POV-Ray : Newsgroups : povray.general : Height field to mesh - more resolution Server Time
4 Mar 2026 12:20:19 EST (-0500)
  Height field to mesh - more resolution (Message 1 to 10 of 31)
Subject: Height field to mesh - more resolution
Date: 29 Nov 2023 23:59:05
Message: <65681699$1@news.povray.org>
Greeting,
continuing experiments with Python (which continues to piss me off), I
decided to write small program to convert image heightfields into
triangle meshes. My may intention was to improve quality for
heightfields having both small image size and low bit depth - I supposed
that converting them into meshes will make POVRay interpolate
nonexisting data, thus improving visual appearance.
Attached is my test image 1.test grey 001.png, used as a heightfield
(with "smooth" on) for rendering 2.heightfield.jpg. Since the source is
only 64 * 64 pixels, result looks... well, correspondingly.
Next, I created my converter (attached as img2mesh.01.004.py.bz2) and
used it to convert the same source into triangle mesh. Rendering result
is attached as 3.img2mesh.01.004.jpg and, as you can see, it's clearer
but full of holes. After that I finally took a look at POVRay docs, that
say that POVRay internally uses 4 pixels for 2 triangles, just like my
program (never read docs before doing something yourself - it's
discouraging!), except for I didn't do force connection of square
corners, that lead to a holes. Instead of fixing it (I find fixing
discouraging too), I simply invented different approach - using 4 pixels
for 4 triangles (don't tell me if this is described somewhere already),
that lead to a completely different program, attached as
img2mesh.02.001.py.bz2), which provides output like attached
4.img2mesh.02.001.jpg.
The latter looks to me significantly better than POVRay heightfield
rendering (not to mention my first attempt), although I plan some
additional explorations (artifacts on flat surfaces are still
unexplained, and I even start to suspect POVRay roundoff errors).
Meanwhile, I hope someone will find this tiny utility useful, and
probably even come with new ideas.
Prerequisites:
1) Python (I used 3.12 but previous versions of Python 3 are supposed to
be fine). Seem to be preinstalled on many computers nowadays (that's how
I got it, for example). My program is equipped with minimal GUI, using
tkinter, which seem to be redistributed with all standard Python
distributions, so doesn't require separate download.
2) Pillow for reading images. As a simple image reading library, pillow
is distributed everywhere; at worst, it takes few seconds to download
and no seconds to install and configure.
So, have a day.
Ilya
Download '1.test grey 001.png' (2 KB) Download '2.heightfield.jpg' (9 KB) Download 'img2mesh.01.004.py.bz2.zip' (3 KB) Download '3.img2mesh.01.004.jpg' (14 KB) Download 'img2mesh.02.001.py.bz2.zip' (2 KB) Download '4.img2mesh.02.001.jpg' (10 KB)
Preview of image '1.test grey 001.png'
Preview of image '2.heightfield.jpg'
Preview of image '3.img2mesh.01.004.jpg'
Preview of image '4.img2mesh.02.001.jpg'
Subject: Re: Height field to mesh - more resolution
Date: 30 Nov 2023 09:00:00
Message: <web.656895462c1eda44f11225116cde94f1@news.povray.org>
hi,
Ilya Razmanov <ily### [at] gmailcom> wrote:
> Greeting,
> triangle meshes. ...
> rendering ...
for data "extrapolated" from a 64x64 image, that last image looks real good I
think.  wondering if the calculation could not be done in SDL ?
regards, jr.
Date: 30 Nov 2023 21:21:56
Message: <65694344$1@news.povray.org>
For this to be done within POVRay only, I need:
1) POVRay opening image as some sort of array with easy access to any
pixel data I want
2) Not only math but some programming (I need cycles first of all)
What as to 1), surely, POVRay have something to read images - after all,
it uses images as heightfield, that requires image reading and
representation as some data structure internally. But I see no way for
*me* to access these data directly. Well, after all, POVRay is neither a
bitmap editor, nor a programming environment (or, as our CC said,
"neither both"). So, I use external tool, taking advantage of that POV
language is simple text, easy to understand and write. I used Python
since I got my Windows notebook with Python 3.8 preinstalled, and I was
curious enough to take a look at what is this and what it is good for.
As long as I know, it also comes preinstalled with Linux, and, in
general, looks to be more widely available than POVRay itself, that
makes my tiny programs cross-platform. And, since POV files are so easy
to write, why not to use this advantage of POVRay? ;-)
Ilya
Date: 30 Nov 2023 23:55:00
Message: <web.656965f42c1eda44f11225116cde94f1@news.povray.org>
hi,
> pixel data I want
aiui, POV-Ray (as of 3.7) has the "tools", and your first script (the spheres
image) would, I think, be fairly straightforward to code up in SDL.  hence my
question re the details of the height_field processing.
:-)  I'm sure many/most (can) use Python, but all of us have POV-Ray to use.
regards, jr.
