POV-Ray : Newsgroups : povray.general : material_map Server Time
12 Jan 2026 00:49:16 EST (-0500)
  material_map (Message 1 to 4 of 4)
Subject: material_map
Date: 30 Dec 2002 06:09:35
Message: <Xns92F47B6B6CB33raf256com@204.213.191.226>
Can I scale only image that is used in material_map leaving all used
textures unchanged ?
I.e. I have
box { ...
    material_map { png "..."
      texture { A }
      texture { B }
textures A & B are i.e. bozo. And now I want to streach image to cover
entire box but WITHOUT changing scale of texture A and B I have to do :
  texture { #local S=<2,3,1>;
      texture { A scale 1/S }
      texture { B scale 1/S }
    scale S
and if I want to use other transforms - it gets more complicated and little
uncomfortable IMHO
Subject: Re: material_map
Date: 30 Dec 2002 06:57:42
Message: <3e1034b6$1@news.povray.org>
You could declare your transform and use the transform{MyTransform
inverse}syntax in child textures. I seem to remember there is a keyword that
makes the child texture independant from the parent's modifiers, but I could
not find it. Maybe it was a MegaPov feature ?
Povingly,
Philippe
Date: 30 Dec 2002 07:04:19
Message: <3e103643@news.povray.org>
You could use an image_pattern inside a pigment_pattern instead, it can
essentially do everything a material_map can, but it is more versatile.
Something like this should work:
  pigment_pattern {
    image_pattern { png "img.png" /*...*/ }
    // Do your transformations here
  // Given an 8-bit grayscale image, this
  // simulates the material_map behaviour.
  texture_map {
    [0 Tex1 ]
    [1/256 Tex1 ]
    [1/256 Tex2 ]
    [2/256 Tex2 ]
    [2/256 Tex3 ]
    [3/256 Tex3 ]
Date: 30 Dec 2002 07:07:02
Message: <3e1036e5@news.povray.org>
Philippe Debar wrote:
> I seem to remember there is a keyword that makes the child texture
> independant from the parent's modifiers, but I could not find it.
Yep, the reset_children keyword. IIRC it was deprecated in favor of
pigment_pattern during the development of 3.5.
