POV-Ray : Newsgroups : povray.general : Emissive object not showing up Server Time
16 May 2026 16:32:29 EDT (-0400)
  Emissive object not showing up (Message 1 to 5 of 5)
Subject: Emissive object not showing up
Date: 6 Aug 2018 07:55:25
Message: <5b68372d$1@news.povray.org>
I have created this object at the center of my scene, but it is not
visible. What mistakes have I made? Thanks.
Mike
sphere
	0, RWorld_Sun_Radius
	hollow
	material
		texture
			pigment {rgbt 1}
		interior
			media
				emission 100000
				density
					spherical
					density_map
						[0 rgb 0]
						[1 rgb 1]
					scale RWorld_Sun_Radius
Subject: Re: Emissive object not showing up
Date: 6 Aug 2018 11:18:35
Message: <5b6866cb$1@news.povray.org>
> Mike
> sphere
>     hollow
>     material
>         texture
>             pigment {rgbt 1}
>         interior
>             media
>                 emission 100000
>                 density
>                     spherical
>                     density_map
>                         [0 rgb 0]
>                         [1 rgb 1]
rgbt ? the t is for transmit, 1 would go for 100% transmission
Have you tried an homogeneous media ?
Any clue about the value of RWorl_Sun_Radius ?
Is material legit there ? (I would have expected texture & interior
alone), material was to transport them together with finish too.
Date: 6 Aug 2018 13:03:31
Message: <5b687f63$1@news.povray.org>
>> Mike
>> sphere
>>      hollow
>>      material
>>          texture
>>              pigment {rgbt 1}
>>          interior
>>              media
>>                  emission 100000
>>                  density
>>                      spherical
>>                      density_map
>>                          [0 rgb 0]
>>                          [1 rgb 1]
material is legit. Here, it really does nothing. It's only a wrapper to
make it possible to have a texture and an interior bundled together the
convenience.
The possible problem could be one of scale. If the scene contain
elements in the single unit range and other in the 10e6+ range, things
tend to break down.
What is the ratio between the length of the camera's location and
RWorld_sun_radius ? Is the camera farther than 1000000 units from the
origin ?
You may want to use a scale of over 1000 Km per unit. Even up to 10E6 Km
per unit.
Date: 6 Aug 2018 13:43:57
Message: <5b6888dd$1@news.povray.org>
> tend to break down.
> origin ?
> per unit.
// 1 unit = 100 miles
#declare RWorld_Sun_Diameter = 10000;
#declare RWorld_Ring_Radius = 950000;
#declare RWorld_Camera_Distance = 10;
#declare RWorld_Camera_Scale = RWorld_Ring_Radius * 1.1;
I think it did have something to do with scale. The problem went away,
but don't know how or why.
Here's the new version:
sphere
	hollow
	material
		texture
			pigment {rgbt 1}
		interior
			media
				emission 10/RWorld_Sun_Radius
				density
					spherical
					density_map
						[0.0 rgb 0]
						[0.1 rgb RWorld_Light_Point_Color]
						[1.0 rgb RWorld_Light_Point_Color]
Date: 7 Aug 2018 02:39:10
Message: <5b693e8e$1@news.povray.org>
That is probably true. To avoid confusion, I generally scale the
container at the end, e.g.:
sphere {
   0, 1
   hollow
   material {
       pigment {rgbt 1}
     interior {
       media {
         emission 10/MyScale
         scattering 3/MyScale
         density {
           spherical
           density_map {MyMap}
   scale MyScale
