POV-Ray : Newsgroups : povray.general : Transparent PNGs Server Time
18 May 2024 18:37:36 EDT (-0400)
  Transparent PNGs (Message 11 to 20 of 44)
Subject: Re: Transparent PNGs
Date: 9 Oct 2017 10:05:01
Message: <web.59db8201c5de9ff4c437ac910@news.povray.org>
Sven Littkowski <I### [at] SvenLittkowskiname> wrote:
> Which brings me to the next problem, how to
> recreate one of the Roman-style galley oars. it is too easy just to use
> a long cylinder with a flattened (thin-scaled) oval cylinder at the end.
> The transition between shaft and brad area was kinda smooth.
I'd start by posting a close-up / detailed image of what you want to do in 3D
(if you can't find an existing 3D model) and then I'm sure someone could
recommend a mesh-modeling, CSG, isosurface, or blob approach.
Date: 9 Oct 2017 14:04:27
Message: <59dbba2b@news.povray.org>
The very strange thing with me is, that I find it extremely hard to
model with WYSIWYG surfaces, but I find it totally easy to write scenes
with all the coordinates by myself and understand them. This is how I
got my huge spaceships done.
Okay, here is the sample photo. These oars have no real edges, every
corner has been rounded and smoothened. And even the edge between staff
and blade is kinda smoothened a bit.
Diese E-Mail wurde von AVG auf Viren geprüft.
http://www.avg.com
Download 'oars.jpg' (245 KB)
Preview of image 'oars.jpg'
Date: 9 Oct 2017 15:10:01
Message: <web.59dbc948c5de9ff4c437ac910@news.povray.org>
Yep, we all have our own ways of understanding and manipulating data.
CSG:
cylinder shaft
Cone tapered from shaft to near the end
flattened cones, slices of cones, or CSG parts of narrow rectangles for blades
flattened sphere or a box for the tip of the blade
If you look through the isosurface docs, you can come up with functions for all
of those primitives, their rotations and translations, and differences, and then
blob them together to get a totally smooth surface.
It sounds hard until you give it a go, and then it doesn't seem too bad.
Use the isosurface approximation or the (I believe very similar) Paul Nylander
mesh code to make an array of smooth_triangle vertices, and you could then
generate a mesh and save it.
'cause it sounds like you want to render a fleet of Roman vessels....
Date: 9 Oct 2017 17:02:52
Message: <59dbe3fc$1@news.povray.org>
> CSG:
> cylinder shaft
lades
or all
nd then
ander
n
I wished I had the skills to render an entire ship! I have all the
maritime archaeological knowledge, but not the skill to create such
shapes in any renderer. But this is a dream for more than 10 years...
For now, the oars only.
http://www.avg.com
Date: 10 Oct 2017 02:41:43
Message: <59dc6ba7@news.povray.org>
On 9-10-2017 14:00, Stephen wrote:
> On 09/10/2017 12:38, Thomas de Groot wrote:
>> It might be better to render as tga and later convert to png if
>> necessary.
> Is that one of those "Plant thy Mandrake when the moon is in Taurus and
> waning gibbous.", things? :-P
LOL Yes, but then adapted to the digital world. Even so, I indeed
recommend Mandrake over a Homunculus. ;-)
I seem to remember to have had problems generating transparent png
images while I never had problems with tga.
Date: 10 Oct 2017 03:27:29
Message: <59dc7661$1@news.povray.org>
>>> necessary.
>> and waning gibbous.", things? :-P
Definitely Mandrake over Homunculus. Unless you are going to...
I recognised the form of the spell. I had the same problem donkey's
years ago.
There was a time when PNGs behaved badly. I think it was not writing the
Alpha values in the output.
Regards
Date: 10 Oct 2017 03:34:52
Message: <59dc781c$1@news.povray.org>
>>>> necessary.
Yes, unless. ;-)
> years ago.
That must be the origin of my dim memory of ancient trouble...
Date: 10 Oct 2017 08:26:43
Message: <59dcbc83$1@news.povray.org>
>>>>> necessary.
> Yes, unless. ;-)
Indeed.
>> years ago.
>> the Alpha values in the output.
I seem to remember Billboards were all the rage about that time.
Regards
Date: 10 Oct 2017 10:10:14
Message: <59dcd4c6$1@news.povray.org>
Am 10.10.2017 um 09:27 schrieb Stephen:
> years ago.
If I may clarify:
PNG output in POV-Ray v3.6 had the alpha mode wrong - i.e. how the alpha
channel is supposed to interact with the colour channels.
The PNG specification mandates so-called "straight alpha", i.e. the
colour channels should hold the colour as if the image was fully opaque,
and blending should be done entirely by the display software, using
Alpha:(1-Alpha) as the ratio between stored colour and background. This
is akin to the way in which semi-transparent pigments are specified in
POV-Ray's SDL.
However, POV-Ray's internal computations yield colour channel values
that already take opacity into account, which is akin to so-called "gay
alph..." uh, I mean, "associated alpha" aka "premultiplied alpha", in
which the display software is only responsible for the background
portion of the blending, using 1:(1-Alpha) as the ratio between stored
POV-Ray v3.6 neglected the issue of alpha mode entirely: In file output
it directly wrote the computed colour values, thus always writing in
associated alpha mode (which happens to be wrong for PNG files). In file
input, on the other hand, it interpreted the colour values in much the
same way as in SDL, thus always reading in straight alpha mode (which
happens to be correct for PNG files but wrong for certain other files).
So not only was POV-Ray v3.6 in violation of the PNG file format specs,
it also was inconsistent in itself.
In POV-Ray v3.7, a proper alpha handling framework was implemented, and
the problem fixed for PNG files.
(Interestingly, even though the modes are referred to as "associated
alpha" and "straight alpha", it's not actually the alpha channel that's
different between the two modes -- the value stored is actually
identical for both modes -- but the colour channel.)
The advantage of "straight alpha" is that you can display an opaque
version of the image simply by ignoring the alpha channel.
The advantages of "associated alpha" are that (a) it takes less
computational effort to display, and (b) it can account for situations
where bright light is to be shown against a highly transparent
background (e.g. a transparent sphere with highlights).
Date: 11 Oct 2017 02:48:25
Message: <59ddbeb9$1@news.povray.org>
>>>>>> necessary.
>> Yes, unless. ;-)
> Indeed.
As you say.
>>> years ago.
Yes, and then it faded away. I wonder what will be next.. ;-)
