POV-Ray : Newsgroups : povray.general : trace question Server Time
14 Jan 2026 11:44:13 EST (-0500)
  trace question (Message 1 to 10 of 15)
Subject: trace question
Date: 10 Sep 2017 09:13:19
Message: <59b53a6f$1@news.povray.org>
If I trace an object. How can I get the colour of the intersection of
the ray and object. As far as I can see trace() only returns the normal.
Regards
Subject: Re: trace question
Date: 10 Sep 2017 09:27:07
Message: <59b53dab$1@news.povray.org>
Am 10.09.2017 um 15:13 schrieb Stephen:
You'll need to know the pigment of the object, and invoke `eval_pigment`
on the intersection point you get...
... and hope that the pigment isn't UV-mapped, nor uses a special
pattern like slope or aoi.
Date: 10 Sep 2017 10:01:16
Message: <59b545ac$1@news.povray.org>
Thanks, I had a blank in my memory.
Hope is not involved because there is a good chance I would want to do
that. Is it at all possible?
Regards
Date: 10 Sep 2017 11:03:50
Message: <59b55456$1@news.povray.org>
Am 10.09.2017 um 16:01 schrieb Stephen:
No; not with the current versions of POV-Ray. The `trace` function would
have to be extended to report the UV coordinate of the intersection, so
that you could then feed it into `eval_pigment` instead of the 3D
coordinate.
Date: 10 Sep 2017 11:26:00
Message: <59b55988$1@news.povray.org>
> coordinate.
Again, thanks.
In that case for UV mapped models I'll continue to use the slicing
method for creating df3s for meshes.
Regards
Date: 10 Sep 2017 15:22:09
Message: <59b590e1$1@news.povray.org>
hi,
> coordinate.
do I understand this correctly?  if I trace some object with a regular
pigment it will work, but the trace will fail if the object's
pigment/colour is "not simple"?  seems .. strange.
regards, jr.
Date: 10 Sep 2017 15:57:35
Message: <59b5992f$1@news.povray.org>
Am 10.09.2017 um 21:22 schrieb jr:
> hi,
>> coordinate.
No, the `trace` function works perfectly fine for what it was designed
for: It gives you the point in 3D space where a given ray intersects a
given geometric object. In and of itself, it has nothing to do with
pigments whatsoever.
Likewise, the `eval_pigment` function works perfectly fine for what it
was designed for: It gives you the colour of a given pigment for a given
point in 3D space. In and of itself, it has nothing to do with geometry
whatsoever.
And that's where the problem with UV-mapped textures arises: Since
`trace` knows nothing about textures, and `eval_pigment` knows nothing
about geometry, the two can only be combined for good effect if there is
a direct mapping between geometry and pigment via 3D XYZ space. But with
UV-mapping that's not the case, and hence the /combo/ of the two
functions breaks down there.
Date: 10 Sep 2017 17:28:29
Message: <59b5ae7d$1@news.povray.org>
hi,
> whatsoever.
thanks.
regards, jr.
Date: 10 Sep 2017 17:55:01
Message: <web.59b5b3b6c9840c1a5cafe28e0@news.povray.org>
So, the color of a surface on a uv-mapped object is not directly measurable by
the eval_pigment() function? [ ! :O ]
I would never have guessed that.
It must then use a completely different algorithm than the ray-object
intersection used to generate the final scene.
Can you:
1. use trace() to get the point and the normal
2. define a pigment constructed in the plane intersecting that point with the
same normal
( I likely have no idea what I'm talking about here: I'm just confabulating the
possibility that some slice of a function-object-pattern thing might be a
workaround... )
3. then do an eval_pigment() on the plane?
Date: 11 Sep 2017 03:11:38
Message: <59b6372a$1@news.povray.org>
Follow up question.
How would you use eval_pigment if you were tracing a CSG?
Is it possible?
Regards
