POV-Ray : Newsgroups : povray.general : Color add Server Time
22 Apr 2026 01:52:54 EDT (-0400)
  Color add (Message 1 to 10 of 19)
Subject: Color add
Date: 3 Jan 2003 16:23:31
Message: <Xns92F8E38A5EB08raf256com@204.213.191.226>
How can I make a texture with pigment of following components :
  red = function { FA(x,y,z) }
green = function { FB(x,y,z) }
 blue = function { FC(x,y,z) }
The problem is, IMHO that there is no ADDITIVE filter in color.
I tryed to use 3 texture layers but I don't know how to define colormaps ?
texture { pigment{function{..}} color_map{[0 rgb 0][1 rgb <1,0,0>]} }
texture { pigment{function{..}} color_map{[0 rgb 0][1 rgb <0,1,0>]} }
texture { pigment{function{..}} color_map{[0 rgb 0][1 rgb <0,0,1>]} }
using filter and/or transmit didn't work as I expected. How set them to get
result :
if i.e. texture A pigment    = <1.0 ,0.5, 0.0>
    and texture B pigment    = <0.1 ,0.1, 0.7>
then final pigment for point = <1.1, 0.6, 0.7>
Subject: Re: Color add
Date: 3 Jan 2003 16:33:15
Message: <cjameshuff-018002.16291203012003@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
texture {average
    texture_map {
        [1 pigment{function{..} color_map{[0 rgb 0][1 rgb < 3, 0, 0>]}}
        [1 pigment{function{..} color_map{[0 rgb 0][1 rgb < 0, 3, 0>]}}
        [1 pigment{function{..} color_map{[0 rgb 0][1 rgb < 0, 0, 3>]}}
http://tag.povray.org/
Date: 3 Jan 2003 16:36:55
Message: <3e160277@news.povray.org>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> schrieb im Newsbeitrag
You try to use keywords as functionnames here that won't work IMO. You
should always use a capital letter to avoid that.
Does
#declare Red= function { FA(x,y,z) }
#declare Green = function { FB(x,y,z) }
#declare  Blue = function { FC(x,y,z)
 pigment{ rgb <Red, Green, Blue>}
not work? Or do I miss something obvious?
Marc-Hendrik
Date: 3 Jan 2003 16:45:02
Message: <3E16045E.23919376@gmx.de>
Christopher James Huff wrote:
> texture {average
>     texture_map {
That definitely won't work.  Better:
texture {average
  texture_map {
    [1 pigment{function{..} color_map{[0 rgb 0][1 rgb < 3, 0, 0>]}} ]
    [1 pigment{function{..} color_map{[0 rgb 0][1 rgb < 0, 3, 0>]}} ]
    [1 pigment{function{..} color_map{[0 rgb 0][1 rgb < 0, 0, 3>]}} ]
Even better:
    average
    pigment_map {
      [1 function{..} color_map{[0 rgb 0][1 rgb < 3, 0, 0>]} ]
      [1 function{..} color_map{[0 rgb 0][1 rgb < 0, 3, 0>]} ]
      [1 function{..} color_map{[0 rgb 0][1 rgb < 0, 0, 3>]} ]
Last updated 31 Dec. 2002 _____./\/^>_*_<^\/\.______
Date: 3 Jan 2003 17:08:58
Message: <Xns92F8EB3F9F6F2raf256com@204.213.191.226>
"Marc-Hendrik Bremer" <Mar### [at] t-onlinede> wrote in
news:3e160277@news.povray.org
> Does
I don't want
pigment { rgb ... }
  but
pigment { function { .... } color_map ...
Date: 3 Jan 2003 17:27:46
Message: <3e160e62@news.povray.org>
> > Does
> I don't want
> pigment { rgb ... }
>   but
It doesn't work anyway. It's been a while since my last serious poving -
forgot a lot allready.
Marc-Hendrik
Date: 3 Jan 2003 17:34:16
Message: <Xns92F8EF8995540raf256com@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3E16045E.23919376@gmx.de
Another colors question:
I have i.e. sphere rgb <1,0,0> behind a box rgb <0,1,0> and all this behind
a wall rgb .3
Now I want color of pixel, that is on render output "inside" all 3 shapes
(inside there projection on view port exacly) to have color :
<1,0,0> + <0,1,0> + .3 = <1.3,1.3,0.3>
so - box and wall will act just like "particle", in OGL it would be
"additive-alpha" afair
Date: 3 Jan 2003 19:20:44
Message: <3e1628dc@news.povray.org>
POV-Ray doesn't have an additive alpha feature. All it has for alpha is
transparency and filtering. Additive effects can, however, be created with
emission media.
Nonetheless, I think an additive-alpha feature would be a good thing for a
patch...
 - Slime
[ http://www.slimeland.com/ ]
Date: 3 Jan 2003 19:33:20
Message: <Xns92F9F95DAD19raf256com@204.213.191.226>
"Slime" <slm### [at] slimelandcom> wrote in news:3e1628dc@news.povray.org
> is transparency and filtering. Additive effects can, however, be
> created with emission media.
> for a patch...
I agree, and it's very easy to implement imho.
Date: 3 Jan 2003 20:24:02
Message: <3e1637b2@news.povray.org>
> patch...
  IMHO it should be more generic than just a specific "additive-alpha"
filter. This way you could get many other type of filters for free.
