On 8/8/2018 9:49 PM, Mike Horvath wrote:
> Can anyone recommend a nice star field? The texture that comes with
> POV-Ray is not very good.
> This one is okay:
> http://www.hoboes.com/NetLife/POV_Simple/5/2/
> Thanks.
> Mike
I also tried some public domain bitmaps, but my scene is under high
magnification, which causes the background to appear extremely pixelated.
Mike
You might want to check out Chris Colfax's old "Galaxy.inc" file; it can
apparently make 'just' starfields, with lots of settings. (I haven't used it
before-- in fact, I just downloaded it!)
Here are two sites where it's currently available...
http://objects.povworld.org/cat/Space/
and
http://www.oocities.org/ccolefax/galaxy.html
And there's always the brute-force method instead: lots of white spheres placed
way off in the distance. I would imagine that this simpler method might be less
memory-intensive than a pre-made starfield *image* (which might have to be quite
large in picel dimensions to get the proper detail, to avoid pixelation.)
>> This one is okay:
> Interesting; I wasn't aware of this bozo-pattern technique. Thanks.
bozo{colour_map{[0 rgb 2][0.2 rgb 0]}scale 0.006}
Looks like it rely on sub-pixel artifacts, just like the ones from the
distribution that use granite. It's just that it use a different base
pattern.
Just like those from skys.inc, it suffer the from same problem : Any
movement or rotation, of the camera will cause the stars to completely
change.
This make micro-pattern based skys unsuitable for animations.
This apply to granite, bozo(bumps, spotted), agate, crackle, cells, ...
based patterns.
With those, you can have coloured stars.
One possible option is :
bozo{colour_map
{[0 rgb 2]
[0.025 rgb<2,0,0>]
[0.0375 rgb 0]
[0.05 rgb<0,0,2>]
[0.075 rgb 2]
[0.2 rgb 0]}
scale 0.006
The skys from galaxy.inc don't suffer from that problem, but are more
memory intensive, take more time to parse and are somewhat slower to render.
try this:
sky_sphere {
pigment_pattern {granite scale 3}
pigment_map {
[0
crackle form <1,1,0>
scale .0035
color_map {
[.35 rgb .25]
[.55 rgb 0]
[1 rgb 0]
poly_wave .25
it's old code, haven't tested it with any recent version of POV-Ray, but
I suppose it'll still work.
cu!
ZK
