POV-Ray : Newsgroups : povray.general : photons + media Server Time
24 Nov 2025 13:03:09 EST (-0500)
  photons + media (Message 1 to 10 of 16)
Subject: photons + media
Date: 24 Feb 2003 15:06:46
Message: <Xns932CD71A953D1raf256com@204.213.191.226>
I have a little problem - how can I show photons (using media?)
My scene (will be posted in .b.i in a minute) looks like :
    *  Y=0 spot light
    ^    1 light
   / \   2 light
  =====  3 glass = box+ior+normal + photons{refraction on}
  //|\\  4 photons
 ///|\\\ 5 photons
-------- 6 photons stored on floor (collect=on)
Scattering media is everywhere in scene (global).
Problem is, that media shows light in Y=1,2, BUT photons in Y=4,5 are NOT
showned in media - this photons do NOT light scattering media. In area 4,5
media acts exacly as the box would be totaly solid and as this part of
media was in shadow.
Photons are correcly shown on floor (Y=6).
In global_settings i use
 radiosity { media on }
 photons { count 100*1000  media 100  }
and glass box is :
  pigment { rgbf .99 }
  finish { reflection .2 specular .9 roughness 0.02 }
  interior { ior 1.3 }
  normal { bozo scale .4 }
  photons { refraction on  target on }
What can be wrong ?
Second box (on image in b.i) has in addition :
  dispersion 1.04 dispersion_samples 20
Subject: Re: photons + media
Date: 24 Feb 2003 15:08:32
Message: <Xns932CD767855AFraf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226
and ofcourse, my media settings :
// --- media ---
media {
  scattering { 1 rgb .3 extinction .1 }
  samples 1000
full scene source will be posted in a minute
Date: 24 Feb 2003 17:27:59
Message: <3e5a9c6f@news.povray.org>
There are several things I'd look at:
1. Don't use count. IMHO its more intuitive to use spacing,
 as decreased values lead to predictable better results.Also,
your count seems way too low, I always get several
hundreds of thousand, sometimes millions of photons for
decent results, and it should be higher cause you're even spreading
some across the media.
2. Set max_trace_level for the photons higher, they might
be too low (I think 5 is default)
3. Global-Media doesn't work very nice AFAIK, its better
to use containment. Since its all happening in a box, why don't
you use a box?
I'll download your scene-file and see what I can do.
Tim
Tim Nikias
Email: Tim### [at] gmxde
> // --- media ---
> media {
>   samples 1000
> #macro g(U,V)(.4*abs(sin(9*sqrt(pow(x-U,2)+pow(y-V,2))))*pow(1-min(1,(sqrt(
> pow(x-U,2)+pow(y-V,2))*.3)),2)+.9)#end#macro p(c)#if(c>1)#local l=mod(c,100
> );g(2*div(l,10)-8,2*mod(l,10)-8)*p(div(c,100))#else 1#end#end light_source{
> y 2}sphere{z*20 9pigment{function{p(26252423)*p(36455644)*p(66656463)}}}//M
Date: 24 Feb 2003 17:53:14
Message: <3e5aa25a$1@news.povray.org>
Okay, here goes:
1. Make that glass use rgbt not rgbf. f=filter, so if you
set rgbf .99 just about every piece of light is filtered
by .99, so that leaves you .01 of the original amount of light.
2. Get rid of those sphere which you've placed ON the
lightsources. Somehow they block the media-photons,
even though caustics work with them.
3. Place your media inside the inverse box at the
beginning, and don't forget to remove that inverse
and replace it with hollow (since we want to be INSIDE
a media-filled box).
Thats about it. Tweaking those settings is up to you, but
it sure gets hell...
Tim
Tim Nikias
Date: 24 Feb 2003 18:49:13
Message: <cjameshuff-D66808.18452824022003@netplex.aussie.org>
In article <3e5aa25a$1@news.povray.org>,
 "Tim Nikias" <tim### [at] gmxde> wrote:
> Okay, here goes:
I think you need to go review at the behavior of filtering. It doesn't
behave anything like you describe.
rgbf  is the same as rgbf < 0.99, 0.99, 0.99, 0.99>, which is nearly
perfectly transparent. This is not the problem.
Rafal: look at the optics.pov demo scene.
http://tag.povray.org/
Date: 24 Feb 2003 18:57:24
Message: <Xns932DA11DB213raf256com@204.213.191.226>
Christopher James Huff <cja### [at] earthlinknet> wrote in
news:cja### [at] netplexaussieorg
Ok, and in btw - minimal scene to reproduce my problem :
camera { location <0,9,-8> look_at 0 angle 70 }
#declare UseMedia = 1; // <====
#declare UsePhotons = 1; // <====
#if (UsePhotons) global_settings { photons { spacing .005 media 100 } } #end
light_source { y*5 rgb .5 shadowless } // fill-light
plane { y,0.01 pigment { checker rgb .7 rgb .8 }  finish { diffuse .6 } }
light_source { // spot
  <0,9,0> rgb 1 spotlight  point_at <0,0,0>
  radius  10 falloff 10+10 tightness 3
box { // glass box
  -1,+1 scale 2*<1,.05,1> rotate -y*20 translate <2,3,0>
  pigment { rgbt 1 } // <---
  interior { ior 1.5 }  normal { bozo .5 scale .4 }
  photons { refraction on  target on }  hollow
#if (UseMedia) // media - dust box
box {
  <-5,-1,-5>, <+5,8,+5>
  interior { media {
      samples 100
      scattering { 1 rgb .1 extinction 0 }
  hollow // <---
Using media is ok, using photons is ok, but using them both gives problem.
Date: 24 Feb 2003 20:03:59
Message: <3e5ac0ff$1@news.povray.org>
Hm, you're right. I somehow messed something up
with that "subtractive transparency" talk in the docs.
Tim Nikias
Date: 24 Feb 2003 20:26:32
Message: <cjameshuff-F7D95F.20224924022003@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
> box {
>   interior { media {
>       samples 100
>   hollow // <---
> #end
Try adding a photon block with pass_through, if that doesn't work try
making it a photon target. Or maybe the media itself is off...
Date: 25 Feb 2003 04:34:09
Message: <3e5b3891@news.povray.org>
"Tim Nikias" <tim### [at] gmxde> wrote in message
news:3e5ac0ff$1@news.povray.org...
I'm not sure that section of the docs is wrong, but it certainly is
misleading...
Date: 25 Feb 2003 05:47:59
Message: <3e5b49df$1@news.povray.org>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in message
Dunno if it's a bug or not, but you can fix it by making your media container a
bit taller so that the spotlight is inside it.
So, instead of:
> box {
try
> box {
>   <-5,-1,-5>, <+5,9.5,+5>
... and watch those render times slow to a crawl (must be working then ;)
BTW I don't think your glass box needs the hollow keyword.
