POV-Ray : Newsgroups : povray.general : CNRS Server Time
20 Jun 2026 05:57:47 EDT (-0400)
  CNRS (Message 1 to 8 of 8)
Subject: CNRS
Date: 19 Oct 2019 11:55:39
Message: <5dab31fb$1@news.povray.org>
Is it possible to translate the following equation with POV-Ray ?
	<https://imaginary.github.io/80-cnrs/>
I don't know how to begin ... It's an interesting problem :-)
Best regards,
Author of Eureka 2.12 (2D Graph Describer, 3D Modeller)
http://eureka.atari.org/
Subject: Re: CNRS
Date: 19 Oct 2019 14:05:00
Message: <web.5dab504846c52bde4eec112d0@news.povray.org>
Francois LE COAT <lec### [at] atariorg> wrote:
Hello friend,
Try the following and let me know how it works out   :)
// rearranging a bit and deleting extra unnecessary parentheses gives:
10*e
#declare e = exp(1);//2.71828182845904523536028747135266249775724709369996;
// or #include "consts.inc"
// then just convert to SDL syntax (* this is untested)
#declare Equation = function (x, y, z, a, b, c, d) {
( pow (pow (x+2*a, 2) + pow (y+2*b, 2)-1, 2)     - c+pow(2*z, 2) + d*pow (y+2*b,
2) ) *
( pow (pow (x+2*a, 2) + pow (y-2*b, 2)-1, 2)     - c+pow(2*z, 2) + d*pow (y-2*b,
2) ) *
( pow (pow (x-2*a, 2) + pow (y(2*b+1), 2)-1, 2)  - c+pow(2*z, 2) + d*pow
(y/(2*b+1), 2) ) -
10 * e}
// Define a, b, c, and d
// and then plug it into an isosurface declaration,
// preferably with the max_gradient estimatiing equation
// to speed things up a bit.
// render with a very low accuracy to start:  maybe 0.1
// I'd also keep lighting and textures the simplest possible, perhaps only using
a
// finish {specular 0.2} or 0.4
Subject: Re: CNRS
Date: 19 Oct 2019 14:50:00
Message: <web.5dab5a0e46c52bde4eec112d0@news.povray.org>
OK, so I couldn't help myself.
Here's a working scene with good starting values for a through d, and some
initial ideas about what those parameters affect.
// Bill Walker "Bald Eagle" October 2019
// scene for Francois LE COAT
// based on equation for the SURFER application at:
// https://imaginary.github.io/80-cnrs/
#version 3.8;
global_settings {assumed_gamma 1.0 }
#include "functions.inc"
#include "math.inc"
 location <0, 6.5, -15>
 //location <0, 10, 3>
 up y
 look_at <0, -2, 0>
 //rotate -y*155
sky_sphere {pigment {rgb 1}}
light_source {<2, 5, -10> rgb 1}
//light_source {<-10, 8, -1> rgb 0.8} // fill light
#declare Tan = texture {pigment {rgb <0.92, 0.60, 0.20>} finish {specular 0.2}}
#declare Tan2 = texture {pigment {rgb <0.92, 0.60, 0.20>} finish {diffuse 0.7
specular 0.2 reflection 0.02}}
#declare Gray = texture {pigment {rgb 0.5}}
#declare Gray2 = texture {pigment {rgb 0.5}finish {diffuse 0.7 specular 0.2
reflection 0.02}}
#declare Shade = 1;
#declare   _Red = texture {pigment {rgb <1, 0, 0>*Shade} finish {diffuse 0.7}}
#declare _Green = texture {pigment {rgb <0, 1, 0>*Shade} finish {diffuse 0.7}}
#declare  _Blue = texture {pigment {rgb <0, 0, 1>*Shade} finish {diffuse 0.7}}
#declare Checker = texture {pigment {checker rgb 0 rgb 1} scale 2 finish
{diffuse 1}}
//##########POV-RAY###############Bald
Eagle##############2019###################
#declare Square = union {
 triangle {<-5, 0, -5>, <-5, 0, 5>, <5, 0, -5>}
 triangle {<5, 0, -5>, <-5, 0, 5>, <5, 0, 5> }
 texture {Checker}
#declare Axes =
 union {
  #declare Line = 0.1;
  #declare Base = Line*3;
  #declare Length = 3.5;
  #declare Ext = 0.5;
  cylinder {<0, 0, 0>, <Length, 0, 0>, Line texture {_Red}}
