POV-Ray : Newsgroups : povray.general : long syntax Server Time
12 Jan 2026 23:28:57 EST (-0500)
  long syntax (Message 1 to 10 of 24)
Subject: long syntax
Date: 23 Jul 2002 20:45:42
Message: <Xns92551B829A3A9raf256com@204.213.191.226>
I have a little suggeston / future-request.
Myself I like usign Pov without any editor (to type code "by hands" :)
but there are one thing that IMHO makes it unnesesarly uncomfortalbe -
[too] long names.
Compare i.e.:
difference {
  sphere { ... }
  torus { ... }
  finish { roughness 1 brillaince 2 relfection { .2 .5 } metallic 9 diffuse
  0.7 }
} superellipsoid { ... }
with :
@@diff {
  s { } tr { }
  fi { rou 1 bril 2 ref { .2 .5 } met 9 diff 0.7 }
} @sup { ... }
So the idea is to use aliases for important names, and to mark them with
Implementation imho would be quite easy - ther is probalby one function
that reads next element, and tells is it an object, float, string,
undeclared identyfier, etc...
So only we have to do something like
void interprate(char *s) {
  if (s[0]=='@') {
    char *x = // match alias name, "s","tr","fi" etc
    interprate(x);
The more advanced idea is :
if alias is marked by "@@" like @@diff { ... } then assume that every name
in it can be an alias, even it it is not marked with "@" (or "@@")
example :
 @sp { @fi { @ref } }   // ok. sp=sphere fi=finish ref=reflection
 @sp {  fi {  ref { } } // errors, fi and ref must be marked by "@"
@@sp {  fi {  ref { } } // ok fi and ref are inside "@@" block
 @sp {@@fi {  ref { } } // ok ref is inside "@@" block
maybe alsow it will be a good idea to implement @! operator, that removes
aliases from following block (i.e when we need names like "fi" in it)
#declare fi = 5.0;
@@sp {
  fi { }
  @!pig {
     fi // fi is here an 5.0 float
this new syntax might look strange now, but it will shorten code about x3
times ! x3 shorter code = x3 more writing, x3 more comfortable
x3 more code on ona page (or screen)
My suggestions :
@tex  texture
@mat  material
@fin  finish
@nor  normal
@int  interior
@cmap color_map
@nmap normal_map
@mmap material_map
@sp   sphere
@bo   box
@pl   plane
@to   torus
@sup  superellipsoid (that's a good example ;)
@blo  blob
@br   brilliance (only in finish block)
@di   diffuse    (only in finish block)
I want to *help* to implement aliases, but I can not do it my self (I do
not understand Pov's souces enought)
what do You thing about it ? If You agree that this is usefull, and
somebody also want's to implement it - I will help :)
Subject: Re: long syntax
Date: 23 Jul 2002 21:39:03
Message: <3d3e0537@news.povray.org>
With all due respect, as nice as it is to save some typing, I think this is
a bad idea that would confuse people. I don't like it.
Anthony
Date: 23 Jul 2002 21:43:05
Message: <chrishuff-1C88F0.20355323072002@netplex.aussie.org>
To be blunt, that looks horrible and I hope POV never supports it.
Sorry. ;-)
The only benefit is less typing. It makes things much more difficult to
read, scatters relatively hard to type and visually noisy @ characters
throughout the code (I dislike the use of the # character in the current
syntax for the same reason), and needlessly complicates the language.
Worse, the same word means totally different things in different
contexts.
The only benefit would be for obfuscated and shortest code contests. If
you really just want to save typing, I would recommend you find a good
editor...you could also use the existing #macro feature:
#macro supell(E, N) superellipsoid {E, N #end
supell(0.1, 0.5)
    texture {...}
Date: 23 Jul 2002 22:01:38
Message: <Xns92552862219D8raf256com@204.213.191.226>
Christopher James Huff <chr### [at] maccom> wrote in news:chrishuff-
1C8### [at] netplexaussieorg
that saves time and is more comfortable
> contexts.
so, how about at least shorten some names, i.e. add keywoed "brill" that
works same as "brilliance".
Don't You agree that brilliance, reflection, diffuse, ambient are keywords
that are used very common (if scene have meany diffrent textures), and ther
is probably no reason to not have shorten versions.
Something like "color" and "colour" keywords - the second is in fact aliast
of 1st, and it is added to make SDL comfortalbe.
This ~10 keywords, maybe with diff and itner will make typing quicker, and
will not make code less clear IMHO
> supell(0.1, 0.5)
>     texture {...}
but it's usless in i.e. finish, normal, pigment, blob, mesh etc
Date: 23 Jul 2002 22:18:54
Message: <chrishuff-424F5B.21114323072002@netplex.aussie.org>
In article <Xns### [at] 204213191226>,
No thanks.
No thanks. The disadvantages far outweigh the advantages in my opinion.
"ambient" has 7 characters, it takes a fraction of a second to type.
That is an entirely different situation...both are valid spellings for
the word.
They are also polluting an already crowded namespace, and will make code
less clear, adding more stuff to memorize, sprinkling odd characters and
keywords through the files whose meanings are not obvious.
