POV-Ray : Newsgroups : povray.general : MegaPov height_of to Pov 3.5 Server Time
29 Dec 2025 05:44:21 EST (-0500)
  MegaPov height_of to Pov 3.5 (Message 1 to 6 of 6)
Subject: MegaPov height_of to Pov 3.5
Date: 5 Aug 2002 03:30:09
Message: <B973A1CB.4BDC%glenncg@isrv.com>
Can anyone help me translate MegaPov's height_of to the new Pov? Thank you.
Subject: Re: MegaPov height_of to Pov 3.5
Date: 5 Aug 2002 03:51:15
Message: <3D4E2E73.7BEF94D@gmx.de>
You mean 'hf_height_at()'?
Just use 'trace()' instead.
Last updated 03 Aug. 2002 _____./\/^>_*_<^\/\.______
Date: 5 Aug 2002 12:18:17
Message: <chrishuff-731D18.11081105082002@netplex.aussie.org>
In article <B973A1CB.4BDC%gle### [at] isrvcom>,
If you are talking about the hf_height_at() function, adding it to POV
3.5 would be a waste of time, since trace() is already there and is a
much better solution. Just trace from a point above the height field
directly down. It is much more flexible, and works for any shape.
Date: 5 Aug 2002 15:15:41
Message: <B9744727.4BFF%glenncg@isrv.com>
in article chr### [at] netplexaussieorg, Christopher
James Huff at chr### [at] maccom wrote on 8/5/02 12:08 PM:
Thank you for your comments.  However, I would like to evaluate a height
field at parse time, not render time.  I've been trying to use bitmap data
to add a deformation map feature to a mesh creation macro i've been working
on. I thought that the 3.5 function feature might be the way to go.  But i
can't figger it.  With MegaPov hf_height_at() i could loop through and
evaluate values at each point before rendering.  Thanks again.
Date: 5 Aug 2002 16:20:18
Message: <3d4ede02@news.povray.org>
You can still do that with trace().
Date: 5 Aug 2002 17:54:18
Message: <chrishuff-33D097.16441305082002@netplex.aussie.org>
In article <B9744727.4BFF%gle### [at] isrvcom>,
The trace() function is a scene description language feature that
operates at parse time, not render time.
> I've been trying to use bitmap data to add a deformation map feature
> to a mesh creation macro i've been working on. I thought that the 3.5
> function feature might be the way to go.  But i can't figger it.
> With MegaPov hf_height_at() i could loop through and evaluate values
You could do the exact same thing with the trace() function, see the
manual. However, it sounds like functions are a better solution. You
might want to look at the height field macros in shapes.inc for examples.
