POV-Ray : Newsgroups : povray.general : Reverse operation of camera code Server Time
16 May 2026 15:17:30 EDT (-0400)
  Reverse operation of camera code (Message 1 to 8 of 8)
Subject: Reverse operation of camera code
Date: 23 Jun 2019 18:03:52
Message: <5d0ff748@news.povray.org>
Starting with location, look_at, angle and sky, I perform the following
operations:
#declare Camera_Location = <25.000000,15.000000,-33.000000>;
#declare Camera_Look_At = <2.000000,2.000000,0.000000>;
#declare Camera_Angle = 70.000000;
// should be able to set this to false as well
#declare Camera_Orthographic = true;
#local CamL = Camera_Location;
#local CamD = vnormalize(Camera_Look_At - CamL);
#local CamR = vnormalize(vcross(Camera_Sky, CamD));
#local CamU = vnormalize(vcross(CamD, CamR));
#local CamW = vlength(Camera_Look_At - CamL);
#if (Camera_Orthographic = true)
	#local CamR = CamR * CamW;
	#local CamU = CamU * CamW;
#declare Camera_Zoom		= 1/2/tand(Camera_Angle/2) * Camera_Aspect_Ratio;
#declare Camera_Direction	= CamD * Camera_Zoom;
#declare Camera_Right		= CamR * Camera_Aspect_Ratio;
#declare Camera_Up			= CamU;
The code calculates the values of the camera's direction, right and up.
My question is, how do I do the inverse? I.e. starting with location,
direction, right and up, how do I calculate look_at, angle and sky? It
seems like pretty simple algebra but I have been hitting my head against
the wall trying to figure it out.
Thanks.
Michael
Subject: Re: Reverse operation of camera code
Date: 23 Jun 2019 22:37:38
Message: <5d103772$1@news.povray.org>
> operations:
> #end
> Thanks.
> Michael
Disregard. I got it working.
Michael
Date: 25 Jun 2019 08:27:04
Message: <5d121318$1@news.povray.org>
Starting with location, direction, up and right I was able to figure out
how to calculate the angle; however I had trouble with look_at. I could
get a look_at that worked well enough to get an accurate render, but it
was was always normalized between 0 and 1 unless the camera was
orthographic. See the "Updated screen.inc" thread in p.t.s-f.
Michael
Date: 25 Jun 2019 17:40:01
Message: <web.5d12940e2334b4c74eec112d0@news.povray.org>
> Michael
Right, because it's not something that's going always going to be static and
untouched.
"When you specify the angle, POV-Ray adjusts the length of the direction vector
accordingly. The formula used is direction_length = 0.5 * right_length /
tan(angle / 2) where right_length is the length of the right vector. You should
therefore specify the direction and right vectors before the angle keyword. The
right vector is explained in the next section."
So unless you're going to store the "original" length of the direction vector,
which is going to be derived from look_at and location, you can only ever
backtrack to a normalized vector.
If it's a stored value, say, a scalar multiplier, then you can just multiply the
direction by that and you're back to "where you started". (assuming that's how
it all got defined)
It's like integrating - you lose the constants when you differentiate, and so
when you integrate, you just add "some constant C" into your equation.
So when you do your "reverse" calculations, all you can say for sure is "the
direction is <x, y, z> times some scalar multiplier C.   Which may or may not be
important.
Date: 25 Jun 2019 22:15:56
Message: <5d12d55c$1@news.povray.org>
Thanks. No, I'm not going to store values.
Michael
Date: 26 Jun 2019 16:40:01
Message: <web.5d13d7082334b4c74eec112d0@news.povray.org>
> Michael
Why not?   It's done all the time.
For instance:
#ifndef (Screen_Inc_Temp)
#declare Screen_Inc_Temp = version;
#version 3.7;
#version Screen_Inc_Temp;
Date: 26 Jun 2019 22:20:47
Message: <5d1427ff$1@news.povray.org>
>> Michael
> For instance:
I am overhauling "screen.inc". The macro has many modes, but it is only
meant to be called once per scene/render. You would need to run the
macro multiple times in order to create a variable and retrieve its
value later on.
Michael
Date: 27 Jun 2019 06:30:00
Message: <web.5d1499f52334b4c74eec112d0@news.povray.org>
> value later on.
One would presume that normal usage would start with a user declaring a camera
location and look_at.  That gives you both direction and magnitude.
#declare Temp_Direction = whatever;  right at the beginning of the macro.
Just use that stored value to fix your normalized vector before exiting the
macro.
Problem solved.
There are also loops, and #ifndef().
#while (Q) some flag to say that you're done, is undefined, loop back.
you can use #switch / #case / #break to select first pass or second pass code,
if you even needed to do more than a single macro run, which I don't think you'd
need to.
Just saying it's possible, not that it's necessary.
