POV-Ray : Newsgroups : povray.general : Speeding up rendering many spheres Server Time
16 May 2026 12:55:08 EDT (-0400)
  Speeding up rendering many spheres (Message 1 to 10 of 13)
Subject: Speeding up rendering many spheres
Date: 6 May 2020 11:47:59
Message: <5eb2dc2f@news.povray.org>
Hi.
I have a scene made of 200k spheres merged on a path (like a sphere_sweep,
but with changing pigment and a ringed look), few are big, many are tiny and
barely visible. Unsurprisingly, it is taking forever to render.
I am looking for ways to speed it up.
My attempt was to group the spheres in sub-merges, and let POV-Ray compute
bounding boxes for these groups. It helps, a little, but not much. Not
enough to make the scene possible.
My next attempt would probably be to try to add explicit bounded_by on the
groups.
I could experiment by myself, but people here probably have insight: do you
have advice on the most efficient way to speed this up?
Thanks in advance.
Subject: Re: Speeding up rendering many spheres
Date: 6 May 2020 12:24:45
Message: <5eb2e4cd$1@news.povray.org>
On 5/6/20 11:47 AM, Nicolas George wrote:
> Hi.
> groups.
> Thanks in advance.
Have you looked at bounding mode 2 (+bm2)? If not that's worth a shot.
Related: There are issues in v37 and the official v38 branch - mitigated
'somewhat' in my povr solver branch - with tiny sphere intersections
getting dropped when they should not be. Applies to a few other objects
too a situations too. Depends on exactly how the rays approach.
This can affect Anti-Aliasing time somewhat substantially because the
spheres are basically blinking in and out of existence...  There is,
IIRC, some related discussion buried in the github pull req #358 comments.
https://github.com/POV-Ray/povray/pull/358
Bill P.
Date: 6 May 2020 13:30:01
Message: <web.5eb2f40cddc05618fb0b41570@news.povray.org>
For bounding, blobs are apparently the way to go.
I guess you can use a strength of 1 and that should be a good starting point.
For pseudo-sphere-sweeps, I always use a sphere followed by checking if it's the
first sphere or not.
If not, then I draw a cylinder from the last sphere to this sphere.
Save this sphere in a variable for the next loop.
In your case with varying radii, you can use cones instead of cylinders.
Perhaps if that works well enough to fill in the space, then you can even
decrease the number of spheres you use drastically.
Alternately, and I have no idea if this has any advantage - you could model a
sphere as a mesh or mesh 2 unit sphere base object and just scale and translate
it.  But that might only save memory, not speed up the rendering.
Date: 6 May 2020 14:05:59
Message: <5eb2fc87$1@news.povray.org>
William F Pokorny , dans le message <5eb2e4cd$1@news.povray.org>, a
I just tried with 20k spheres, it did not make a visible difference.
I am using the version packages by Debian, they say it is a 3.7.0.8. Anyway,
you tell me there is a problem with sphere intersections, but my scene only
has merges, so I should be safe?
What I am really asking is:
merge {
  A
  B
merge {
  merge { A }
  merge { B }
where A and B are small and made of many tiny objects close together, but
they are far apart from each other.
Will the second version be faster because POV-Ray will compute a bounding
box for the two sub-merges, or shall I write:
merge {
  merge { A bounded_by box_A }
  merge { B bounded_by box_B }
I shall test, but it would be helpful to know what is supposed to be the
result.
Thanks for your help.
Date: 6 May 2020 14:08:54
Message: <5eb2fd36@news.povray.org>
"Bald Eagle" , dans le message
I doubt it. The principle of bounding box is that they need to be as fast as
possible, while blobs are vey slow.
I think I was not clear enough in my first question: the scene is done, it
is made of sphere, they are already computed, I am satisfied with it. I only
need help to get POV-Ray to render it before the end of the century.
> model a sphere as a mesh or mesh 2 unit sphere base object and just scale
> and translate it.  But that might only save memory, not speed up the
> rendering.
