POV-Ray : Newsgroups : povray.general : Scaling texture_map Server Time
27 Mar 2026 22:32:43 EDT (-0400)
  Scaling texture_map (Message 1 to 3 of 3)
Subject: Scaling texture_map
Date: 4 Dec 1999 13:07:54
Message: <8E92C7AC2seed7@204.213.191.228>
In the scene below are two spheres with white dots. I expected both the
textures to be the same, except for the red dot. But it seems that scaling
the not only affects the pattern_type but also the texture map. I had a quick
look in the docs but found nothing that explains.
Is this the to be expected behaviour, or...
How can I get the result I want? Layerd textures won't work because of the
different finishes.
Ingo
#version 3.1;
global_settings {assumed_gamma 1.0}
light_source {<500,500,-500> rgb 1}
camera {location <0,1.6,-2> look_at <0,0,0>}
#declare TestT= texture {
      leopard
      scale 0.05
      colour_map {
         [0.3, rgb 0.3]
         [0.3, rgb 1]
#declare TestT2= texture {
   cylindrical
   scale <2,1,1>
   texture_map {
      [0.7, TestT]
      [0.8, pigment {red 1} finish {phong 1}]
sphere {
   0,0.5
   texture{TestT}
   translate <-0.5,0,0>
sphere {
   0,0.5
   texture{TestT2}
   translate <0.5,0,0>
Subject: Re: Scaling texture_map
Date: 4 Dec 1999 13:15:18
Message: <chrishuff_99-6076F1.13153304121999@news.povray.org>
I think this is what the reset_children patch in UVPov is for. It allows
you to transform the top level of a texture, leaving it's component
parts(it's children) unchanged.
Other than using that patch, I think this will do what you
want(untested!):
   cylindrical
   scale <2,1,1>
   texture_map {
      [0.7, TestT scale < 0.5, 1, 1>]//scale this part to compensate
Chris Huff
e-mail: chr### [at] yahoocom
Date: 4 Dec 1999 14:44:25
Message: <8E92D7745seed7@204.213.191.228>
The warp{reset_children} is perfect, as it also works for turbulence witch
your second solution does not.
Thanks Chris,
Ingo
