POV-Ray : Newsgroups : povray.general : Speeding up rendering many spheres Server Time
29 Apr 2024 04:07:50 EDT (-0400)
  Speeding up rendering many spheres (Message 4 to 13 of 13)
<<< Previous 3 Messages Goto Initial 10 Messages
Subject: Re: Speeding up rendering many spheres
Date: 6 May 2020 14:05:59
Message: <5eb2fc87$1@news.povray.org>
William F Pokorny , dans le message <5eb2e4cd$1@news.povray.org>, a
> Have you looked at bounding mode 2 (+bm2)? If not that's worth a shot.
I just tried with 20k spheres, it did not make a visible difference.
> Related: There are issues in v37 and the official v38 branch - mitigated
> 'somewhat' in my povr solver branch - with tiny sphere intersections
> getting dropped when they should not be. Applies to a few other objects
> too a situations too. Depends on exactly how the rays approach.
> This can affect Anti-Aliasing time somewhat substantially because the
> spheres are basically blinking in and out of existence...  There is,
> IIRC, some related discussion buried in the github pull req #358 comments.
> https://github.com/POV-Ray/povray/pull/358
I am using the version packages by Debian, they say it is a 3.7.0.8. Anyway,
you tell me there is a problem with sphere intersections, but my scene only
has merges, so I should be safe?
What I am really asking is:
merge {
  A
  B
merge {
  merge { A }
  merge { B }
where A and B are small and made of many tiny objects close together, but
they are far apart from each other.
Will the second version be faster because POV-Ray will compute a bounding
box for the two sub-merges, or shall I write:
merge {
  merge { A bounded_by box_A }
  merge { B bounded_by box_B }
I shall test, but it would be helpful to know what is supposed to be the
result.
Thanks for your help.
Date: 6 May 2020 14:08:54
Message: <5eb2fd36@news.povray.org>
"Bald Eagle" , dans le message
> For bounding, blobs are apparently the way to go.
I doubt it. The principle of bounding box is that they need to be as fast as
possible, while blobs are vey slow.
> For pseudo-sphere-sweeps, I always use a sphere followed by checking if it's the
> first sphere or not.
> If not, then I draw a cylinder from the last sphere to this sphere.
> Save this sphere in a variable for the next loop.
> In your case with varying radii, you can use cones instead of cylinders.
> Perhaps if that works well enough to fill in the space, then you can even
> decrease the number of spheres you use drastically.
I think I was not clear enough in my first question: the scene is done, it
is made of sphere, they are already computed, I am satisfied with it. I only
need help to get POV-Ray to render it before the end of the century.
> Alternately, and I have no idea if this has any advantage - you could
> model a sphere as a mesh or mesh 2 unit sphere base object and just scale
> and translate it.  But that might only save memory, not speed up the
> rendering.
I doubt that a mesh will take less memory than a sphere.
Date: 6 May 2020 14:44:15
Message: <5eb3057f$1@news.povray.org>
> result.
I ran the test, with the scene below.
My conclusion is that POV-Ray does not try to compute bounding boxes for
components of a CSG object.
Can somebody confirm it is the expected behavior?
Well, that means I should gain a significant speed improvement by computing
intermediate bounding boxes before rendering.
As a side note: maybe a directive auto_bounding_box would be a good idea to
let the scene author hint POV-Ray: "this is a very complex CSG object, but
this part is small, it deserves its own bounding box".
My test scene:
  location <0, 0, -2>
  look_at <0, 0, 0>
#macro many_spheres(x0, y0, z0)
  #local i = -10;
  #while (i <= 10)
    #local j = -10;
    #while (j <= 10)
      #local k = -10;
      #while (k <= 10)
        sphere { <x0 + 0.001 * i, y0 + 0.001 * j, z0 + 0.001 * k>, 0.0008 }
        #local k = k + 1;
      #local j = j + 1;
    #local i = i + 1;
merge {
  //merge {
    many_spheres(-0.5, 0.5, 0)
    //bounded_by { box { <-0.52, 0.48, -0.02>, <-0.48, 0.52, 0.02> } }
  //merge {
    many_spheres(0.5, -0.5, 0)
    //bounded_by { box { <0.48, -0.52, -0.02>, <0.52, -0.48, 0.02> } }
  pigment { rgb <1, 1, 0> }
  finish { ambient 1 }
// with bounded_by:  using 8 thread(s) with 3.698 CPU-seconds total
// without:          using 8 thread(s) with 137.005 CPU-seconds total
// without submerge: using 8 thread(s) with 136.182 CPU-seconds total
Date: 6 May 2020 14:46:04
Message: <5eb305ec$1@news.povray.org>
Le 2020-05-06 à 11:47, Nicolas George a écrit :
> Hi.