Date: 1 Dec 2023 01:50:00
Message: <web.656981f02c1eda4417bac71e8ffb8ce3@news.povray.org>
> pixel data I want
you can use an image as a pattern and you can use a pattern in a function. Then
you can sample the "image function" to fill arrays. But, the image will already
be interpolated.
ingo
Date: 1 Dec 2023 02:05:00
Message: <web.6569853a2c1eda44f11225116cde94f1@news.povray.org>
> ...> > For this to be done within POVRay only, I need:
> aiui, POV-Ray (as of 3.7) has the "tools", ...
proof of concept (640x480 image source).  ~20 minutes ;-)
regards, jr.
-----<snip>-----
/* cf Iyla's "spheres" script */
#version 3.8;
#include "functions.inc"
global_settings {assumed_gamma 1}
#declare im_ = pigment {
  image_map {
    png "s_o_l.png"
    gamma 1
  scale <640,480,1>
#declare ext_ = max_extent(im_);
#declare arr_ = array [640][480];
#for (r_,0,479)
  #for (c_,0,639)
    #local arr_[c_][r_] = eval_pigment(im_,<c_,r_,.5>);
#for (r_,0,479)
  #for (c_,0,639)
    sphere {
      <(c_+.5),(r_+.5),0>, .495
        pigment {arr_[c_][r_]}
        finish {emission 1}
  location <320,240,-275>
  right x * (4/3)
  up y
  angle 90
  look_at <320,240,0>
Download '231201_ir.png' (960 KB)
Preview of image '231201_ir.png'
Date: 1 Dec 2023 03:15:41
Message: <6569962d$1@news.povray.org>
Op 1-12-2023 om 08:03 schreef jr:
LOL!
Date: 1 Dec 2023 09:13:40
Message: <6569ea14$1@news.povray.org>
On 12/1/23 02:03, jr wrote:
> proof of concept (640x480 image source).  ~20 minutes 😉
This a good example to show the value of the yuqk / v4.0 idea of
providing a 'munctions.inc' / macro defined functions include.
The yuqk fork has no 'eval_pigment', but it does have a munction called
   M_evaluate_pigment(). The following runs in about 4.5 seconds,
elapsed, on my old i3.
In this case, I think, you can mostly emulate what was done with
M_evaluate_pigment() in official releases of POV-Ray - to some degree or
other.
Bill P.
----- snip ------
#version unofficial 3.8; // yuqk
#if (file_exists("version.inc"))
     #include "version.inc"
#if (!defined(Fork_yuqk))
     #error "This POV-Ray SDL code requires the yuqk fork."
#declare Grey50 = srgb <0.5,0.5,0.5>;
background { Grey50 }
#declare VarOrthoMult =
     2.0/max(image_width/image_height,image_height/image_width);
#declare Camera01z = camera {
     orthographic
     location <0,0,-2>
     direction z
     right VarOrthoMult*x*max(1,image_width/image_height)
     up VarOrthoMult*y*max(1,image_height/image_width)
#declare PigIm = pigment {
     image_map {
         png "Test680x480.png"
         gamma srgb
         interpolate 0
     scale <640,480,1>
#include "munctions.inc"
// Following defines FnPg00() so it can be used directly.
#declare Vec00 =
M_evaluate_pigment("FnPg00",PigIm,<0,0,0>,false);
//--- scene ---
union {
#for (R,0,479)
     #for (C,0,639)
         sphere {
           <(C+.5),(R+.5),0>, .495
                 // Can call 'munction' repeatedly too, but it's
                 // 2x slower than FnPg00() due the macro call.
               //color
               //M_evaluate_pigment("FnPg00",PigIm,<C,R,0>,false)
                 color FnPg00(C,R,0)
             finish {emission 1}
scale <1/640,1/480,1>
translate <-0.5,-0.5,0>
scale <VarOrthoMult*max(1,image_width/image_height),
     VarOrthoMult*max(1,image_height/image_width),
     1>
camera { Camera01z }
----- snip ------
Download 'jr.png' (33 KB)
Preview of image 'jr.png'
Date: 1 Dec 2023 10:10:46
Message: <6569f776$1@news.povray.org>
On 12/1/23 09:13, William F Pokorny wrote:
> This a good example
Apologies for attaching the pointless image. Foggy mind / autopilot :-(
Bill P.
Date: 1 Dec 2023 11:25:00
Message: <web.656a07e52c1eda44f11225116cde94f1@news.povray.org>
hi,
that's pretty good.  modifying my posted code to junk the array and call
'eval_pigment' inside the 'texture{}', I get parsing down to just under 5.5 secs
(plus ~1s render) using the beta.2.
have not tried tried to install the renamed branch yet, will try later tonight
to get your code to run with last-but-one-before-renaming version.
@Ilya
sorry about misspelling your name in the posted scene code, have corrected my
local copy.
regards, jr.
