POV-Ray : Newsgroups : povray.general : Fonts Server Time
22 Feb 2026 05:24:32 EST (-0500)
  Fonts (Message 1 to 5 of 5)
Subject: Fonts
Date: 11 Jun 2004 16:03:12
Message: <MPG.1b33bddbf4d1f98989a7b@news.povray.org>
Has anyone considered designing a special font function that could
extract the vector information from TTF type fonts, then employ splines
to either warp them along a path or even wrap them around objects? Seems
a waste to me to have a perfectly good vector based graphic, but no way
to bend it to fit objects. Existing methods are limited and imperfect
imho.
Anyway, I certainly hope someone might a) find the idea interesting and
b) have a clue how to do it. Wish I did...
void main () {
    call functional_code()
  else
    call crash_windows();
Subject: Re: Fonts
Date: 11 Jun 2004 16:09:16
Message: <c44kc09bmc7nmpi55ei8k9lbogo1p9lrru@4ax.com>
On Fri, 11 Jun 2004 13:02:53 -0700, Patrick Elliott <sha### [at] hotmailcom>
Do you mean text along spline or spline of curves used to create letter ?
Both have their pretty accurate workarounds (thought second with external
tool).
ABX
Subject: Re: Fonts
Date: 12 Jun 2004 16:42:01
Message: <MPG.1b35185ecde83bb7989a7e@news.povray.org>
In article <c44kc09bmc7nmpi55ei8k9lbogo1p9lrru@4ax.com>, abx### [at] abxartpl
says...
> tool).
> ABX
No, I mean taking the vector data straight out of the TTF, so you could
literally place the font onto a spline or object path of some sort.
Optimal would be if you could do:
text {
    ttf "timron.ttf" "This is fun" 1, 0
    pigment { Red }
    path {
      sphere {<0,0,0>, 5}
So it would actually recompute the points the define the font to 'fit'
the sphere.
However, this may not be practical. For example, how do you manage that
if the 'path' is a bicubic batch? A set of splines, say one for each
edge, could be used instead, so it bends the fonts along the 3D path of
the splines. A single letter (or a line of text) could then be bent along
the path, so it ends up rippled, twisted or even folded around to touch
itself. Yes, there are ways to fake it, but none of them can do this so
it is actually right.
I think it has definite benefits over the currently difficult and
complicated placement of every letter, one at a time, especially since
you can't actually 'warp' the letters to fit an object, unless you then
CSG them to cut away the parts that don't fit. Even then, they still are
only 'close' in most case, not actually right. Doing it with existing
methods is a lot of extra work for something that isn't really what you
intended in the first place.
I mean it just seemed to me that since the information in TTF was vector
based anyway, it might be easy to adapt such data to produce this effect.
Would be interesting to see it done by someone. I could care less about
current workarounds. At least at this moment anyway, since I am not
actually working on anything that needs one.
void main () {
  else
Subject: Re: Fonts
Date: 13 Jun 2004 07:34:15
Message: <40cc3bb7$1@news.povray.org>
You can place all caracters of your text along a spline with the
Spline_Trans macro available in transforms.inc
ZeSly
http://perso.wanadoo.fr/zesly/
Subject: Re: Fonts
Date: 13 Jun 2004 18:27:07
Message: <MPG.1b36829cf642bd98989a80@news.povray.org>
In article <40cc3bb7$1@news.povray.org>, zes### [at] wanadoofr says...
What part of "this doesn't quite do what I am suggesting" did you miss?
Yes, you can use that to 'position' them, but it cannot and will not bend
the individual letters to conform to a shape. That is what I suggested
would be more interesting to do. Actually distorting the text to follow
the contours of a shape.
void main () {
  else