   cone {<Length, 0, 0>, Base, <Length+Ext, 0, 0>, 0 texture {_Red}}
   text {ttf "timrom.ttf", "X", 0.02, 0.0 texture {_Red}
    translate <2, -1.125, 0>
  cylinder {<0, 0, 0>, <0, Length, 0>, Line texture {_Green}}
   cone {<0, Length, 0>, Base, <0, Length+Ext, 0>, 0 texture {_Green}}
  cylinder {<0, 0, 0>, <0, 0, Length>, Line texture {_Blue}}
   cone {<0, 0, Length>, Base, <0, 0, Length+Ext>, 0 texture {_Blue}}
  //no_shadow
object {Square translate -y*4}
object {Axes}
/* rearranging a bit and deleting extra unnecessary parentheses gives:
10*e
2) ) *
2) ) *
( pow (pow (x-2*a, 2) + pow (y/(2*b+1), 2)-1, 2)  - c+pow(2*z, 2) + d*pow
(y/(2*b+1), 2) ) -
10 * e}
// And then plug it into an isosurface declaration,
a
  #declare Range = 1;
  #declare Whole = yes;
  #declare Label = no;
  #declare Gradient = 50;
  #declare Min_factor= 0.6;
  #declare a = 0.8; // affects letter separation
  #declare b = 0.55; // affects "girdle" of the 8
  #declare c = 0.45; // affects top and bottom of numbers
  #declare d = 0.45; // also affects top and bottom of numbers
  isosurface {
    function {Equation (x, y, z, a, b, c, d)}
    //open
    threshold 0.5
    //max_gradient 10
    accuracy     0.01
    evaluate Gradient*Min_factor,  sqrt(Gradient/(Gradient*Min_factor)),  min
(0.7, 1.0)
    contained_by {box {<-3, -2, -1>*Range, <Whole*3, 2.3, 1>*Range}}
      texture {Tan} //interior_texture {Gray}
      //texture {Tex1}
     scale 1
Subject: Re: CNRS
Date: 19 Oct 2019 15:52:36
Message: <5dab6984$1@news.povray.org>
I use POV-Ray 3.7, but I rendered the image successfully with it, here :
	<http://eureka.atari.org/cnrs.png>
It's great, and you're really an advanced user, congratulations ! This
"80" shape was designed for today, October 19th 2019, the eighty
anniversary of the CNRS (centre national de la recherche scientifique)
the french institute for research.
It's really kind of you to have worked on this, because we can
celebrate this anniversary worldwide :-) Thanks to you !
I'm really amazed and I will study what you've done closer ...
Bald Eagle writes:
> //https://imaginary.github.io/80-cnrs/
> #version 3.8;
> #include "math.inc"
> camera {
>   up y
>   look_at <0, -2, 0>
>   //rotate -y*155
ular 0.2}}
fuse 0.7
ar 0.2
> reflection 0.02}}
> #declare Shade = 1;
use 0.7}}
use 0.7}}
use 0.7}}
ish
> {diffuse 1}}
>   texture {Checker}
> #declare Axes =
>   union {
>    #declare Ext = 0.5;
>    //no_shadow
> object {Axes}
> 10*e
69996;
w (y+2*b,
> 2) ) *
w (y-2*b,
> 2) ) *
ow
> (y/(2*b+1), 2) ) -
> 10 * e}
nly using
> a
>    #declare Range = 1;
>    isosurface {
>      //open
>      threshold 0.5
>      //max_gradient 10
>      accuracy     0.01
),  min
> (0.7, 1.0)
>        //texture {Tex1}
>       scale 1
Subject: Re: CNRS
Date: 19 Oct 2019 18:20:01
Message: <web.5dab8b7746c52bde4eec112d0@news.povray.org>
> Hi,
Yes, excellent - and now you have a nice scene to use with other isosurface
equations  :)
I'm getting there.  "Experienced", maybe.   "Advanced"...  I think I still have
a few more years to go, and a lot more reading "under the hood" until I can
start to play at the level some of the other folks do.
But thank you for the compliment.  :)
> This
Very nice.  It was pretty neat to read the description of how they came up with
the equation based originally on a torus, and then using some extra math to
perform a union.
