POV-Ray : Newsgroups : povray.general : distance pattern ? Server Time
29 Dec 2025 11:08:38 EST (-0500)
  distance pattern ? (Message 1 to 10 of 16)
Subject: distance pattern ?
Date: 9 Jul 2002 21:17:50
Message: <Xns924720F957A3Eraf256com@204.213.191.226>
realy couldn't find one thing in manual... there AFAIR was some pattern
(used i.e. in media) that value in <x,y,z> was equal to distance beetwen
<x,y,z> and some object
so it works like object{} pattern, but it can be used with color_map etc
ther was some example represanting media looking like letter 'H'
is this pattern available in Pov 3.5 ?
Subject: Re: distance pattern ?
Date: 9 Jul 2002 21:35:28
Message: <3d2b8f5f@news.povray.org>
Rafal 'Raf256' Maj <raf### [at] raf256com> wrote:
> Hi,
  If there would be a fast way of determining the distance of a point from
the surface of an object, that would be more or less a holy grail of
raytracing. (Among other things it would allow you to create an isosurface
identical to any given object and then just transform it non-linearly.)
  The sad fact is that there's no generic way of calculating this distance
fast and accurately for any given object.
  The patch you are referring to _approximated_ the distance by shooting
many rays towards the object and taking the one which hit the object at
closest distance. Of course this has two drawbacks: It's not very accurate
(usually introduces bad graininess) and it's very slow.
  There was a discussion some time ago (I think initiated by me) that the
distance calculation could be optimized in a per-primitive basis (for many
primitives getting the accurate distance fast is quite easy), as well as
developing a proper algorithm for calculating it analytically for a CSG
object. (Of course there are objects where you *can't* get the accurate
distance from the surface, eg. the 4D julia object. For some objects it
might not be unambiguous which distance is the correct one.)
Date: 9 Jul 2002 23:01:00
Message: <Xns92473277261A7raf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3d2b8f5f@news.povray.org:
>> pattern (used i.e. in media) that value in <x,y,z> was equal to
>> distance beetwen <x,y,z> and some object
>   from
> isosurface identical to any given object and then just transform it
> non-linearly.)
>   distance
>   shooting
is this future available in Pov 3.5 and what is it's name ?
> at closest distance. Of course this has two drawbacks: It's not very
> accurate (usually introduces bad graininess) and it's very slow.
Well - it should be easy to optimize it :)
if you do NOT need information about normal of object, but only of
distance, why not add future like
pixelized {
  object ...
  100,100,100
that will create 100x100x100 bits arrar - informing is some point inside
object or not. In addition - it will be very fast to use, and object size
(maybe speed) can be optimized using binary trees (or something simmilar).
For 'pixelized' object (as well as for some primitives) functions
returining distance from <x,y,z> to object will be very fast.
I can implement it, in fact I would be heapy to, but I need little help - I
realy do NOT like modyfing somones other code, especialy when its so big
and complex as Pov's source. So I will write individual program realizating
this algorith and if You will like it - maybe somebody will actualy use it
in Pov.
How code should look to be easy to link with Pov ?
My suggestion - program wil
Use functions of PovRay :
bool Inside(int x,int y,in z); // is point inside of some object
Give functions
void BuildTab(); // build i.e. 100x100x100 array
void FreeTab(); // free
double Distance(float x,float y,float z); // distance from point to
  // object
I can alsow ofcourse implement above for sphere,box,cone,torus and maybe
few other primitives
Date: 9 Jul 2002 23:05:43
Message: <Xns92473343EDCAFraf256com@204.213.191.226>
"Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote in
news:Xns### [at] 204213191226:
Full example "
#declare pix = pixelized {
  object { some_complex_object }
  100,100,100
#declare d1=density {
  distance { pix }
  distance { box { /* ... */ } }
  distance { sphere }
  distance { blob { ... } }  // error, or use future with shooting many
  // rays
so in fact - pixelized its just a creation of df3 data while parsing,
functions like
save_data
load_data
would be alsow useful
Date: 9 Jul 2002 23:20:45
Message: <3d2ba80d@news.povray.org>
  I thought that I made clear that the patch was highly experimental.
  They didn't include highly experimental and incomplete patches to 3.5.
> pixelized {
>   object ...
>   100,100,100
> object or not.