I doubt that a mesh will take less memory than a sphere.
Date: 6 May 2020 14:44:15
Message: <5eb3057f$1@news.povray.org>
> result.
I ran the test, with the scene below.
My conclusion is that POV-Ray does not try to compute bounding boxes for
components of a CSG object.
Can somebody confirm it is the expected behavior?
Well, that means I should gain a significant speed improvement by computing
intermediate bounding boxes before rendering.
As a side note: maybe a directive auto_bounding_box would be a good idea to
let the scene author hint POV-Ray: "this is a very complex CSG object, but
this part is small, it deserves its own bounding box".
My test scene:
  location <0, 0, -2>
  look_at <0, 0, 0>
#macro many_spheres(x0, y0, z0)
  #local i = -10;
  #while (i <= 10)
    #local j = -10;
    #while (j <= 10)
      #local k = -10;
      #while (k <= 10)
        sphere { <x0 + 0.001 * i, y0 + 0.001 * j, z0 + 0.001 * k>, 0.0008 }
        #local k = k + 1;
      #local j = j + 1;
    #local i = i + 1;
merge {
  //merge {
    many_spheres(-0.5, 0.5, 0)
    //bounded_by { box { <-0.52, 0.48, -0.02>, <-0.48, 0.52, 0.02> } }
  //merge {
    many_spheres(0.5, -0.5, 0)
    //bounded_by { box { <0.48, -0.52, -0.02>, <0.52, -0.48, 0.02> } }
  pigment { rgb <1, 1, 0> }
  finish { ambient 1 }
// with bounded_by:  using 8 thread(s) with 3.698 CPU-seconds total
// without:          using 8 thread(s) with 137.005 CPU-seconds total
// without submerge: using 8 thread(s) with 136.182 CPU-seconds total
Date: 6 May 2020 14:46:04
Message: <5eb305ec$1@news.povray.org>
Le 2020-05-06 à 11:47, Nicolas George a écrit :
> Hi.
> groups.
> Thanks in advance.
If those spheres are not transparent, then, you need to replace that
merge with an union.
Maybe only have the big one in merge and the small and tiny in unions.
That way, your bounding will get much more efficient.
As the tiny are barely visible, changing from merge to union won't make
any visible difference. Also, having those opaque instead of transparent
should have only minimal effect.
I don't think that manual bounding could help.
Date: 6 May 2020 14:54:38
Message: <5eb307ee$1@news.povray.org>
>   écrit :
> merge {
>    A
>    B
> merge {
>    merge { A }
>    merge { B }
In that case, use:
union{
   merge{ A }
   merge{ B }
> merge {
This will NOT help in any way.
> result.
Whenever you merge several primitives, they always share a single
bounding box. Any ray entering that bounding box must test for
everything it contains. ANY internal and manual bounding within that
merge is totally ignored. That's why merge is so slow.
The purpose of merge is to suppress the internal surfaces when you have
a transparent object.
So, if you don't use transparency, always use union, never merge.
If you have disconnected transparent components, use an union for them.
Date: 6 May 2020 14:58:43
Message: <5eb308e3$1@news.povray.org>
Slow, yes, but not as slow as a merge of 100's of objects. If you have a
few K objects, the blob get much faster than a merge.
Date: 6 May 2020 15:02:41
Message: <5eb309d1$1@news.povray.org>
Le 2020-05-06 à 14:44, Nicolas George a écrit :
>> result.
> My test scene:
> camera {
>    location <0, 0, -2>
>    look_at <0, 0, 0>
>    #local i = -10;
>    #while (i <= 10)
>      #local j = -10;
>      #while (j <= 10)
>        #local k = -10;
>        #while (k <= 10)
>          #local k = k + 1;
>        #end
>        #local j = j + 1;
>      #end
>      #local i = i + 1;
>    #end
> #end
> merge {
>    //merge {
>    //merge {
In this sample, you have pigment{rgb<1,1,0>}
This have zero transparency. Meaning that you should absolutely use an
union and not a merge.
It becomes :
union{
