POV-Ray : Newsgroups : povray.general : interior fade Server Time
25 Nov 2025 19:50:32 EST (-0500)
  interior fade (Message 1 to 5 of 5)
Subject: interior fade
Date: 4 Aug 2002 13:15:16
Message: <Xns9260C340FE097raf256com@204.213.191.226>
I'm woundering - is it phisicaly ok that light (interior - fade_power)
fades to black ? imho light should fade to some color.
But using fade_color same as pigment color results in no fading at all.
I.e. think about human's skin.
I.e. we have 3 small splinter's inside humans finger (drastic example ;)
All are white.
The object that is at 'depth' of 0.1 mm will have normal white color.
This at depth 2 mm will have ie 50% it's color, and 50% of skinns color, so
it will be bright-"orange".
And this at dethp over 5 mm will be in fact invisible from outside.
How can I simulate this in POV ? Maybe little example (box=finger,
sphere=splinter)
Subject: Re: interior fade
Date: 4 Aug 2002 13:20:17
Message: <Xns9260C41B4C8FDraf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226
sorry, forgot to add this - I don't want to use media - it's slow and not
accurate.
Imho scattering media with constant density will give proper effect, but -
how about add way to calculate this very tryvial effect without using
standart media - that is slow and innacurate ?
Date: 4 Aug 2002 13:25:13
Message: <3d4d6379@news.povray.org>
"Rafal 'Raf256' Maj" wrote:
> Hi,
You need to give fade_color very low values to still get visible fading
for example rgb<0.1,0.2,0>. This is because rgb 0 is the default and rgb 1
doesn't give any fading so to get almost the same fading as with the default
only colored you have to use such low values.
Simon
Date: 4 Aug 2002 15:50:02
Message: <chrishuff-4CFB08.14405904082002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
No, it should fade to black. As distance increases, it allows less and
less light to pass through.
You are probably using too high of a color value or simply can't see the
fading because of the pigment color. Make the pigment color "rgbf 1".
> All are white.
Skin is a different case, it scatters quite a bit of light. Interior
attenuation can not simulate this, you need scattering media.
Date: 4 Aug 2002 15:51:04
Message: <chrishuff-0B2220.14420204082002@netplex.aussie.org>
> accurate.
Actually, media is more accurate in most cases. And it usually isn't too
slow to use.
Absorbing media is the analog of attenuation, not scattering. And media
is accurate, that's why it is slow.
