povray.org:
> export from there.
Thanks for replying.  All I had was under the "Edit" menu, a "Plugins
Preferences" item with a "Povray" sub-item.  When I saw your reply I tried
messing with this and it looks like the problem was that the first Povray
option was set to "Automatic Dialogs", when I switched this to "Enabled
Dialogs", then a new Povray export option appeared under the "File->
Export" menu.  Now it works and this new menu item also has a little box
next to it with Povray export options.  So, you lead me in the right
direction even though it wasn't direct.  Thanks.
Date: 11 Jul 2003 19:01:53
Message: <Xns93B5C1990DAECNone@204.213.191.226>
"Tek" <tek### [at] evilsuperbraincom> wrote in news:3f0f399b$1@news.povray.org:
> to convert that to a pov file. It's a bit of hassle but PoseRay has
> better options.
Thanks for the tip!  I would have never thought of doing that since I
assumed PoseRay would only be useful if I had Poser (never bothered to
inform myself).  Great, I'll try that as well.
