POV-Ray : Newsgroups : povray.general : more radiosity - load/save Server Time
12 Jan 2026 17:14:58 EST (-0500)
  more radiosity - load/save (Message 1 to 4 of 4)
Subject: more radiosity - load/save
Date: 12 Sep 2002 14:28:43
Message: <Xns9287CF9DD57BDraf256com@204.213.191.226>
(Yes I realy do like playing with radiosity :)
After saving radiosity data, and then loading it with identical scene, the
output image is little different. The image that loads data renders about
x6 faster (count=300 error=1) and looks a little bit nicer that image that
where outputet when saving radiosity.
I would like to have same quality with create+sava radiosity version and
with load radiosity version - but to save more time (I want to do
animation).
And Yes, I do use always_sample 0 :
in save version :
      save_file "rad2"
    //  load_file "rad2"
    //  always_sample 0
and next I'm re-rendering it with :
    //  save_file "rad2"
      load_file "rad2"
      always_sample 0
Another question - what excly data are stored in radiosity file ?
It is save to move camera around, but I quess it will be NOT safe if camera
will i.e. move to another room - or if it will view surfaces not visible
while saving radiosity ?
And - can I change light's _colors_ (not position), like
light_source { <0,0,0> color rgb <clock,0,1-clock> }
or
sphere { 0 100 pigment { color rgb x*clock } finish { ambient 1 } }
Subject: Re: more radiosity - load/save
Date: 12 Sep 2002 15:35:23
Message: <3D80EC7C.FC38D53D@gmx.de>
> in save version :
>       save_file "rad2"
>     //  load_file "rad2"
>     //  always_sample 0
>     //  save_file "rad2"
>       load_file "rad2"
>       always_sample 0
You should have a look at the documentation of 'always_sample'.  using
'always_sample off' disables gathering new samples during final trace.
It's fairly obvious the result looks different.
Date: 12 Sep 2002 15:40:52
Message: <Xns9287DBD9B37A8raf256com@204.213.191.226>
Christoph Hormann <chr### [at] gmxde> wrote in
news:3D80EC7C.FC38D53D@gmx.de
>> in save version :
>>       save_file "rad2"
>>     //  load_file "rad2"
>>     //  always_sample 0
>>     //  save_file "rad2"
>>       load_file "rad2"
>>       always_sample 0
I read it, so I quess I missinterpretate this part.
I want for clock==0 - gather samples, gather in final phase, and save all
samples
else :
  laod data, do not gather enything, just use loaded data
or loaded data isn't enought to skip entire gathering - it is only some
kind of optimization for speed-up gathering ?
Date: 12 Sep 2002 17:43:29
Message: <3d810a80@news.povray.org>
> I would like to have same quality with create+save radiosity version and
> animation).
  From my experience, in the "load version" you must specify the same
error_bound and recursion_limit used on the "save version", because these
values are apparently overridden and set again to defaults (and used for
the calculations too).
Jaime Vives Piqueres
http://www.ignorancia.org
