POV-Ray : Newsgroups : povray.general : Request for Comments: Quadratic Bezier Splines Server Time
21 Jun 2026 19:03:47 EDT (-0400)
  Request for Comments: Quadratic Bezier Splines (Message 1 to 10 of 23)
Subject: Request for Comments: Quadratic Bezier Splines
Date: 6 Jun 2021 17:52:34
Message: <60bd43a2$1@news.povray.org>
Hi folks,
the `prism` primitive currently supports, among others, cubic Bezier
spline outlines.
For certain technical reasons, I may need to add support for _quadratic_
Bezier splines at the render engine level as well, but it would be a
waste to not expose them to the scene description language (and, while
I'm at it, possibly also extend `lathe` accordingly).
An open question is, what keyword should be used for this type of spline?
For the records:
- Quadratic Bezier splines are a flavor of quadratic splines, aka 2nd
order polynomial splines.
- Quadratic splines are also occasionally referred to as "conic splines"
or "conic arcs", for reasons I'm not entirely sure of.
- `bezier_spline` is the current moniker for cubic Bezier splines.
- `quadratic_spline` is already in use for some quirky flavor of
quadratic spline that, in my mind, doesn't even deserve to live, but has
a long-standing tradition of existing under this moniker and therefore
isn't going anywhere in POV-Ray v3.x.
Here are some ideas:
- `quadratic_bezier_spline`, being the most accurate term.
- `conic_bezier_spline`, being a bit shorter.
- `conic_spline`, being yet shorter.
- `bezier2_spline`, the "2" referring to the polynomial order.
Personally, I'm somewhat unhappy with the very first for being rather
verbose, and the third for being prone to confusion with both
`cubic_spline` and `conic_sweep`, the latter being also used in `prism`.
I'm also not quite happy with the second one, because it's still
somewhat lengthy, and I think it isn't the most accurate of terms.
Thoughts, anyone?
Subject: Re: Request for Comments: Quadratic Bezier Splines
Date: 6 Jun 2021 18:35:00
Message: <web.60bd4c5084e2d21b7a6f5201f712fc00@news.povray.org>
> Hi folks,
> spline outlines.
> For the records:
 I like the last one 'bezier2_spline'
To tell the truth I had to look up the quadratic bezier spline, to see how it
worked. I have looked at pov sorce code to help my prism/polygon program match
pov prisms better.
 After reading about the quadratic bezier spline I was wondering why it wasn't
already a part of prisms. It seems a logic step up from the other splines
leading to the qubic bezier spline. But having said that, Now it seems a step
back. I rarely use any thing but the cubic to make prisms.
Have Fun!
Date: 6 Jun 2021 18:45:00
Message: <web.60bd4ee884e2d21b1f9dae3025979125@news.povray.org>
> Hi folks,
> spline outlines.
> <snip>
> Thoughts, anyone?
thoughts:
used in fonts/typfaces and svg representations of glyphs.  Cousin Ricky was nice
enough to provide me with an early release of his sphere sweep macro that allows
QBS.
degree.
So, you may not have to code a whole separate section for QBS - just write an
algorithm to degree-elevate a QBS to a cubic.  I have my SDL version that you
can have to adapt into suitable c++ source code.
IIRC degree reduction was a bit trickier, and I hadn't implemented that.
maybe he already has something to do that side of the degree manipulation.
What would be very nice would be a generic "bezier" keyword followed by the
desired degree, or perhaps, by the degree of the supplied control points
followed by the desired degree after elevation / reduction.
But that is JUST something to think about, before anything becomes "concrete".
Does that help?  :D
Date: 6 Jun 2021 19:16:52
Message: <60bd5764$1@news.povray.org>
I just wanted to point out that there seems to be something wrong with
the web interface.
I just posted this, and when I went to read it, it was corrupted.   But
the strange thing is, the post looks FINE when I open it in Thunderbird.
So it's getting written properly, but read/displayed improperly.
Here's what it looks like in the web interface, for anyone reading with
Thunderbird:
thoughts:
was nice
that allows
QBS.
degree.
write an
that you
"concrete".
Does that help?  :D
Date: 6 Jun 2021 20:10:45
Message: <60bd6405$1@news.povray.org>
Am 07.06.2021 um 01:16 schrieb Bald Eagle:
> the web interface.
