POV-Ray : Newsgroups : povray.general : what is a spline Server Time
23 Apr 2026 11:41:53 EDT (-0400)
  what is a spline (Message 1 to 10 of 12)
Subject: what is a spline
Date: 18 Feb 2002 03:47:26
Message: <82f17usvq6kkpubonvcoq3gbfk9seosh58@4ax.com>
useless (but not o-t) philosophical question in free time during rendering:
What is a spline ?
Is it an object (becouse of shape)?
Is it a data type (becouse appear in declarations)?
Is it a data structure (becouse store points at entries)?
Is it a programing structure (becouse it is way of declaring function)?
Is it new alone category ?
ABX
Subject: Re: what is a spline
Date: 18 Feb 2002 08:26:44
Message: <3c710114@news.povray.org>
> What is a spline ?
No, there is no shape!
Of course.
Not really, because not only the declared entries can be adressed.
No, because it isn't programable by the user.
No, it's a data type.
Everything only IMHO!
Felix Wiemann
Date: 18 Feb 2002 08:37:39
Message: <3C710399.AD1ADCD@namtar.qub.ac.uk>
Felix Wiemann wrote:
> > What is a spline ?
Well, don't forget splines were originally geometric entities; used to
smoothly interpolate between sets of points. We've extended it to other
uses, but...
signature{
Date: 18 Feb 2002 08:46:06
Message: <3c71059d@news.povray.org>
I would say that a spline is a function. You give it some data (the
control points and the time value to be evaluated) and it returns some
coordinates. Exactly what functions do.
Date: 18 Feb 2002 09:12:32
Message: <3c710bd0$1@news.povray.org>
But the user can't control the calculating process (like it is possible with
a function).
Date: 18 Feb 2002 09:14:54
Message: <3C710C53.F57388CB@namtar.qub.ac.uk>
> a function).
Oh, you mean like the way you can control how functions like sin(),
pow() etc. are calculated (?)
signature{
Date: 18 Feb 2002 09:26:26
Message: <c3327uom1m9jm4c3q5a2hj3stict5rji85@4ax.com>
On Mon, 18 Feb 2002 14:28:14 +0100, "Felix Wiemann" <Fel### [at] gmxnet>
wrote:
> > What is a spline ?
it does the same what parametric object, in given range of parameter results
coordinates
> Of course.
so what is content of this data ?
type of spline ?
values for entries ?
results for parameter? (infinite data type?)
in a list when you adress entry outside range of index then you just recive
NULL, it's empty result but result
you can influence output with specified list of tools: adding entry and
changing type
me too
ABX
Date: 18 Feb 2002 11:43:30
Message: <chrishuff-BD85E1.11431418022002@netplex.aussie.org>
In article <82f17usvq6kkpubonvcoq3gbfk9seosh58@4ax.com>,
> What is a spline ?
A function. You give it an input, you get an output based on that input.
It isn't a shape, it doesn't have a surface, the closest thing is that
it returns spatially related values. It is a data type in the same way
that textures and objects are data types, but that's nothing unusual in
POV...anything that can be declared is a data type. It uses a data
structure, but it isn't used as one, it isn't intended to store and
retrieve data like arrays (though I guess you could use it to store
points if you keep track of the t values).
For the other person: "programmability" is not a requirement for a
function, only providing a result from a set of parameters. You can't
reprogram the sin(), cos(), or vlength(), but they are still functions.
Date: 18 Feb 2002 13:16:36
Message: <3c714504@news.povray.org>
Hmmm... I actually meant user defined functions, but you're right...
Date: 18 Feb 2002 13:52:00
Message: <3c714d50@news.povray.org>
> parameter results coordinates
But using the parametric object directly creates a shape, using a spline
doesn't create a shape. (I don't know what I'm talking about, so please
correct me, if I'm wrong.)
> > Of course.
> type of spline ?
Type of spline and values for entries.
recive
A list? Which language?
function)?
> changing type
Do you mean user defined functions?
They are completely programable by the user.
Or do you mean predefined functions?
Spline are declared at parsing time, so they can't be predefined.
But perhaps splines are predefined (because of the predefined algorithm) and
user defined (because they are declared at parsing time) functions. A
function is a data type, so I think, the answer could be:
A spline is a data type and a function.
Felix
