POV-Ray : Newsgroups : povray.general : Problems with different shadows in the same scene Server Time
18 May 2024 07:07:31 EDT (-0400)
  Problems with different shadows in the same scene (Message 1 to 7 of 7)
Subject: Problems with different shadows in the same scene
Date: 28 Jul 2017 05:50:00
Message: <web.597b044e348a2f7c7942b6570@news.povray.org>
Hello
Every time when I tried to render the scene I've got different results. The
difference was in the lighting of the scene. In the scene there is only one HDR
sky_sphere.
I am using official 3.7 build on Windows and unofficial MacOS build 3.7.1.
Is there something I've missed?
Here are two examples of the resulting image: https://ibb.co/gR9VkQ
Here is complete test scene:
#version 3.7;
#include "finish.inc"
#default{
  finish{
    ambient 0
    diffuse 1
global_settings {
  radiosity {
    pretrace_start 0.08
    pretrace_end   0.04
    count 35
    nearest_count 5
    error_bound 1.8
    recursion_limit 3
    low_error_factor .5
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1
    adc_bailout 0.01/2
sky_sphere{
  pigment{
    image_map {
      hdr "..\kitchen_probe.hdr"
      map_type 1
      interpolate 4
  } // end of pigment
} //end of skysphere -----
// perspective (default) camera
  location  <0.0, 1.2, -2.0>
  look_at   <0.0, 0.5,  0.0>
// scene
sphere{ <0,0,0>, 0.5
  texture{
    pigment{ DimGray }
    finish{ Dull }
  } // end of texture
  translate <0, 0.5, 0>
plane{
  <0,1,0>, 0  hollow // normal vector, distance to zero ----
  texture{
    pigment{ Gray }
    finish{ Dull }
  } // end of texture
Subject: Re: Problems with different shadows in the same scene
Date: 28 Jul 2017 07:00:03
Message: <597b1933$1@news.povray.org>
Le 28/07/2017 à 11:44, gregors a écrit :
> Hello
> sky_sphere.
Nearly complete, missing kitchen_probe.hdr
(I found one at
http://www.cgadvertising.com/pages/free-materials/hdr-maps.php
It can be reproduced simply adding +KFI0 +KFF10 (here on linux, so not
platform specific)
Yet, have you read http://wiki.povray.org/content/HowTo:Use_radiosity ?
Radiosity is not reproducible (there is a lot of randomness in it), you
need to save & reload radiosity data if you want always the same result
(such as in animation).
Date: 28 Jul 2017 09:05:00
Message: <web.597b35c66fc2aca09c5d6c810@news.povray.org>
> > Hello
> > sky_sphere.
> platform specific)
Since you said that I had to check to be sure, I know there's always some
resampling going on even when always_sample off is being used. Or so I believe,
and the doc seems to say same.
Having tried the animation using command line +rf"hdr_rad" for one frame and
adding +rfi for the other frames, animated it still flickers from changes to the
radiosity.
Before doing that I was trying higher count and some other settings. I had also
used a different hdr file in place of the kitchen.
I was able to render successive frames without visible deviations by using count
>1600 called the Halston method in the docs.
Maybe the other settings contribute to the smoothness too.
I'm still not very good with radiosity settings, I tend to find what looks best
for particular scenes while trying for fast renders too.
Here's that global_settings from the test scene.
global_settings {
 assumed_gamma 1
  radiosity {
    pretrace_start 0.08
    pretrace_end   0.02
    count 1601 // >1600 is Halston method
 always_sample off
 //max_sample 0.9
    nearest_count 12
    error_bound 1.2
    recursion_limit 2//3
    low_error_factor 0.4
    gray_threshold 0.0
    minimum_reuse 0.015
    brightness 1
    adc_bailout 0.01/2
Date: 28 Jul 2017 10:15:01
Message: <web.597b46276fc2aca07942b6570@news.povray.org>
Thank you for the answers. They helped a lot.
Date: 28 Jul 2017 22:39:13
Message: <597bf551@news.povray.org>
Le 17-07-28 à 05:44, gregors a écrit :
> Hello
> sky_sphere.
> #version 3.7;
> #default{
>    finish{
>      ambient 0
>      diffuse 1
Not a good idea. A value around 0.6 to 0.8 will give more realist
results.> to    }
> global_settings {
>    radiosity {
>      pretrace_start 0.08
>      pretrace_end   0.04
Should be smaller, like 0.01 or even 0.005
>      count 35
MUCH to small for a pure radiosity scene. Ok in a scene using regular
light_source.
Use at least 75, probably more.
Also, you should try the 2 parameters variation. The second value set a
pool of samples directions. It help reduce artefacts.
try this :
count 160, 5555
>      nearest_count 5
Maybe a little small.
Take advantage of the adaptive version :
nearest_count 5, 20
>      error_bound 1.8
Maybe a little smaller, like 0.9
This is OK when NOT using pure radiosity, but illuminating your scene
with light_source.
>      recursion_limit 3
>      low_error_factor .5
OK, but you may want to try something smaller here also. Good values
range between 0.1 and 0.5
>      gray_threshold 0.0 // OK
>      minimum_reuse 0.015 // OK
>      brightness 1 // OK
>      adc_bailout 0.01/2 // Probably OK
> sky_sphere{
>    pigment{
>      image_map {
Take note that it's a single direction probe. It have a blind spot and
you can see the camera.
>        map_type 1
>        interpolate 4
>    } // end of pigment
> camera {
> // scene
>    texture{
>      pigment{ DimGray }
>      finish{ Dull }
>    } // end of texture
> plane{
Why add «hollow»? It have absolutely no effect in this scene.
>    texture{
>      pigment{ Gray }
>      finish{ Dull }
>    } // end of texture
Date: 29 Jul 2017 00:50:00
Message: <web.597c137e6fc2aca0883fb31c0@news.povray.org>
I recently discovered this random light-patch-brightness as well (while
animating my 'city buildings.') I thought it was because I had used the rather
crude default values for radiosity. Saving and reloading the data sounds like a
good idea.
I need to read the up-to-date documentation; haven't done so in a long while.
I don't think I've ever tried using radiosity in an animation, until now.
Thanks for clarifying.
Date: 31 Jul 2017 15:10:01
Message: <web.597f80846fc2aca09c5d6c810@news.povray.org>
"omniverse" <omn### [at] charternet> wrote:
>   radiosity {
>     pretrace_start 0.08
>     pretrace_end   0.02
>     count 1601 // >1600 is Hal(-s)ton method
>  always_sample off
>  //max_sample 0.9
>     nearest_count 12
>     error_bound 1.2
>     gray_threshold 0.0
>     minimum_reuse 0.015
>     brightness 1
>     adc_bailout 0.01/2
Apologies for the spelling mistake. Halton not Halston. A pseudo-randomization,
distributed more evenly.