> > supell(0.1, 0.5)
> >     texture {...}
I don't see how blobs or meshes are any different. And for the texture
stuff, it isn't useless, just put the stuff you use most often as a
parameter. You could also leave off the ending bracket to be closed
outside the macro call.
#macro Fin(Dif, Amb, Spec, Rough, Refl)
    finish {
        diffuse Dif
        ambient Amb
        specular Spec
        roughness Rough
        reflection Refl
You could put these in an include and make things as short and hard to
read as you want. ;-)
My point is that there is already a feature that can be used to do what
you want, and the proposed feature has so many drawbacks that it is very
unlikely you will find anyone willing to waste the time to implement it.
Date: 23 Jul 2002 22:35:26
Message: <1105360.1bWDcCXsOV@3-e.net>
Go ahead type that way, then search and replace before you render.
No need to change POV at all!
Rafal 'Raf256' Maj wrote:
> Hi,
> [too] long names.
> Compare i.e.:
> difference {
>   sphere { ... }
>   torus { ... }
>   diffuse 0.7 }
> with :
> @@diff {
>   s { } tr { }
> } @sup { ... }
>   if (s[0]=='@') {
>     interprate(x);
> example :
> #declare fi = 5.0;
> @@sp {
>   fi { }
>   @!pig {
> My suggestions :
> @tex  texture
> @mat  material
> @fin  finish
> @nor  normal
> @int  interior
> @cmap color_map
> @nmap normal_map
> @mmap material_map
> @sp   sphere
> @bo   box
> @pl   plane
> @to   torus
> @blo  blob
> #macro
> #g(U,V)(.4*abs(sin(9*sqrt(pow(x-U,2)+pow(y-V,2))))*pow(1-min(1,(sqrt(
> pow(x-U,2)+pow(y-V,2))*.3)),2)+.9)#end#macro p(c)#if(c>1)#local
> l=mod(c,100 );g(2*div(l,10)-8,2*mod(l,10)-8)*p(div(c,100))#else 1#end#end
> light_source{ y 2}sphere{z*20
> 9pigment{function{p(26252423)*p(36455644)*p(66656463)}}}//M
Your connection failed because: Your Flux Capacitor has gone bad.
Date: 23 Jul 2002 22:52:37
Message: <Xns925531073B081raf256com@204.213.191.226>
news:chr### [at] netplexaussieorg
>     finish {
>         diffuse Dif
>         ambient Amb
>         specular Spec
>         roughness Rough
>         reflection Refl
> #end
> what you want, and the proposed feature has so many drawbacks that it
> is very unlikely you will find anyone willing to waste the time to
> implement it.
finish { ambient 0 }
finish { ambient 0 diffuse .3 reflection { .2 .4 } metallic .7 brilliance
1.2 }
will need 2 macros to make any sens, or one macro to be used like :
Fin(0, -1,-1,-1,-1,-1,-1);
where -1 means "default value"
ok, It was just a suggestion. Meany peoples says "what, I had to write 10
pages to get a simpel image ? no - thanks" and it's not easy to convince
them... well - theirs problem ;)
Date: 23 Jul 2002 22:53:25
Message: <Xns925531297E308raf256com@204.213.191.226>
Daniel Matthews <dan#@3-e.net> wrote in news:110### [at] 3-enet
add-on is a good idea imho. I'll see if it will be usefull
Date: 24 Jul 2002 02:10:20
Message: <60hsju8ikr93p1d38ar8lrlu35rivp22fh@4ax.com>
On 23 Jul 2002 20:45:42 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
Use POVWin if you want syntax completion. No need for long keyword typing.
IIRC Python port has it either. Leave short one-or-a-few-letter names for
local variables.
ABX
Date: 24 Jul 2002 02:26:50
Message: <TWCvYBAyfkP9EwXC@econym.demon.co.uk>
If your main objective is to save typing, then you might consider using
the existing keyword expansion and/or codelist features.
Keyword         your            Keywod
                suggestion      Expansion
texture         @tex            tex[TAB][TAB]
material        @mat            mat[TAB]
finish          @fin            fini[TAB]
normal          @nor            nor[TAB]
color_map       @cmap           co[TAB][TAB][TAB]
normal_map      @nmap           nor[TAB][TAB][TAB]
sphere          @sp             sph[TAB]
box             @bo             box
plane           @pl             pl[TAB][TAB]
torus           @to             to[TAB][TAB][TAB]
superellipsiod  @sup            sup[TAB]
blob            @blo            bl[TAB][TAB]
brilliance      @br             bril[TAB]
diffuse         @di             di[TAB][TAB]
The difference in the number of keystrokes is fairly minimal, but
keyword expansion and codelist have the following advantages:-
1. The resulting code is readable.
2. ALL the POV keywords are supported.
3. Easier to remember. E.g. you don't have to remember whether @br is
short for "brilliance" or "brightness".
4. You can use it to generate scenes that are compatible with previous
versions of POV.
Mike Williams
Gentleman of Leisure
