POV-Ray : Newsgroups : povray.general : REQUEST: Macro fol Scaffold? Server Time
16 May 2026 15:16:48 EDT (-0400)
  REQUEST: Macro fol Scaffold? (Message 1 to 10 of 19)
Subject: REQUEST: Macro fol Scaffold?
Date: 28 Jul 2019 23:48:47
Message: <5d3e6c9f$1@news.povray.org>
I have a cylinder shape in my scene, but want to build a scaffold around
it of triangles. Is there any macro or formula that can do that, with me
specifying thickness of the scaffold poles and the size of the triangles?
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Subject: Re: REQUEST: Macro fol Scaffold?
Date: 29 Jul 2019 06:20:01
Message: <web.5d3ec7e24ed4290e4eec112d0@news.povray.org>
Sven Littkowski <wrt### [at] yahoocom> wrote:
> Hi,
> http://www.avg.com
Easiest way would be to go around in a circle using r sin z and r cos x and make
a regular polygon.  Step up the side of the cylinder and zig-zag up from your
old polygon to where the new one will be.  Using an even number of sides will
make finding the radius and doing the zig-zags easier I think.
Once you get that worked out, you can likely back-calculate to how large the
triangles are and see if changing that will overcomplicate things.
Date: 29 Jul 2019 07:01:49
Message: <5d3ed21d@news.povray.org>
Op 29/07/2019 om 12:18 schreef Bald Eagle:
>> Hi,
>> http://www.avg.com
Years ago, when I was a temporary resident of Gancaloon, I wrote series
of macros to generate meshes fro a given heigh_field surface. I include
the set here for your inspiration; no documentation is available
however. ;-)
Download 'gridgen.mcr.txt' (9 KB)
Date: 29 Jul 2019 11:09:40
Message: <5d3f0c34$1@news.povray.org>
> however. ;-)
Thanks. I looked through it, but your code uses too many features I
never used before. I admit, I lack understanding, wouldn't know where to
start to make changes, and how to make changes. I might just have to
give up. :-)
http://www.avg.com
Date: 29 Jul 2019 16:25:01
Message: <web.5d3f54f34ed4290e4eec112d0@news.povray.org>
This is from November 2016, where there was some experimentation with scanning
objects with trace() and building triangles.  Obviously still needs some work.
Also, Jerome Grimbert has some excellent additions that do exactly this in
HgPOV-Ray.
http://wiki.povray.org/content/User:Le_Forgeron/tesselation
#version 3.7;
global_settings {
 assumed_gamma 1.0
 ambient_light color rgb <1, 1, 1>
#include "math.inc"
#include "transforms.inc"
#declare Camera_Origin = camera {
                            location  <0, 0, 0>
                            right    x*image_width/image_height
                            look_at   <0, 0, 0.01>}
#declare Camera_Angle = camera {
                            location  <0.0 , 0.0, 0.0>
                            look_at   <100, 30, 0>}
#declare Camera_Front = camera {
                            location  <2, 5, -30.0>
      //location  <0.0, 12, -10.0>
      sky y
                            look_at   <2, 5, 0>}
#declare Camera_Rear = camera {
                            location  <0.0, -100.0, -300.0>
                            look_at   <0, 0, 0>}
#declare Camera_Top = camera {
                            location  <0, 25.0, 0>
                            look_at   <0, 0, 0>}
#declare Camera_Iso = camera {
                            location  <-50, 0, 0>
                            look_at   <0, 0, 0>}
//camera {Camera_Front}
light_source{ <50, 50, -100>  color rgb <1, 1, 1>}    // White top
// Create an infinite sphere around scene and allow any pigment on it
sky_sphere{ pigment { gradient <0,1,0>
                      color_map { [0.00 rgb <0.6, 0.7, 1.0>]
                                  [0.35 rgb <0.0, 0.1, 0.8>]
                                  [0.65 rgb <0.0, 0.1, 0.8>]
                                  [1.00 rgb <0.6, 0.7, 1.0>]
                      scale 2
                    } // end of pigment
          } //end of skysphere -------------------------------------
#declare Cylinder = cylinder {<0, 0, 0>, <0, 10, 0> 2 pigment {Red} }
#declare Sphere = sphere {<0, 0, 0>, 2 pigment {Red} }
#declare Box = box {-1, 1 pigment {Red} }
#declare Cross = union {
