POV-Ray : Newsgroups : povray.general : Transparent PNGs Server Time
18 May 2024 06:03:13 EDT (-0400)
  Transparent PNGs (Message 15 to 24 of 44)
Subject: Re: Transparent PNGs
Date: 10 Oct 2017 02:41:43
Message: <59dc6ba7@news.povray.org>
On 9-10-2017 14:00, Stephen wrote:
> On 09/10/2017 12:38, Thomas de Groot wrote:
>> It might be better to render as tga and later convert to png if
>> necessary.
> Is that one of those "Plant thy Mandrake when the moon is in Taurus and
> waning gibbous.", things? :-P
LOL Yes, but then adapted to the digital world. Even so, I indeed
recommend Mandrake over a Homunculus. ;-)
I seem to remember to have had problems generating transparent png
images while I never had problems with tga.
Date: 10 Oct 2017 03:27:29
Message: <59dc7661$1@news.povray.org>
>>> necessary.
>> and waning gibbous.", things? :-P
Definitely Mandrake over Homunculus. Unless you are going to...
I recognised the form of the spell. I had the same problem donkey's
years ago.
There was a time when PNGs behaved badly. I think it was not writing the
Alpha values in the output.
Regards
Date: 10 Oct 2017 03:34:52
Message: <59dc781c$1@news.povray.org>
>>>> necessary.
Yes, unless. ;-)
> years ago.
That must be the origin of my dim memory of ancient trouble...
Date: 10 Oct 2017 08:26:43
Message: <59dcbc83$1@news.povray.org>
>>>>> necessary.
> Yes, unless. ;-)
Indeed.
>> years ago.
>> the Alpha values in the output.
I seem to remember Billboards were all the rage about that time.
Regards
Date: 10 Oct 2017 10:10:14
Message: <59dcd4c6$1@news.povray.org>
Am 10.10.2017 um 09:27 schrieb Stephen:
> years ago.
If I may clarify:
PNG output in POV-Ray v3.6 had the alpha mode wrong - i.e. how the alpha
channel is supposed to interact with the colour channels.
The PNG specification mandates so-called "straight alpha", i.e. the
colour channels should hold the colour as if the image was fully opaque,
and blending should be done entirely by the display software, using
Alpha:(1-Alpha) as the ratio between stored colour and background. This
is akin to the way in which semi-transparent pigments are specified in
POV-Ray's SDL.
However, POV-Ray's internal computations yield colour channel values
that already take opacity into account, which is akin to so-called "gay
alph..." uh, I mean, "associated alpha" aka "premultiplied alpha", in
which the display software is only responsible for the background
portion of the blending, using 1:(1-Alpha) as the ratio between stored
POV-Ray v3.6 neglected the issue of alpha mode entirely: In file output
it directly wrote the computed colour values, thus always writing in
associated alpha mode (which happens to be wrong for PNG files). In file
input, on the other hand, it interpreted the colour values in much the
same way as in SDL, thus always reading in straight alpha mode (which
happens to be correct for PNG files but wrong for certain other files).
So not only was POV-Ray v3.6 in violation of the PNG file format specs,
it also was inconsistent in itself.
In POV-Ray v3.7, a proper alpha handling framework was implemented, and
the problem fixed for PNG files.
(Interestingly, even though the modes are referred to as "associated
alpha" and "straight alpha", it's not actually the alpha channel that's
different between the two modes -- the value stored is actually
identical for both modes -- but the colour channel.)
The advantage of "straight alpha" is that you can display an opaque
version of the image simply by ignoring the alpha channel.
The advantages of "associated alpha" are that (a) it takes less
computational effort to display, and (b) it can account for situations
where bright light is to be shown against a highly transparent
background (e.g. a transparent sphere with highlights).
Date: 11 Oct 2017 02:48:25
Message: <59ddbeb9$1@news.povray.org>
>>>>>> necessary.
>> Yes, unless. ;-)
> Indeed.
As you say.
>>> years ago.
Yes, and then it faded away. I wonder what will be next.. ;-)
Date: 11 Oct 2017 02:55:01
Message: <59ddc045$1@news.povray.org>
>> years ago.
> If I may clarify:
> POV-Ray's SDL.
It comes back now, yes. Thanks for the reminder. Interesting to notice
how it is former bad behaviour that sticks in the memory rather than the
later correction. Survival adaptation, no doubt ;-)
Date: 11 Oct 2017 06:26:04
Message: <59ddf1bc$1@news.povray.org>
>> years ago.
> If I may clarify:
> POV-Ray's SDL.
Interesting insight, thanks. :-)
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Date: 11 Oct 2017 06:31:12
Message: <59ddf2f0@news.povray.org>
On 09.10.2017 06:56, Sven Littkowski wrote:
> Hi
> is it possible to create a scene where the rendered items are visible
> but the entire empty background becomes transparent, if the output image
> is a PNG?
> http://www.avg.com
I want to mention another problem that I have since I switched monitors
(now using a 16:9 monitor): the object of the scene has shifted to the
right side.
I tried to create a better camera, but still fail to get the 0.0 center
of the scene as center of the camera. Any assistance?
This is what i have now:
camera
 location < 0.0,  0.0, -50.0 >
 look_at  < 0.0,  0.0,   0.0 >
 right 1.77*x
Date: 11 Oct 2017 06:49:58
Message: <59ddf756$1@news.povray.org>
Am 11.10.2017 um 12:31 schrieb Sven Littkowski:
> right side.
> camera
>  right 1.77*x
That should work just fine -- at any resolution.
Are you sure it's not just your display software?
A test scene might be helpful.
(Also, I'd recommend using `right x*16/9` rather than the fudgy factor
of 1.77; with full-resolution renders it does make a difference of
something in the order of 10-20 pixels. Or use `right
x*image_width/image_height` to be independent of output image aspect ratio.)
