POV-Ray : Newsgroups : povray.general : Semi-transparent rocket exhaust plumes ? Server Time
16 Jan 2026 02:13:48 EST (-0500)
  Semi-transparent rocket exhaust plumes ? (Message 1 to 6 of 6)
Subject: Semi-transparent rocket exhaust plumes ?
Date: 19 Feb 2004 19:43:32
Message: <MPG.1a9f688f58da0b098968f@news.povray.org>
Has anyone done a realistic-looking semi-transparent rocket exhaust
plume (no bright fire and no smoke) and if so, how ? I'm thinking of
something vaguely similar to these (except it will be from a spacecraft
in space and not on the ground):
http://www.clavius.org/img/az50fire.jpg
http://www.clavius.org/img/tit2-engine.jpg
And maybe a bit like this although I want a much more regular plume
shape:
http://cs.space.eads.net/sp/images/Plume_S10-2.jpg
Basically, what I want is a faint plume with a fuzzy outer boundary,
with its visibility strongest (and also the lowest level of
transparency) not far from its outer boundary as in the links above.
Bjorn Jonsson / bjj### [at] ZZZmmediais
Address changed to avoid spam. Remove YYY and
ZZZ to reply.
Subject: Re: Semi-transparent rocket exhaust plumes ?
Date: 19 Feb 2004 22:37:33
Message: <403580FC.D65A654@hotmail.com>
> spacecraft in space and not on the ground):
I have one in my April 03 IRTC entry:
  http://www.irtc.org/ftp/pub/anims/2003-04-15/advent.mpg
You may not like the color, but the technique should be adaptable to
your purposes.
John
Date: 20 Feb 2004 13:47:33
Message: <MPG.1aa066a1fee02d20989690@news.povray.org>
In article <403### [at] hotmailcom>, evi### [at] hotmailcom
says...
> your purposes.
> Regards,
> John
This is somewhat similar to what I'm trying to do and could definitely
be modified into something I'd be happy with. The only problem is that I
found no source code or description of how this was done ;-).
FWIW what I'm planning to do is to add the exhaust plume to this:
http://www.mmedia.is/~bjj/css_53187,055560_no_plume.jpg
This will show NASA's Cassini spacecraft firing its retrorocket to enter
orbit around Saturn.
ZZZ to reply.
Date: 20 Feb 2004 16:06:12
Message: <403676c4$1@news.povray.org>
I've posted one to povray.text.scene-files which you might be able to work
with, although it's written up kind of crudely. Subject line is Rocket
Nozzle example.
Loved the animation John showed. Figured it probably had the scene file
there at IRTC... appears not, like you said. I only see the text description
along with MPG and JPG files. I'd hazard to guess it must be quite a bunch
of files to get all of it animated.
Bob H.
http://www.3digitaleyes.com
Date: 20 Feb 2004 20:15:16
Message: <4036B122.29217E50@hotmail.com>
> I found no source code or description of how this was done ;-).
I generally don't post my sources, mainly because I don't want to get
too much mail about people having trouble with them.
The code used to generate the flames is posted to p.t.scene-files.
John
Date: 20 Feb 2004 20:19:53
Message: <4036B237.DBBE1BF6@hotmail.com>
Hughes, B. wrote:
> I'd hazard to guess it must be quite a bunch of files to get all of it
> animated.
There are 19 files that simple set up the scenes and place objects,
subtitles, and so on.  There is another file for the valley, each
building, each robot (4 different ones used), the ship, the road, the
orchard, and various others as well.
John
