POV-Ray : Newsgroups : povray.general : chr(0) problem Server Time
24 May 2026 16:56:02 EDT (-0400)
  chr(0) problem (Message 1 to 10 of 24)
Subject: chr(0) problem
Date: 28 Feb 2002 05:35:57
Message: <5m0s7usm1t32sajav9eou78e4tbfr9f21v@4ax.com>
any idea how to add to string or write into file chr(0) ?
it is the only limit to write binary files :-(
(treat it as feature request if it is not possible)
ABX
Subject: Re: chr(0) problem
Date: 28 Feb 2002 06:10:04
Message: <3C7E1031.F8CEFDE9@namtar.qub.ac.uk>
> ABX
"\0" writes the null character.
signature{
Date: 28 Feb 2002 06:14:07
Message: <3c7e10ff@news.povray.org>
As you might know, you are not supposed to be able to write binary files...
    Thorsten
e-mail: tho### [at] trfde
Date: 28 Feb 2002 06:27:04
Message: <0n4s7ug2ce25efi7tli2vv7vdpt345ac0g@4ax.com>
On Thu, 28 Feb 2002 12:14:05 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Yes, I suppose there wasn't such idea in design of POV. Anyway I wan't try to
write DF3 file and use it within the same parse. It's just the 3d version of
image function and I found it useful in my current task.
ABX
Date: 28 Feb 2002 06:44:45
Message: <0u5s7uoktp549usmnn8sn3q1rtugp730e2@4ax.com>
On Thu, 28 Feb 2002 11:10:41 +0000, Grey Knight <s16### [at] namtarqubacuk>
#write(DF3,"\0" <----ERROR
Parse Error: Illegal escape sequence in string.
ABX
Date: 28 Feb 2002 07:03:23
Message: <3C7E1C7D.C4F9EC96@namtar.qub.ac.uk>
Oh dear. What exactly was \0 put in for if you can't write it to a file?
It's not like it makes any sense to put it in a text string...
> ABX
signature{
Date: 28 Feb 2002 07:14:18
Message: <9h7s7uovnvah261sdpgrhgoar29fd73o4m@4ax.com>
On Thu, 28 Feb 2002 12:03:09 +0000, Grey Knight <s16### [at] namtarqubacuk>
From documentation: "Depending on what platform you are using, they may not be
fully supported for console output. However they will appear in any text file
if you re-direct a stream to a file."
When I tried it with #warning it produced the same error message.
So, does it means bug ? Should I repost it into beta-test ?
ABX
Date: 28 Feb 2002 07:28:43
Message: <3c7e227b@news.povray.org>
Well, whatever the documentation wants to say with this, a "\0" is converted
to a backslash in at least 3.1 and 3.5.  It is obvious that "\0" cannot be
supported because C strings use it as terminator, so it should probably be
removed from the documentation altogether.
BTW, note that the quote you provided only talks about output streams, not the
file #write directive!
    Thorsten
Date: 28 Feb 2002 07:36:32
Message: <8r8s7u07h0qd6lipk3pfd4ltae7i3pgoai@4ax.com>
On Thu, 28 Feb 2002 13:28:42 +0100, "Thorsten Froehlich" <tho### [at] trfde>
Worse luck!
Yes, I noticed. But of course I tested it with #warning before quoting.
The solution I choosed is to limit range to 1-255. I hope it will be
sufficient.
ABX
Date: 28 Feb 2002 08:57:06
Message: <3c7e3732@news.povray.org>
"Thorsten Froehlich" <tho### [at] trfde> wrote in message
news:3c7e10ff@news.povray.org...
files...
By the way, why there is such a limitation? It should be useful.
Gleb