> I have a scene made of 200k spheres merged on a path (like a sphere_sweep,
> but with changing pigment and a ringed look), few are big, many are tiny and
> barely visible. Unsurprisingly, it is taking forever to render.
> I am looking for ways to speed it up.
> My attempt was to group the spheres in sub-merges, and let POV-Ray compute
> bounding boxes for these groups. It helps, a little, but not much. Not
> enough to make the scene possible.
> My next attempt would probably be to try to add explicit bounded_by on the
> groups.
> I could experiment by myself, but people here probably have insight: do you
> have advice on the most efficient way to speed this up?
> Thanks in advance.
If those spheres are not transparent, then, you need to replace that
merge with an union.
Maybe only have the big one in merge and the small and tiny in unions.
That way, your bounding will get much more efficient.
As the tiny are barely visible, changing from merge to union won't make
any visible difference. Also, having those opaque instead of transparent
should have only minimal effect.
I don't think that manual bounding could help.
Date: 6 May 2020 14:54:38
Message: <5eb307ee$1@news.povray.org>
>   écrit :
> merge {
>    A
>    B
> merge {
>    merge { A }
>    merge { B }
In that case, use:
union{
   merge{ A }
   merge{ B }
> merge {
This will NOT help in any way.
> result.
Whenever you merge several primitives, they always share a single
bounding box. Any ray entering that bounding box must test for
everything it contains. ANY internal and manual bounding within that
merge is totally ignored. That's why merge is so slow.
The purpose of merge is to suppress the internal surfaces when you have
a transparent object.
So, if you don't use transparency, always use union, never merge.
If you have disconnected transparent components, use an union for them.
Date: 6 May 2020 14:58:43
Message: <5eb308e3$1@news.povray.org>
Slow, yes, but not as slow as a merge of 100's of objects. If you have a
few K objects, the blob get much faster than a merge.
Date: 6 May 2020 15:02:41
Message: <5eb309d1$1@news.povray.org>
Le 2020-05-06 à 14:44, Nicolas George a écrit :
>> result.
> My test scene:
> camera {
>    location <0, 0, -2>
>    look_at <0, 0, 0>
>    #local i = -10;
>    #while (i <= 10)
>      #local j = -10;
>      #while (j <= 10)
>        #local k = -10;
>        #while (k <= 10)
>          #local k = k + 1;
>        #end
>        #local j = j + 1;
>      #end
>      #local i = i + 1;
>    #end
> #end
> merge {
>    //merge {
>    //merge {
In this sample, you have pigment{rgb<1,1,0>}
This have zero transparency. Meaning that you should absolutely use an
union and not a merge.
It becomes :
union{
Date: 6 May 2020 15:06:58
Message: <5eb30ad2@news.povray.org>
>   écrit :
Ah, thanks for pounding home that you are using merge{}.
Try changing all merges to unions(1). Then perhaps +bm2 - for which
there are a lot of tuning parameters I've played with only a little -
might help. Just the merge to union probably more than enough speed up
unless you're after real time rendering speeds or something.
Ignore my aside on the intersection depth issues (really a couple). Any
real fix / improvement there is as likely to cost you time as not. If
you're doing heavy AA though turning it off, rendering larger and
scaling down 'might' be faster.
If you are using SDL to create those spheres, parsing could be a
significant part of the total run time. Do you know how much time
parsing and how much time rendering?
Somewhere I have some test cases with spheres. Let me see.... Yep. The
one from the github comments.
\time povr2 +w900 +h600 attractors.pov
2 million spheres in unions each with textures.
Parsing 17.325s / Bounding m1 3.504s
povr2 +w900 +h600
Render on my two core i3 : 33.781 seconds
Total CPU measured with \time : 136.43user 0:55.83elapsed
Memory about 1.5G
p380 (same as above,but many sphere intersections are dropped in v37/v38
107.96user 0.61system 0:45.06elapsed
Bill P.
(1) Unions unnest and so 'might' be better handled by the default
bounding or +bm2.
Date: 6 May 2020 15:21:54
Message: <5eb30e52@news.povray.org>
Before starting, I ran a few small tests and found that merge was slightly
faster. I suppose they were too small to be significant. Indeed, with the
full scene, union is incredibly faster than merge. I should have re-tested
earlier.
Thanks.
Date: 6 May 2020 17:10:07
Message: <web.5eb326caddc056181b6c6b3a0@news.povray.org>
Without knowing where your path came from, or quite what 'ringed look' means, my
suggestion might be useless to you, so apologies in advance!
However, in this situation I think I would seriously consider building this as a
mesh, creating a ring of triangles for each point of the path. Triangle rings
can be given different textures, either picked from a list (mesh2), or UV-mapped
from a gradient of your pigment 'space'. Parsing might still take some time, but
I would think rendering would be pretty fast.
Bill