 cylinder {<0, 0, 0>, <0, 10, 0> 1 pigment {Red} }
 cylinder {<-5, 5, 0>, <5, 5, 0> 1 pigment {Red} }
#declare Cross2 = union {
 cylinder {<0, 5, -5>, <0, 5, 5> 1 pigment {Red} }
#declare Torus = torus {3, 0.5 pigment {Red} rotate x*0}
#declare Blob =
 //union {
  blob {
  threshold .65
  sphere { <.5,0,0>, .8, 1 pigment {Blue} }
  sphere { <-.5,0,0>,.8, 1 pigment {Red} }
  finish { phong 1 }
//sphere { <.5,0,0>, .8 pigment { Blue transmit .9 }}
//sphere { <-.5,0,0>, .8 pigment { Red transmit .9 }}
//cylinder {<-1, 0, 0>, <1, 0, 0>, 0.65/2  pigment {color White transmit 0.9}
no_shadow}
#declare Object = object {Cylinder}
object {Cylinder}
// Scan object with a loop of traces
#declare Min = min_extent (Object);
#declare Max = max_extent (Object);
#declare MidHeight = (Min.y + Max.y)/2;
#declare Move = (Max.x*2)+4;
#declare Center = (Min.x + Move)/2;
        location  <Center, MidHeight, (Min.z*10)>
  sky y
        look_at   <Center, MidHeight, 0>}
#declare TraceRadius = max (Min.x, Max.x, Min.z, Max.z) * 2;
#declare Step = 0.5;
#declare Arcs = 36;
#declare TraceNormal = <0, 0, 0>;
#declare Degrees = 360/Arcs;
#declare OddShift = Degrees/2;
#declare Levels = (Max.y-Min.y)/Step;
#debug concat( " Levels = ", str(Levels, 3, 1), "\n")
#declare TraceMeshArray = array [Levels+1][Arcs+1];
#declare ArrayY = 0;
#declare ArrayX = 0;
#for (Y, Min.y, Max.y, Step)
 #if (odd(ArrayY))
  #declare Shift = OddShift;
 #else
  #declare Shift = 0;
 #for (Theta, 0, 360, Degrees)
  #declare MyTransform = transform { rotate  y*(Theta+Shift) };
  #declare TracePoint = vtransform (<TraceRadius, Y, 0>, MyTransform);
  #declare TraceMeshArray[ArrayY][ArrayX] = trace(Object, <0, Y, 0>, TracePoint,
TraceNormal);
  //#debug concat( " Y = ", str(ArrayY, 3, 1),  "     X = ", str(ArrayX, 3, 1),
"     TraceNormal = ", vstr(3, TraceNormal, ", ", 3, 0), "\n")
  cylinder {TracePoint, <0, Y, 0> 0.005 pigment {Blue} }
  #declare ArrayX = ArrayX+1;
#declare ArrayX = 0;  // reset X
#declare ArrayY = ArrayY+1;
// plot mesh vertices
#declare SphereRadius = 0.03;
  sphere {TraceMeshArray[ArrayY][ArrayX], SphereRadius pigment {Black} translate
x*Move}
// draw mesh edges
#declare SphereRadius = 0.025;
#declare SphereRadius = 0.0125;
  //horizontal edges
  #if (ArrayX >= 1)
   //#debug concat( "TraceMeshArray[ArrayY][ArrayX] = ", vstr(3,
TraceMeshArray[ArrayY][ArrayX], ", ", 3, 3), "
TraceMeshArray[ArrayY][ArrayX-1] = ", vstr(3, TraceMeshArray[ArrayY][ArrayX-1],
", ", 3, 3),"\n")
   cylinder {TraceMeshArray[ArrayY][ArrayX],
TraceMeshArray[ArrayY][ArrayX-1]+0.001, SphereRadius pigment {Green} translate
x*Move}
  // diagonal edges
  #if (Y > Min.y)
TraceMeshArray[ArrayY-1][ArrayX]+0.001, SphereRadius pigment {Green} translate
x*Move}
   #if (odd(ArrayY))
    #if (ArrayX < Arcs)
TraceMeshArray[ArrayY-1][ArrayX+1]+0.001, SphereRadius pigment {Green} translate
x*Move}
    #else
TraceMeshArray[ArrayY-1][0]+0.001, SphereRadius pigment {Green} translate
x*Move}
   #else
    #if (ArrayX > 0)
TraceMeshArray[ArrayY-1][ArrayX-1]+0.001, SphereRadius pigment {Green} translate
x*Move}
    #else
x*Move}
Date: 29 Jul 2019 20:09:59
Message: <5d3f8ad7$1@news.povray.org>
Okay, the scene works now. Thanks!    :-)
http://www.avg.com
Date: 29 Jul 2019 20:10:45
Message: <5d3f8b05$1@news.povray.org>
Thanks. At the moment, there seem to be various errors in the code. Some
errors were caused by wrong line breaks which I was able to correct
(Internet line format and Pov-Ray line format). But some other errors I
cannot dissolve at the moment.
http://www.avg.com
Date: 30 Jul 2019 12:32:41
Message: <5d407129@news.povray.org>
On 7/28/2019 11:48 PM, Sven Littkowski wrote:
> Hi,
> http://www.avg.com
For cylinders, there was Truss Generator include by Theran Cochran.
Cannot find a download link anywhere however.
Date: 30 Jul 2019 13:25:02
Message: <web.5d407d584ed4290e4eec112d0@news.povray.org>
http://www.oocities.org/ccolefax/links.html
http://www.oocities.org/ccolefax/download/truss.zip
Date: 31 Jul 2019 02:24:41
Message: <5d413429$1@news.povray.org>
Op 30/07/2019 om 19:24 schreef Bald Eagle:
Careful! Malwarebytes blocked both sites here.
