POV-Ray : Newsgroups : povray.general : Feature Request: Line-by-Line Parsing (Error Tracking) Server Time
21 May 2024 23:14:40 EDT (-0400)
  Feature Request: Line-by-Line Parsing (Error Tracking) (Message 6 to 15 of 15)
<<< Previous 5 Messages Goto Initial 10 Messages
Subject: Re: Feature Request: Line-by-Line Parsing (Error Tracking)
Date: 27 Apr 2018 04:51:31
Message: <5ae2e493$1@news.povray.org>
On 04/26/2018 02:13 PM, Alain wrote:
> What if you get an error in file 153 that is caused by a flaw in file 73?
> Having smaller files won't help in this case, and it's a case that can
> happen very easily.
It's actually a case that happens a lot. Usually when I forget an #end.
In this case, I figure file 153 hasn't changed in years, and file 73 is
what I'm working on, so start there.  Sometimes I have to git diff for a
good visual clue where the missing #end is.
dik
Rendered 328976 of 330000 (99%)
Date: 27 Apr 2018 08:00:00
Message: <web.5ae31027c48ed6a6c437ac910@news.povray.org>
Yeah, I've run into this issue with closing curly braces }
That's why I really double-down on structuring my code with noticeable
indentations, comments on closing braces and #ends, and embedding #debug code
blocks into the various sections.
Embedding "opening" and "closing" #debug messages for macros and include files,
writing values of arguments passed to these to the #debug stream, and the
results of critical intermediate and final calculations can be a huge help in
tracking down what went wrong, where, and why.
Don't start writing your cvode assuming it's going to work - write it assuming
it's going to go horribly wrong, and 3 weeks from now when you can't even
recognize it as your own code or remember what you did or why --- you're going
to be SO thankful for those comments and helpful debugging features.  :)
Date: 27 Apr 2018 13:02:35
Message: <5ae357ab$1@news.povray.org>
I like that philosophy: assume your code goes horribly wrong.
But my suggestion for a Line-By-Line step parsing and for a
Until-Line-Number step parsing remains. Needed. And such a feature would
give much more convenience and support to the user.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 28 Apr 2018 02:56:20
Message: <5ae41b14$1@news.povray.org>
Don't get me started!
Oh Boy! Each time I swear to do that and, of course, forget during the
next project. I am a famous re-inventor of wheels if not hopeless
wanderer through a dark code wood. Still, I prevail in the end! ;-)
But, seriously, yes. The best advice to anybody indeed. I am now, when I
revisit an older scene, checking the state of the comments and add them
lavishly when necessary; taking out well-documented code snippets for
later use, etc.
The best checker is yourself.
Date: 28 Apr 2018 06:04:37
Message: <5ae44735$1@news.povray.org>
#end for me atm. :-(
Regards
Date: 28 Apr 2018 06:25:01
Message: <web.5ae44b32c48ed6a61b6c6b3a0@news.povray.org>
Haha, I too reinvent repeatedly. Sometimes I'm *certain* I've done something
before, but just can't remember which .pov file it was in or what it was called.
I've taken to ensuring all new tricks go into documented .inc files in my
include tree, that way I have somewhere to peruse when I'm half-remembering
something. At least once, I've used google on these forums because of something
I posted years ago :)
As to managing large POV-Ray projects - taking a modular approach is something I
favour. Parametrise everything, move blocks into macros, or declarations. If you
start getting too many nested blocks, declaring the inner workings to keep the
containers simple helps. Parsing speed might suffer in some cases, but you can
always optimise later if necessary.
When all else fails, as others have suggested, use the #debug stream to spot
where things start to go wrong. Sometimes I really miss a debugger (I guess one
could always debug the parsing code to see what the input file is doing!).
Bill
Date: 28 Apr 2018 07:04:50
Message: <5ae45552$1@news.povray.org>
Am 28.04.2018 um 12:04 schrieb Stephen:
Missing `}`, `#end` or even `)` in an include file are a PITA even from
the POV-Ray developer's point of view: The parser being the ugly mess it
is, it's virtually impossible to do the Pokemon on the various
variations of this theme. No way you can ever catch them all.
And, depending on the particular scenario, they do cause hard crashes.
Date: 28 Apr 2018 21:18:22
Message: <5ae51d5e$1@news.povray.org>
Same here - a debugger is really needed A LOT, that's how I feel. After
all, POV-Ray's language is to the widest part a programming language
(and yes, I LOVE that language!).
Line-By-Line
Up-To-LineNumber
These two are wildly, passionatly wanted! They will be sweeter than s..
I would say. ;-)
http://www.avg.com
Date: 29 Apr 2018 04:41:50
Message: <5ae5854e$1@news.povray.org>
Am 29.04.2018 um 03:18 schrieb Sven Littkowski:
> Line-By-Line
> Up-To-LineNumber
While I concede it's not as luxurious, we already have tools that can
provide you with that information:
    #debug "I'm here!\n"
and
    #error "Reached that line.\n"
You can even get the same information a call stack could give you:
    #debug "Entering macro FOOBAR\n"
    #debug "Leaving macro FOOBAR\n"
The /true/ benefit of IDEs is that they allow you to interactively
inspect (and often even modify) the current state of variables. Which
requires an interface to access that information at run-time. Which
requires programming effort. Which requires manpower. Of which
unfortunately we don't have as much as we'd like.
Rest assured however that your suggestion has been noted.
Date: 15 Jun 2018 20:42:02
Message: <5b245cda$1@news.povray.org>
Thanks. :-)
http://www.avg.com
