POV-Ray : Newsgroups : povray.general : Let Me Render That For You Server Time
16 May 2026 20:40:15 EDT (-0400)
  Let Me Render That For You (Message 1 to 10 of 10)
Subject: Let Me Render That For You
Date: 7 Nov 2017 05:53:47
Message: <5a0190bb$1@news.povray.org>
Hi folks,
it's late autumn over here, central heating isn't working properly, and
I consider electric heaters a waste of money... unless they produce
POV-Ray images as a byproduct.
So if any of you happens to be working on a render-time-consuming
project and could need some additional raw computing power, let me know
-- here's a computer that needs to render some POV-Ray frames to keep my
feet warm ;)
(Until then, I guess I'll try to get that warm and cozy feeling by doing
some cancer research for the WCG.)
Subject: Re: Let Me Render That For You
Date: 7 Nov 2017 06:22:33
Message: <5a019779$1@news.povray.org>
On 11/7/2017 5:53 AM, clipka wrote:
> Hi folks,
> feet warm ;)
sounds boring ... perhaps you should consider watching paint dry ;-)
Date: 7 Nov 2017 06:42:07
Message: <5a019c0f$1@news.povray.org>
Am 07.11.2017 um 12:22 schrieb Jim Holsenback:
>> Hi folks,
>> feet warm ;)
Drying paint doesn't warm my feet ;)
I currently don't have the time & energy to roll my own
render-time-consuming projects.
Date: 7 Nov 2017 07:50:01
Message: <web.5a01abdb294fb4d4c437ac910@news.povray.org>
Same here.
My loopy landlord somehow seems to think that Joule heating is "the most
efficient" because he was some sort of DOE "energy auditor".
As a tenant, "most efficient" = least amount of money per BTU.
I have a propane heating unit, which apparently has NEVER been used, was not
designed to be accessible for cleaning, and so when I finally got it fired up...
  :O
Many thanks for the offer - I'm sure someone may have a scene or two for you to
render  ;)
Date: 7 Nov 2017 08:30:26
Message: <5a01b572$1@news.povray.org>
On 07/11/2017 11:42, clipka wrote:
> Drying paint doesn't warm my feet;)
Train your cats to go to sleep curled around you feet. :)
Regards
Date: 7 Nov 2017 10:07:27
Message: <5a01cc2f$1@news.povray.org>
Am 07.11.2017 um 14:30 schrieb Stephen:
Ain't got any. (Cats, that is. Feet I still do have.)
Date: 7 Nov 2017 11:12:38
Message: <5a01db76$1@news.povray.org>
I use a hot water bottle wrapped in a pillow, myself.
As my old sensi used to say:
"Stick up for your feet and they will stand up for you."
And never a truer word, spoken.
Regards
Date: 8 Nov 2017 20:40:01
Message: <web.5a03b1d4294fb4d49c5d6c810@news.povray.org>
> feet warm ;)
I would send you the old Capriccio sample scene, modified to use 3.7/3.8, but
it's almost 12 MB compressed for whole set of folders and files. Not sure if
that could be trimmed down, I made changes to some image_maps too, part of the
bulk of the file size.
I've been trying animation of morning to night-- in a clumsy way-- and it's only
several hours at low resolution to do 100 frames but if radiosity is added,
resolution and frame count increased the render time gets way longer.
Date: 10 Nov 2017 02:15:01
Message: <web.5a0551b9294fb4d49c5d6c810@news.povray.org>
Um, sorry, not a "sample" or example scene file. Not part of POV-Ray
distribution, I remembered wrong.
A rendering is in POV-Ray Hall of Fame, and I think a link to its files too but
that link is broken. However Norbert Kern reposted them, so thanks for doing
that a few years ago Norbert!!
http://news.povray.org/povray.binaries.scene-files/thread/%3Cweb.542d85973c52af1d5f44f3a00%40news.povray.org%3E/?ttop=4
14950&toff=50
Going astray here, I didn't know Histogram file output (ini option +HTN for
example) was removed from 3.7 but I have a PNG histogram of the capriccio.pov
render, apparently done using version 3.6. I was going to try another using 3.8
and got the error about it being unrecognized.
C'est la vie!
Date: 18 Nov 2017 08:55:01
Message: <web.5a103af7294fb4d4990be8aa0@news.povray.org>
> Hi folks,
> feet warm ;)
Wow, that is an incredibly generous offer! :) I am a bit surprised that nobody
took up the offer though. There are countless times that I have needed/wanted
more raw power...
Best wishes! /A