I have been learning a lot from the ray-marching folks, and need to return there
to work out some more fun tools.
http://iquilezles.org/www/index.htm
It was fairly easy, since the equation didn't need much "unraveling" and it was
pretty much one equation with 3 variations.
Then I just plugged it into an existing scene that I made for the purpose.
It was a lot easier then some past work I've done, and I failed to mention that
if you expand all of the terms, or plug the equation into a website that will do
that for you (there are several) - then you can render this as a polynomial {}
object in POV-Ray.
See:
http://news.povray.org/povray.binaries.images/thread/%3Cweb.59eaa80bc23a6d95cafe28e0%40news.povray.org%3E/?ttop=428294&
toff=250
http://news.povray.org/povray.advanced-users/thread/%3Cweb.59e76275a367ac6c437ac910%40news.povray.org%3E/
http://news.povray.org/povray.binaries.utilities/thread/%3Cweb.59e8fd04c28e2cfdc437ac910%40news.povray.org%3E/
Subject: Re: CNRS
Date: 21 Oct 2019 13:30:20
Message: <5dadeb2c$1@news.povray.org>
Le 19/10/2019 à 17:55, Francois LE COAT a écrit :
> Hi,
> Best regards,
Equation is:
((((x+2*a)²+(y+2*b)²-1)²-c+2*z²+d*(y+2*b)²))*((((x+2*a)²+(y-2*b)²-1)²-c+2*z²+d*(y-2*b)²))*((((x-2*a)²+(y/(2*b+1))²-1)²-c+2*z²+d*(y/(2*b+1))²))-10*e
a, b, c, d & e are the sliders, but I cannot get their values from the page.
Yet, the "i" link open a subpage with
((((x+1)²+(y+1)²-1)²-1/2+2*z²+1/2*(y+1)²))*
((((x+1)²+(y-1)²-1)²-1/2+2*z²+1/2*(y-1)²))*
((((x-3/2)²+(y/2)²-1)²-1/2+2*z²+1/2*(y/2)²))-1
which is fine enough to ask wolfram to expand to get a polynomial
expression;
81/4 x^4 y^4 z^2 + 12 x^4 z^4 + 8 x^3 z^4 + 21/2 x^2 y^6 z^2 + 18 x^2
y^2 z^4 + 94 x^2 z^4 + 11 x y^6 z^2 + 26 x y^2 z^4 + 2 x z^4 + (9 y^8
z^2)/4 - (11 y^6 z^2)/8 + (33 y^4 z^4)/4 + 55 y^2 z^4 + 8 z^6 + (49
z^4)/4 + ... + x^12 + 2 x^11 - (17 x^10)/2 - (55 x^9)/2 - (47 x^8)/16 +
(157 x^7)/2 + (427 x^6)/4 + (37 x^5)/2 - (565 x^4)/8 - (129 x^3)/2 - (75
x^2)/4 + x - 12 y^2 + 1/16
(84 terms)
And it is just a transcription away from povray SDL with either poly syntax
http://wiki.povray.org/content/Reference:Poly
(good luck with the ordering of the coefficients) or polynomial syntax
(same object, easier to input)
http://wiki.povray.org/content/Documentation:Tutorial_Section_3.2#Polynomial_made_easy
You can of course experiment more with wolfram, keeping a to e if you dare.
Subject: Re: CNRS
Date: 21 Oct 2019 13:50:01
Message: <web.5dadef3446c52bde4eec112d0@news.povray.org>
Yeah - I tried looking through the page source to see if the initial slider
values were in there anywhere - but no.  :|
> expression;
> (84 terms)
Indeed, which is why I wrote that spreadsheet   :D
The strangest thing I found, was that when I opened the page, copied the
equation, and pasted it into SURFER, I get the (!) error indicator.   I have
corresponded with the folks over there once or twice about that, but it didn't
appear as though I was going to get very far.   Which is a shame - it seems to
be a very nice rapid-visualization and development application for polynomial
equations.
Subject: Re: CNRS
Date: 23 Oct 2019 10:59:16
Message: <5db06ac4$1@news.povray.org>
Bald Eagle writes:
e
 have
 didn't
eems to
nomial
> equations.
I also tested modelling the "80" shape from the CNRS anniversary, with
MathMod, with the help from its author Taha Abderrahman and it gives :
	<http://eureka.atari.org/mathmod.png>
The eighty anniversary of the institute was celebrated worldwide :-)
Best regards,
François LE COAT