Yes, it looks like the web interface mangles anything with non-ASCII
characters. Such as in Mr. Bezier's properly-spelled name.
Date: 6 Jun 2021 20:24:23
Message: <60bd6737$1@news.povray.org>
Am 07.06.2021 um 00:40 schrieb Bald Eagle:
> QBS.
> degree.
As a matter of fact, fonts is exactly the topic I'm implementing this
for in the first place, because I'm working on throwing out our
dedicated `text` shape rendering code and replacing it with `prism`
under the hood.
And yes, so far I have been using degree-elevation to map conic outlines
to cubic ones as already supported by `prism`.
But this turns out to come at the cost of slower render times, and I
have a hunch that's because TrueType fonts exclusively use conic (or
linear) outline segments, so by adding native support for conic bezier
outlines I hope to regain some of the lost performance.
Date: 6 Jun 2021 22:00:00
Message: <web.60bd7d7984e2d21b1f9dae3025979125@news.povray.org>
> under the hood.
Very nice.  I recall that was one of the things on your list.  Maybe the visual
quality of the fonts will improve with the new implementation.
Of course you have.  :D
Your toolbox of coding stuff must be astonishing to behold.
So, it hit me - while trying to get to sleep, of course - that something useful
would be to have an outline-only version of the text object - that traces out
the ttf outlines without filling them in like a prism would do.  I know a lot of
people have played with various font projects, and this would save a lot of work
in achieving the end-results.
keyword could be outline_text or text2 or something.
I don't know if daisy-chaining the spline with a sphere sweep would be the way
to go, or maybe if there's some way to take the font segment data and make it
visible to the SDL in the form of an array or something.  I've seen some very
nice technical drawings when I was researching working with the splines and font
data, and I think that such a an additional low-level tool would be attractive
to folks who work with typefaces and might want to make technical drawings,
presentations explaining how fonts are drawn, etc.
http://www.mathisintheair.org/wp/wp-content/uploads/2015/03/G-45-90_5373.gif
It would also be a very nice way to have the font data at one's fingertips in
case a user wanted to make small edits to the coordinates, or anything else
requiring the actual font data.
I'm not sure how much of your work would cross over into making SVG a useable
format, but maybe that's something to keep in mind and at least plop a juicy
comment into the source code.  ;)
Date: 6 Jun 2021 22:24:22
Message: <60bd8356$1@news.povray.org>
Am 07.06.2021 um 03:59 schrieb Bald Eagle:
Well, that didn't go as planned...
As it turns out, converting conic-outline fonts straight to 2nd order
Bezier `prism`s (amended to provide direct support) is actually slower.
My hunch is that it results in poorer bounding, because elevating the
order also "tightens" the control points, and I suspect the `prism`
bounding computations just plain braindeadly bound to the convex hull of
the control points.
So there might still be potential there, but not the low-hanging fruit I
was hopong for.
Also, turns out that the loss of performance was just empty prisms I
created for whitespace characters. Which is of course dumb. Now that
I've fixed that, rendering of text actually seems to be faster than ever
before.
Oh, there's plenty of potential there for such things indeed.
One day, one fine morning, all the spline-related features will be
combined into one glorious unified system, and text will just be another
source of splines.
Date: 7 Jun 2021 05:36:31
Message: <XnsAD42761851048seed7@news.povray.org>
in news:60bd43a2$1@news.povray.org clipka wrote:
> Thoughts, anyone?
as it is clear that it is a spline, or curve, bezier2, bezier3
A few minutes ago in http://news.povray.org/povray.binaries.scene-
files/message/%3CXnsAD427355E3A62seed7%40news.povray.org%3E/#%
3CXnsAD427355E3A62seed7%40news.povray.org%3E I posted a new version of a
curvers / splines include file. I think the concept would make a nice
addition to POV-Ray if implemented in C++ (that I sadly don't speak) as a
substitute/addition to the current splines.
https://ingoogni.nl
Date: 7 Jun 2021 08:33:55
Message: <60be1233$1@news.povray.org>
> quadratic spline that, in my mind, doesn't even deserve to live, [snip]
I'm inclined to agree with you there.  And I will speculate that Bald
Eagle also agrees.
For what it's worth, when I implemented the quadratic Bezier sphere
sweep in the Object Collection, I used the name SSWP_BEZIER2_SPLINE to
select that spline type.  So of course I'm biased in favor of the last
option.