  Uh... I didn't understand this at all. What does it help to know if
a point is inside an object or not, when you are calculating the distance
of a point from the surface of the object?
  And besides, insideness test is not a problem (it's required for CSG and
perhaps some other things, and in pov3.5 they even added it to the SDL so
that you can use it in your scenes; it's the inside() function).
Date: 10 Jul 2002 01:20:38
Message: <Xns92474A242630raf256com@204.213.191.226>
Warp <war### [at] tagpovrayorg> wrote in news:3d2ba80d@news.povray.org:
>> inside object or not.
> distance of a point from the surface of the object?
in worst case - You can just shut rays at object, as it was in test wersion
of distance pattern, but it will by much faster to test intersection of
pixelized rather then i.e. isosurface or complex CSG
> and
> so that you can use it in your scenes; it's the inside() function).
I only suggested : why not optimize (using pre-calculated array) this
tests, that will result in faster shooting rays and i.e. speeding up
distance calculations
Date: 10 Jul 2002 05:11:00
Message: <hstniu4gije9cv8iqg5rdurkrb0gb92vqg@4ax.com>
On 9 Jul 2002 21:17:50 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> Hi,
For basic primitives this can be realized without internall support. Take a
look at my 'rounded' addition to iso_csg library
(http://www-public.tu-bs.de:8080/~y0013390/pov/ic/). It can be even faster
than internall pattern since it is optimized for shapes and not use rays like
original proximity pattern. It is also accurate unless you not use strange
transformations or complicated CSGs.
For more complicated shapes it can be realized with my
blurred/distance/proximity solution (unfortunatelly final macro is not
finished becouse of bugs I found during betatesting but initial version should
work).
http://news.povray.org/povray.binaries.images/22100/
http://news.povray.org/povray.binaries.images/22745/
http://news.povray.org/povray.text.scene-files/22075/
ABX
Date: 10 Jul 2002 05:17:04
Message: <iiuniucqugvah8npbnj2f00pd5kcm2jnij@4ax.com>
On 9 Jul 2002 23:01:00 -0400, "Rafal 'Raf256' Maj" <raf### [at] raf256com> wrote:
> pixelized {
>   object ...
>   100,100,100
No need for patching. It is already done in my implementation of distance
pattern via functions.
> I realy do NOT like modyfing somones other code, especialy when its so big
If you really want to help POV or You want work in any team professionally you
should learn to work with other sources. Moreover POV sources are complex in
total size but basic in general raytracing algorithms and are builded very
clear. Yes, there is no so much comments but identifiers are usually
selfexplaining.
ABX
Date: 10 Jul 2002 10:26:12
Message: <3d2c4404@news.povray.org>
  Really? Can you give me actual measurements of this?
  Besides, you will just get a "pixelized" distance pattern (ie. the pattern
will be formed of cubes). How is that useful?
> tests
  Because insideness test is already very fast. As I said, that's not the
problem. However, a fast insideness test does not help resolving the
distance from the surface of the object.
Date: 10 Jul 2002 13:06:14
Message: <chrishuff-D1EF6B.12032110072002@netplex.aussie.org>
In article <3d2b8f5f@news.povray.org>, Warp <war### [at] tagpovrayorg>
That is an optimization that I've been planning on for nearly as long as
the proximity pattern has existed...I'm going to do a fairly complete
rewrite of the patch, making something that is simpler to use and
generally faster. I'm going to do something similar for the glow patch
as well...the two patches are going to be pretty closely tied together.
To answer the question: no, the proximity pattern was not added to POV
3.5...it never got beyond the experimental stage, and wasn't even close
to being ready for the official version. The object pattern did make it,
and it can be used to get a somewhat similar effect where the pattern
value depends on the percentage of nearby space filled by the object.
This is not proximity, and it is a bit slow, but it might do what you
need.
And the "pixelize" idea (which would really be "voxelize") has its own
problems: the voxel field takes up a huge amount of memory, and even
with interpolation you get grid artifacts if the resolution is too low.
It doesn't require a patch though...if I recall correctly, there are
other patches in MegaPOV that would make it possible. The official
POV-Ray 3.1 has a density file pattern, and a MegaPOV patch made it
possible to generate the field from within the scene file. (this might
have made it into 3.5, I don't remember)
A patch adding features for generating and processing voxel information
would be useful though. There are a lot of things that could be done to
extend the current capabilities.
